This commute is being a PITA [1] Is there either a nice touring type bike that I should buy for 120 miles per day, or a light clutch conversion pack? TIA [1] Pain In The Arm -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
Catman says... Have you fitted the reach adjustable clutch lever from the Bonneville yet? -- Lozzo Triumph Daytona 955i SE (Black with added black bits) GSF600SW (broked) 'I do not object to people looking at their watches when I am speaking. But I strongly object when they start shaking them to make certain they are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
No Is this a good thing? -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
Catman says... It's a dogleg version with a span adjuster like your brake lever has, so makes it easier to use than the straight one you have. Pop over and we'll fit mine to your bike so you can try it out if you like. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) GSF600SW (broked) 'I do not object to people looking at their watches when I am speaking. But I strongly object when they start shaking them to make certain they are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
OK, first thing is to find out where the problem lies - strength (or lack thereof) or nerve damage (which is my main problem). That said, I assume from my short experience of a Speed Dribble, that you've got at least some weight on your hands when you're riding slowly - and that is likely to be a large part of the problem. IME it's the push & pull action (pushing your body up and pulling the clutch against it at the same time) that's the killer. If you've got a cable clutch (I don't think you do though, right), there's a mechanism called 'easy clutch' that you can put into the cable that changes the gearing and makes the clutch easier to operate. On BMWs at least it also pretty much ensures that the clutch will drag... Anyway, you could look into fitting higher bars or bar raisers to your bike instead. You basically want to sit as upright as possible but that means you'll need a fairing for riding longer distances. Regarding tourers, well. I haven't tried *everything* but my impression is as follows: Honda ST1100 Pan Euro. Not bad, bearable for me but you've still got some weight on your wrist. ST1300 - only sat on one, I think the bars are a tad higher. Clutch again appears to be similar to the 1100. BMW - forget any 4V boxer with a cable clutch. An old R80RT or R100RT should be OKish, as should be the R100GS. K100/1100LT - the same. 4V Boxers with hydraulic clutches are a lot easier on the hand, but you're still looking at either an RT or a GS. One bike I found extremely useable was a very late (2005) Harley big twin. The clutches on the new ones are surprisingly light and you pretty much have zero weight on your arms. Plus, the big ones (at least in touring guise)are superb mile munchers.
Well the pain is actually in my shoulder / neck Yes, that could well be true. The pain doesn't really ease when not using the clutch IYSWIM No, it is cable Yes, I was afraid of that, thinking of how they work. Hmm, which starts to look like a less good idea. Not sure if there are any for the Triple OK, the earlier ones were already in the frame anyway. They seem ideal for what I'm doing. Problem is finding the time to find one. K100 is fave at this point. Might have to sell the Triple though Oh. Right. Shame Thanks for all that -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
I had the same problem going from the nice, light hydraulic clutch on the old Tiger to the cable clutch on the 955. There are a couple of things that may help help though: 1. Make sure the lever is in the right position i.e. when holding the bars normally, stretch your fingers out in a straight line with your forearm, & ensure the lever is just below them. If you have to bend your fingers or wrist up a bit to clear the lever, it needs adjusting down. 2. Loosen the cable nuts at the engine end, & any clamps, & make sure the cable isn't twisted. This isn't unknown on Tigers, & the extra friction makes the pull stiffer. 3. Get one of those eazipull things to go between lever & cable. Most off-road parts suppliers sell them. -- Krusty www.MuddyStuff.co.uk Off-Road Classifieds '02 MV Senna '03 Tiger 955i '96 Tiger '79 Fantic Hiro 250
for a winter bike? -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
I *think* it's fine, but I will double check. Just bee serviced and adjusted, but I may well give it a double check. It's not *that* heavy, but it's *too* heavy IYSWIM Ta -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
It only takes a slight twist when fiddling with your nuts to make it stiff[1], & we all know how careful spanner monkeys are with these things. [1] Yes, I know. -- Krusty www.MuddyStuff.co.uk Off-Road Classifieds '02 MV Senna '03 Tiger 955i '96 Tiger '79 Fantic Hiro 250
Heh. TBH it's always had this effect, but I've never done 120 miles day on the M25 before. You should be ashamed. I shall check over the weekend. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
Reasonably. I only get it in the left shoulder and it carries on after I've stopped. -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman It appears he failed to understand your stinging retort. -- Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in Performance Bikes and Fast Bikes WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL) IbW#41 SBS#39 OMF#6 Enfield 500 Curry House Racer "The Basmati Rice Burner", Honda GL1000K2 (On its hols) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big" Suzuki TS250 "The Africa Single" Yamaha Vmax Honda ST1100 wiv trailer
Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark Olson Hive no idea, is it? -- Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in Performance Bikes and Fast Bikes WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL) IbW#41 SBS#39 OMF#6 Enfield 500 Curry House Racer "The Basmati Rice Burner", Honda GL1000K2 (On its hols) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big" Suzuki TS250 "The Africa Single" Yamaha Vmax Honda ST1100 wiv trailer
Using the patented Mavis Beacon "Hunt&Peck" Technique, Verdigris Bloody Italian engineering, eh? "There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't. There's drive. ****! There isn't..." -- Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in Performance Bikes and Fast Bikes WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL) IbW#41 SBS#39 OMF#6 Enfield 500 Curry House Racer "The Basmati Rice Burner", Honda GL1000K2 (On its hols) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big" Suzuki TS250 "The Africa Single" Yamaha Vmax Honda ST1100 wiv trailer
I've got a GoldWing like that. -- | ___ Salad Dodger |/ \ _/_____\_ GL1500SEV/CBR1100XXX/CBX1000Z |_\_____/_| ..87753../..22653.../..31893. (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 WG* |__|_|__| BOTAFOT #70 BOTAFOF #09 PM#5 \ |^| / IbW#0 & KotIbW# BotTOS#6 GP#4 \|^|/ ANORAK#17 IbB#4 YTC#4 two#11 '^' RBR Clues: 84 Pts:1800 Miles:5704
Wicked Uncle Nigel says... Sounds like an Alfa Romeo 156 with 'Selespeed', or whatever they call it, transmission. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) GSF600SW (broked) 'I do not object to people looking at their watches when I am speaking. But I strongly object when they start shaking them to make certain they are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
