Left-handers
Discussion in 'UK Motorcycles' started by Power Grainger, Sep 9, 2003.
  1. Now that Lozzo's fixed my clutch lever settings for me, turning right
    isn't quite the same drama as it was [1]. Thanks again, Lozzo!
    However, turning left seems to have become a bit of an issue. Esp from
    major roads into minor roads. So much so that I brought the bike to a
    stop whilst turning left a couple of days ago, as I felt the bike to
    be so unstable. Thankfully there was no-one behind me at the time.
    I've put the nervousness of turning left down to actually having
    dropped it on the left whilst doing slow (1-2mph) speeds and losing
    the front whilst manouevering in driveways.
    But what is actually causing the bike to feel so unstable? Am I going
    too fast (for my level of experience) into the turn? Braking too late?
    Not in the right gear, so not enough torque [1]? If any of you can
    cast your minds back to when you weren't confident, and can offer
    suggestions for improvement, I would be most grateful. (esp as I'd be
    less likely to get rear-ended on the way up to EOSM on Saturday).
    [1] The biting point was a *long* way from the handlebars, so i was
    struggling to control it, as my arm and fingers were extended to the
    max.
    [2] insert relevant word here, I think it's torque but I could be
    wrong...
  2. Power Grainger
    Sorby Guest
    Your increasing fear of left-handers is probably not helping.
    My guess is that you're relying more on the outside handlebar for support
    when cornering.
    On right handers the left hand is playing more of a supporting role and the
    throttle hand is able to control the throttle better and gives you a sense
    of stability.
    On left handers your right hand (throttle hand) is operating the throttle
    AND playing the supporting role - hence the competing forces/roles cause the
    instability.
    Ideally you only want to be applying pressure to the handlebars when
    actually counter-steering. The rest of the time the hands should be relaxed
    and the throttle gradually winding open to 'drive' you through the bend.
    Sorby, Sep 9, 2003
  3. Power Grainger
    Difficult to say, from your description, but I'd guess it're more
    likely that you're going too slowly. At the speeds you suggest you're
    doing (1-2mph) it's much more difficult to keep a bike upright than at
    10-15.
    Other hints might include slipping the clutch and keeping some revs
    on, as you were taught to for your U-Turn practise, and making sure
    you look in the direction you want to end up in. Seriuously, this can
    really help make it smooth and natural, honest.
    Ace, Sep 9, 2003
  4. Power Grainger
    flashgorman Guest
    I had a similar problem with right handers after an enormous crash on a
    right hand bend. I eventually solved it by having a not quite so enormous
    crash on a left hand bend. This has led me to conclude that your most
    comfortable cornering direction is the one you've not crashed on recently.
    flashgorman, Sep 9, 2003
  5. Starting to square off slightly...
    William Grainger, Sep 9, 2003
  6. Power Grainger
    Klaatu Guest
    VBG
    Klaatu, Sep 9, 2003
  7. Too right.
    But in a 90 degree turn, in 2nd gear, say, are you actually
    countersteering? Is it maybe that I have heard of "this thing called
    countersteering" and I vaguely know how it works when on the nice
    twisties, but I try and use it when the bike's not actually creating
    the gyro effect coz it's going too slowly?
  8. Sounds sensible. I think I may have been looking at the wall on the
    far side of the turning and thinking "don't hit that or the cars
    coming out of the turn!"
  9. Heh. True.
  10. Power Grainger
    There are two elements to counter-steering - one is the gyro effectm
    the other is the basic geometry of the bike. So yes, at low speeds
    pushing the opposite bar will result in the bike dropping towards the
    corner, at whcih point the wheel will naturally turn in the direction
    you want to go. Don't get hung up on this though - it's more important
    to just practise until it feels right than work out the precise
    dynamics of the thing.
    Oh, and above all else, _relax_. If you're tense you'll be fighting
    the bike's natural tendency to stabilise itself.
    Ace, Sep 9, 2003
  11. Power Grainger
    Sorby Guest
    Ah - I didn't read your initial post closely enough - soz.
    If it's slow speed corners/turns that you have a problem with then the
    instability you're experiencing probably comes mostly from the lack of
    speed/gyroscopic effect (as you mentioned).
    You still need to be positive with the throttle and drive through/out of the
    turn confidently.
    If you're feathering the clutch too much when pulling out of a junction to
    join a main road you might be sapping much needed power and the bike isn't
    getting enough forward drive?
    Difficult to assess without seeing you in action (Fnnaar!)
    Get yourself down to Dr. Gower's pronto.
    Sorby, Sep 9, 2003
  12. Power Grainger
    Cane Guest
    ...and I've touched those pants :)
    cane [at] ukrm.org ¦ fireblade, r30
    botafo t#50 f#03 YTC #15 bbb #6 apostle [kotl]
    New? http://www.ukrm.net/faq/ukrmscbt.html
    Rideout? http://www.horrible.demon.co.uk/botafof/
    "Brace yourselves ladies, I'm coming in dry"
    Cane, Sep 9, 2003
  13. Power Grainger
    Martian Guest
    Power Grainger wrote:
    [snip left hand worries]
    try giving it a bit more gas and more counter steering, it sounds like
    the bike is falling into the corner as the forces pushing it out are too
    low.
    I have heard it mentioned by a number of bikers that they prefer/feel
    more comfortable with left hand bends over right hand bends.
    Martian, Sep 9, 2003
  14. Power Grainger
    Cane Guest
    I'd recommend this option.
    Cane, Sep 9, 2003
  15. That's v kind. Though no doubt I will get a lot of 'advice' on
    Saturday, given the amount of poeple who have said they want to HAG.
    Will's ridden it, but all he seems to notice is how small it is, so it
    feels a bit awkward for him anyway.
  16. heh, "yesterday I couldn't even *do* corners, today I can get my knee
    down and wheelie round em!"
    sounds good to me...
  17. emailed, ta.
  18. Power Grainger
    Cane Guest
    Cane, Sep 9, 2003
  19. Power Grainger
    Spete Guest
    "Power Grainger" <> schreef in bericht
    So many feedlines, so little time ;-)
    Spete, Sep 9, 2003
  20. err let's see
    1. bike goes where you look so make sure you're looking at the
    right place
    2. get yourself and t'other half to an empty car park one evening
    or sunday and practice slow speed manoeuvres - essential on any new
    bike. Take some old tin cans or cut some tennis balls in half to act as
    "cones" so you can learn how to do zig zags, slalom, full turns etc. I
    generally do this with each bike I buy just to help me "bed in" how the
    controls work and also to prove the bike and I can do those moves if
    necessary.
    3. you're still in the learning phase where your brake, throttle,
    steering control is taking more of your brain power than it will do in
    future. If you accept that and concentrate on clocking up the miles it
    will click faster than if you worry about it.
    4. as others have said - relax, don't use a death grip on the
    controls.
    5. If you've got other things on your mind then you may be losing
    concentration.
    You'll get there - no panic. We all make mistakes - I was on the Beemer
    last Saturday and my riding was awful. I put it down to tiredness, being
    tense and having virtually no concentration.
    Do you or Will buy Bike magazine? The last issue (Sept) had some
    articles about confidence which were very good. Unfortunately it's no
    longer on the stands as the new one's just come out but I'm sure you
    could get hold of a copy to read.
    Paul Corfield, Sep 9, 2003
