Lifting the front while leant over
Discussion in 'UK Motorcycles' started by Gyp, Apr 11, 2005.
  1. Gyp
    So we're talking about the effective increase in gravity in the plane
    of the bike/rider due to centrifugal force (whether or not centrifugal
    force actually exists), yes?
    In which case I don't see where the 1.4G comes from, as surely it's not
    a fixed figure, but one that depends on the speed you're going? The
    extra weight whilst leaning at 45 degrees at 150mph will be much higher
    than at 20mph.
    If it's physically impossible for there to be less than 1G acting on
    the plane of the bike/rider at any speed/angle, then I'll concede. In
    fact I'll concede anyway coz it's not something I want to be thinking
    about at bedtime :)
    Krusty, Apr 12, 2005
  2. Gyp
    All I know is that if you run out of suspension on the front when you're
    going round a corner you fall off. Running out of suspension means that
    something is making the weight of the bike and rider more.
    It all evens out. At 150mph a 45 degree lean isn't going to tun you as
    tightly as at 20mph is it?
    Heh..
    Muck, Apr 12, 2005
  3. Gyp
    Gyp Guest
    I'm off to nitromors off the wheel paint to lighten the wheels, pop on
    the tankbag to shift some weight and whip the oil out of the forks as
    that'll reduce the damping
    Hurrah!
    Gyp, Apr 12, 2005
  4. Gyp
    LOL!
  5. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Krusty"
    You must have farted at the same time. Counteracts the effect, see?
    Grimly Curmudgeon, Apr 12, 2005
  6. Gyp
    Park.
    :eek:))
    Muck, Apr 13, 2005
  7. Gyp
    Fill the enpty space in the tank with helium, don't forget to shut the
    cap quickly though.
    Muck, Apr 13, 2005
  8. Gyp
    Or just turn the bike upside down while so doing.
    Ace, Apr 13, 2005
