Lights: what's the running cost
Discussion in 'UK Motorcycles' started by Hankjam, Nov 10, 2007.
  1. Hankjam
    Hankjam Guest
    I've always ridden with my lights on. I reckon it might help but you
    never know.
    In terms of petrol consumption what is the difference with or with
    out?
    and also on lights.... why do so few people use indicators? I think it
    does not hurt to tell those around me what my plans are.
    Whether they believe me is another matter.
    In this part of the world, East Cent Scotland, they are either never
    used or as a last thought just after a manoeuvre is initiated..
    Aj
  2. Hankjam
    Dave Emerson Guest
    Too small to measure in real world conditions
    Many drivers just use indicators as an alternative to looking.
    Dave Emerson, Nov 10, 2007
  3. Hankjam
    The power consumption is marked on each bulb. I'd guess it was
    insignificant relative to all the other things that consume petrol:
    speeding, hard acceleration, lack of maintenance, luggage, unaerodynamic
    clothing and generally riding like a ****. So much so, in fact, that some
    bike manufacturers reckon they can get away with deleting the off switch.
    You're on a bike. You could have a naked Nordic nubile on the pillion,
    indicating with her norks, and you'd still be invisible. So why bother?
    It's Porridgestan. They're all too drunk.
    platypus, Nov 10, 2007
  4. Hankjam
    Bod43 Guest
    "used or as a last thought "
    It's <pauses to check appostrophie use> the
    same everywhere I have been in the UK.
    I do not use indicators in general for lane changes
    on motorways for example since I found (decades ago)
    when I first started driving that from time to time
    a following driver would cut me off when they saw the
    indicator. I do not extend this to turning right
    at traffic lights or anywhere else where the traffic
    behind has to do anything or might reasonably
    benefit from such a signal.
    I think of them considering the the box on the
    insurance form "Did you indicate" and indicating
    at the last moment such that after the collision the
    broken bulb can be forensically examined to show
    that they were indeed indicating.
    is to start to turn the wheel and, as the
    indicator stalk is just about to pass out of reach
    of the quarter-to-three hand, to flick on the indicator.
    This is consistent with your observation.
    I have never bothered to ask what was in anyones
    head at the moment that the useless turn signal
    came to life.
    My method is of course not convenient for filtering
    motorcyclists on the motorway but there were none
    then where I was living.
    Bod43, Nov 10, 2007
  5. Hankjam
    christofire Guest
    Having a play in the car with some ecu data logging stuff, turning
    lights on made no difference in the l/hr consumption rate.
    I really wouldn't worry about it. Technically, the power will have to
    be generated, but it's so little as to be negligable.
    christofire, Nov 10, 2007
  6. You will consume more, how much I can't be arsed to calculate.
    Drivers? Isn't it obvious what they are going to do next?
    Riders? We are invisible, why complicate matters further for the
    drivers? And besides it costs petrol to use them.
    steve auvache, Nov 10, 2007
  7. Hankjam
    ts Guest
    Technically, negligible. Unless you also e.g. mainatain tyre pressures
    within 1 psi of the most economical level, in addition to all the other
    fuel saving parameters.
    An other way of looking at it; on your bike about half the cost of when
    running a car, but with a significantly better (five- ten- or
    whatever-fold reduced risk) safety benefit.
    ts, Nov 10, 2007
  8. Hankjam
    Domènec Guest
    70W is roughly 1/10th of a hp. Suppose there is an inefficiency of 50% in
    generating electricity. That makes an (awesome) 0.2hp spent in lighting. If
    the bike uses an average of 50hp, you spend 0.4% of the bike energy in
    lighting. If you spend, say, 7 euros of fuel evey 100kms, that makes some 3
    cents.
    So, who cares?
    Domènec, Nov 10, 2007
  9. Hankjam
    Ofnuts Guest
    So true... though I have never tried this particular setup myself.
    Ofnuts, Nov 10, 2007
  10. Hankjam
    Neither have I. But it's on the list.
    platypus, Nov 11, 2007
  11. Hankjam
    When I indicate, I already own the space I'm going into. The message
    conveyed by the indicator is, emphatically, not "Oh, I'm thinking of
    changing lanes, if that's all right with you. No? Oh, well, maybe later."
    The message is "Here is the news."
    You seem to be saying that you've spent decades driving around without
    learning anything.
  12. Hankjam brought next idea :
    Find out the Kilowatt output of your engine, then work out the total
    consumption (wattage) of your lights when turned on. Later will be
    something like 2x 65w + 2x 6w + 20w for panel lights etc. So call it
    162 watts or 0.162 Kw extra load - an insignificant extra load for most
    engines. Of course your engine does not run at its maximum Kw output
    all of the time - you probably ride most of the time at less than 1/3
    of its maximum power.
    Simple laziness?
    Harry Bloomfield, Nov 11, 2007
  13. Hankjam
    Is that like chatting up a member of the opposite sex?
    Pip Luscher, Nov 11, 2007
  14. Hankjam
    Donald Guest
    I think I'll order one straight away, I might regret not having one.
    Heh, after visiting darn sarf for a couple of days, I'm pretty sure
    there are a lot more pissed drivers down here.
    Donald, Nov 11, 2007
  15. Hankjam
    Rich B Guest
    Sucking his keyboard for inspiration, Pip Luscher typed:
    Or the same. This is 2007, you know.
    Rich B, Nov 11, 2007
  16. Sorry mate, but that makes you a bit of a ****, imo. The whole driving
    experience on motorways depends to a large extent on people behaving
    sensibly and reasonably safely, including indicating where necessary
    (which is pretty much always).
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Nov 11, 2007
  17. Hankjam
    God, how the centuries fly.
  18. Hankjam
    Andy C Guest
    i don't think this is true - the only way (i can think) you could possibly
    use more petrol by having the lights on is if it creates an extra load on
    the engine making it more difficult for the engine to turn (as for example
    a belt-driven air conditioning compressor on a car does when it is
    engaged).... unless you count the effect of the reverse thrust of the light
    beam generated (!)
    on a bike with stator/ flywheel setup to recharge the battery, i would have
    thought a fixed load to the engine is created by the magnets on the flywheel
    regardless of how or whether the generated power is utilised - often any
    unused power generated will just be shunted to earth by the regulator as
    heat when the lights are off anyway
    might be wrong, i was once before
    cheers,
    andy
    Andy C, Nov 11, 2007
  19. Of course it fucking is true. Do you honestly think that electricity is
    an energy free by-product of the heat making process? The alternator is
    spinning all the time the engine runs, this is all the time and friction
    costs money. Additionally when you ask the alternator for energy in the
    form of electricity you have to put some extra mechanical energy into it
    this costs fuel. A vanishingly small amount as others have mentioned
    but not free.
    You still are.
    steve auvache, Nov 11, 2007
  20. Hankjam
    Apart from the power consumed by the lights and battery charging,
    IWHTthat the bulk of the energy lost by the relative movement of pole
    pieces or magets is going to be stray eddy currents - the energy lost
    overcoming the pull of the magnets as the poles move away from a
    magnet will be recovered (more-or-less) when the magnet start
    attracting the next pole piece in turn. The only other way I can think
    of energy loss is hysteresis in the iron pole-pieces. No idea how much
    that would be.
    The regulator may or may not shunt energy, depending on how it works.
    It could be: series resistance; shunt resistance, both, or in the case
    of an XS750, neither - they don't have permanent magnets. The
    regulator adjusts the output by adjusting the stator current instead.
