Lights: what's the running cost
Discussion in 'UK Motorcycles' started by Hankjam, Nov 10, 2007.
  1. Hankjam
    Andy C Guest
    think more carefully -
    on a typical bike the shunt resistor from the voltage regulator might be
    approx 5ohms - the shunt resistor is then switched off automatically as the
    lights are switched on- thus on some bikes by switching on just the side
    lights you are drawing less current than with them off
    the rest of your bad-tempered rant is fundamentally flawed too, but i fear
    you may have a temper tantrum and pop a vital vain should you have to
    further endure the audicity of someone not agreeing with you
    cheers,
    andy
    Andy C, Nov 11, 2007
  2. Hankjam
    Cab Guest
    You really don't know steve, do you?
    Cab, Nov 11, 2007
  3. Hankjam
    Andy C Guest
    the energy lost
    i'm not certain i understand you correctly, but i don't think so... i think
    this is a very signicant loss with permanent magnets, i would say in reality
    more like someone dabbing a brake on and off than your description - i would
    liken your description (very loosely) to kicking over a single cylinder bike
    with or without the plug in there..
    with the plug in you have the hard to kick compression bit followed by the
    helping expansion thrust - but overall much more work is require to spin it
    than with no compression
    yes, accepted- i just picked a basic setup as it seemed an easy example
    cheers,
    andy
  4. Hankjam
    Andy C Guest
    nah, lol
    think i'd best go back to lurking ;-)
  5. Most bikes don't use 'dump to earth' rectification any more, that went
    out in the days of the Ark. These days many, if not most, bike
    alternators are like car alternators and the electrical load is passed
    on to the engine as mechanical load pretty much directly as demanded.
    Permanent magnets are so yesterday, daddy-oh.
    Oh, and it's 'vein', btw.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Nov 11, 2007
  6. Hankjam
    Andy C Guest
    now you've made me feel old :-(
  7. and learn to post properly.
    Bad temper, you haven't seen bad temper.
    No my comments is based entirely upon your flawed understanding of the
    basic principles of physics. Nothing for free and all that tosh.
    steve auvache, Nov 12, 2007
  8. The phrase I use is:
    "The roads are a co-operative system" - ie if people have a degree of
    co-operation it all flows a lot more smoothly.
    And yes - that does mean that sometimes you have to give way to
    someone..
    Phil.
    Phil Launchbury, Nov 12, 2007
  9. Hankjam
    Ye-ess, but when kicking over an engine you've got some blow-by and
    the increased piston side-thrust friction. An alternator is purely
    rotary and has more-or-less even forces all round. I'm sure there will
    be some mechanical loss though.
    Ah.
    Pip Luscher, Nov 12, 2007
