Lights with no off switch?
Discussion in 'Australian Motorcycles' started by CrazyCam, Feb 1, 2010.
  1. CrazyCam
    CrazyCam Guest
    Hi folks.
    Back in the dim distant days, the Australian government brought in a
    "Lights on" rule for motorcycles, then, after much argument, that rule
    was removed, and there was a statement that it was perfectly legal to
    retro-fit, or otherwise "fiddle" with a motorcycle which had hard wired
    on lights, so that those lights could be switched off.
    Does anyone know if that is still legal, and might some one be able to
    post a URL to the current rule?
    regards,
    CrazyCam
  2. I believe thats it's legal to ride with your lights off as you can do on all
    older motorcycles. I also believe you can legally fit an on/off headlight
    sw. to a modern M/C. Sorry no URL just my understanding.
    A mate, one of two I have, has fitted a european switchblock with said
    om/off headlight sw. to his 916 and didn't have trouble getting a roadworthy
    in QLD when he decided to re register it after several years of storage.
    Not a very conclusive answer I know and he self insures. If insurance is
    your main concern try asking your insurance Co. otherwise maybe contact the
    revelent Road and Traffic body in your state, they're allways such a delight
    to deal with .
    Capt. A. L.
    Capt About Lunchtime, Feb 1, 2010
  3. The mandated law, made for bikes made after 1992, was rescinded in 1996
    after it was pointed out that it could be more dangerous for motorcycles to
    have their lights when they had the sun behind them, making them almost
    invisible to oncoming traffic.
    And other reasons as well.
    Europe are going to make it compulsory to have daytime driving lights from
    2011, but, Europe does not have the bright setting sun that we have, that is
    they get the sun at all.
    A few HSV drivers have been complaining they are being pulled over by the
    coppers for having driving lights on during the day and they have to explain
    to the coppers that the lights are on with the ignition.
    George W Frost, Feb 1, 2010
  4. CrazyCam
    Toosmoky Guest
    Yes it is legal, there is no rule anymore.
    NZ is a good source of light switches for models that didn't have them
    here. I bought a UK light switch for my Trump but haven't bothered
    looking for one for DR Suzi.
    Toosmoky, Feb 1, 2010
  5. CrazyCam
    Boxer Guest
    I have fitted the Eurpoean spec switch block to some of my BMW's to enable
    the headlight to be switched off.
    Not sure it that is "Legal" but never had a problem with the Law on that
    point.
    Boxer
    Boxer, Feb 2, 2010
  6. CrazyCam
    theo Guest
    Road rules are 'suggested' by the Fed gov't but must be enacted, and
    rescinded, by State Gov'ts. In WA, when the law was repealed, the
    Minister of Police supplied the Motorcycle clubs who did all the
    complaining with a letter stating that it was quite legal to retrofit
    a light switch to motorcycles not so equiped. You will need to check
    NSW law.
    Theo
    theo, Feb 2, 2010
  7. CrazyCam
    CrazyCam Guest
    Hi Boxer.
    Yeah, I,too, have bought the Euro spec switch, IIRC on your
    recommendation as to supplier, and fitted it to the R850R.
    I am now working my self up to a frenzy to fit an off switch to the Triumph.
    Unfortunately, Triumph do not seem to build a Street Triple, for any
    market, with on/off headlight switch, hence my question about "reverse"
    relays.
    Neither have I, but I am sure that when the ADR for lights on was
    repealed, there was an announcement that allowed the retro-fitting of
    on/off switches. I am equally sure that that dispensation has never been
    withdrawn. Regardless, I intend to modify my Triumph.
    But, I was discussing my plan for re-wiring my Triumph with another
    owner of a recent model Triumph, and, while he'd really like to have
    such an option, was questioning the legality of it.
    I tried to find chapter and verse for the allowing of switches, but my
    internet searching skills in the areas of laws and rules and such like
    are far inferior to those of others in this group.... hence my question.
    regards,
    CrazyCam
    CrazyCam, Feb 2, 2010
  8. CrazyCam
    CrazyCam Guest
    Hi Theo.
    Yeah, I think you are right.
    The feds do the ADRs, which, I think, was the mechanism for the lights
    on business while the states do the annual testing....pink slip in
    NSW... which requires all the stuff on the bike, when new, to operate as
    it did out of the box.
    So it might well be a state based dispensation to override hard wired
    headlamps.
    regards,
    CrazyCam
  9. CrazyCam
    Cam,
    I just had a look at BikeBandit
    http://www.bikebandit.com/2008-triumph-motorcycle-street-triple/o/m17742
    and it's a bit ambiguous but it seems to indicate that there's a switch on
    the LEFT switchblock. Could that be right?
    Kath Lilley <> at Jack Lilley's would know for certain
    (and be able to give you the best price).
    Cheers ....
    Knobdoodle, Feb 2, 2010
  10. CrazyCam
    CrazyCam Guest
    Hi Clem.
    Yeah, well the trouble is, the left hand switch block does have the
    Dip/Hi-beam switch.
