Liittle Bleeder
Discussion in 'UK Motorcycles' started by steve auvache, Mar 6, 2006.
  1. By Motrax.
    Presumably it is just a simple one way valve in a fancy tube but has
    anyone used one yet and does it work?
  2. steve auvache
    Mark Guest
    : By Motrax.
    : Presumably it is just a simple one way valve in a fancy tube but has
    : anyone used one yet and does it work?
    Haven't used the motrax one but i've used the one way stuff for some time
    now. Just changed the fluid on the Blackbird with the complications of the
    linked system and all was well. Certainly wouldn't go back to opening and
    closing the bleed screws every few seconds.
    Mark
    Mark, Mar 6, 2006
  3. Mark wrote
    Exactly and for a tenner it seems almost irresistible, especially as I
    am about to take all the brakes to bits on the GS.
  4. steve auvache
    Mark Guest
    : >Haven't used the motrax one but i've used the one way stuff for some time
    : >now. Just changed the fluid on the Blackbird with the complications of
    the
    : >linked system and all was well. Certainly wouldn't go back to opening and
    : >closing the bleed screws every few seconds.
    : Exactly and for a tenner it seems almost irresistible, especially as I
    : am about to take all the brakes to bits on the GS.
    or about £7 at the local Halfords.
    Mark
    Mark, Mar 6, 2006
  5. Mark wrote
    Bugger, I am going to Halfords sometime this week.
  6. steve auvache
    Bollocks, man. There is only one true tool for brake bleeding and
    that is the mighty Mityvac.
    Pip, Mar 6, 2006
  7. Pip wrote
    I know, I know but they cost more than a tenner.
  8. steve auvache
    mb Guest
    Got.
    Very useful for refilling the system but I have to put a load of grease
    on the bleed screw threads to stop air getting sucked down.
    I have speedbleeders TAAW.
    mb, Mar 6, 2006
  9. 1. Squeeze brake lever/push pedal whilst at the same time undoing bleed
    screw until fluid escapes.
    2. Place finger tip over bleed screw to act as a none return valve.
    3. Continue the above until all air is expelled.
    A container should be used to catch the expelled fluid and an assistant
    might be usefull to do the squeezing of the lever if point 1 is out of
    reach of point 2.
    Harry Bloomfield, Mar 7, 2006
  10. steve auvache
    'Hog Guest
    Simpler and better. Use a length of tubing of appropriate diameter.
    Double up the free end and zip up with a cable tie. Make a slit with a
    fine scalpel blade just above the fold. Works perfectly as a valve. Keep
    that end in a container.
    'Hog, Mar 7, 2006