    It also has a wee blanking plate where the on/side/off light switch used
    to be.
    The older TT600 (?) had an almost identical switch block, but with the
    on/side/off switch included.
    Trouble is, there isn't (AFAIK) any market where the Street Triple is
    sold where it has the light switch, so, I don't imagine that the wiring
    loom will have any way of accepting, say, a switch block from a TT600.
    On some of the dedicated Striple fora, a few of the poms are a bit
    pissed off about this, since the UK doesn't require headlights on, but,
    apparently Europe either does, or perhaps, will require them on.
    A wiring diagram for a Street Triple seems to be top secret, and not
    available to the average punter...even if you wave money. :-(
    regards,
    CrazyCam
  11. CrazyCam
    hippo Guest
    WA might be a special case (yes, ok), because IIRC it was the only State
    that doidn't sign up to ADRs. True? If true, is that still the situation?
    hippo, Feb 2, 2010
  12. CrazyCam
    Toosmoky Guest
    Try an earlier Speed Triple switchblock. The switch block for my T595
    just plugged in to the same plug that the original did. Nothing else needed.
    Toosmoky, Feb 2, 2010
  13. CrazyCam
    Toosmoky Guest
    What year? My Manuals cover up to VIN 210444 for the OEM and up to the
    '05 models for the Haynes.
  14. CrazyCam
    CrazyCam Guest
    hippo wrote:
    Hi hippo.
    Well, it wouldn't really surprise me. ;-)
    I didn't actually think that states got a choice in signing up for ADRs,
    but, cricket is a funny old game, and Australia is a fairly strange, and
    at times, illogical country. (Albeit, I love it!)
    <with that thought, I grab an other beer>
    regards,
    CrazyCam
  15. CrazyCam
    CrazyCam Guest
    Hi Toosmoky.
    The thing is, the Street Triple came out after Triumph seem to have
    decided that headlights need to be on...... everywhere. :-(
    There isn't (AFAIK) a market where that model has a working on/side/off
    switch, so would they (as in Triumph) bother to design the capability
    into a new wiring loom?
    The BM was a piece of piss, 'cos they sold the bike in various places,
    some places had switches, others didn't, so the loom worked with both
    options, but..... a new bike, new loom, no alternatives planned
    for....<shrug>
    regards,
    CrazyCam
  16. CrazyCam
    Toosmoky Guest
    Aaah, *Street* Triple. I still read Speed Triple when I see that...
  17. CrazyCam
    theo Guest
    that doidn't sign up to ADRs. True? If true, is that still the situation?[/QUOTE]
    No. It is up to each State to incorporate ADR into their laws. As it
    is much easier than making local ADRs they mostly comply.
    Theo
    theo, Feb 2, 2010
  18. CrazyCam
    Boxer Guest
    I would switch it by building a sub loom between the bulb and the original
    bulb plug, utilising an aftermarket bulb batton.
    Boxer
    Boxer, Feb 2, 2010
  19. CrazyCam
    Hmm.. I just read your thread on Triumphrat and I see what you mean.
    Have a look at the switchblock connector to be sure; mine had less wires on
    the swithblock side and a link joining two of the pins. When I got the
    replacement it had the missing wires (and the switch).
    Did you read the thread about Striples not starting without the headlights
    connected? That might need a little bit of investigation.
    Last but least; if it's just starting that you're after (which I'm fairly
    sure it ISN'T) you can run a relay off the sidestand light to kill the
    headlights when the sidestand is down. This is what I did on my old Sprint
    to save the battery.
    Cheers .... Clem
    Knobdoodle, Feb 3, 2010
  20. CrazyCam
    CrazyCam Guest
    Knobdoodle wrote:
    Hmm, I had forgotten about Triumphrat ... too much advertising for my
    limited download. :-|
    Well, from the wee bit of wiring diagram here:-
    http://www.street-triple.co.uk/index.php?option=com_smf&Itemid=26&topic=2320.0
    the box marked 3, looks like one of those SPDT relays, with the
    "normally closed" position feeding electricity to the lights, and the
    switched position feeding power to the starter. (diagram doesn't show
    starting detail)
    The "not starting without headlights connected" probably came from early
    attempts of pulling the fuse, box 2 in diagram, which feeds both lights
    and starter.
    Certainly, when the starter button is pushed, the headlights only appear
    to dim, but I suspect that is showing power to them being cut, but only
    for the very short length of time required for the motor to fire up.
    Sidestand light? What decadence! ;-)
    While it would be elegant to find a TT600 switch block, and wire it into
    the lights the way it should have been done, I'm pretty much convinced
    that the least disturbance and risk will be adding an extra switch to
    the bars, one extra relay, and wiring as per Theo's post.
    Assuming the existing relay uses "normal" spade connectors, and I can
    find room for the extra relay, I should be able to do what I want
    without actually cutting or modifying any existing wires, thus I'll be
    able to undo this mod if required.
    regards,
    CrazyCam
    CrazyCam, Feb 3, 2010
