left curves
Discussion in 'Australian Motorcycles' started by F Murtz, Jan 9, 2011.
  1. F Murtz
    Nev.. Guest
    I've seen a kawasaki with throttle, brake lever, clutch lever,
    indicator, horn and kill switch all on the left handlebar.
    http://thisstupidurl.com/kawa.jpg
    Nev..
    Nev.., Jan 10, 2011
  2. This is a very good point. I've never quite bought the old "throttle
    hand" argument, but I'm not sure why.
    Now that I think about it, I've always been more comfortable sliding out
    the rear wheel on a pushbike when turning left. I guess it's something
    you get used to when young, but I seem to recall that most people swung
    the other way.
    I still say it's camber (especially on dirt roads) though.
    - soakes
    Stephen Oakes, Jan 10, 2011
  3. F Murtz
    Marty H Guest
    I still say its mind over matter
    mh
    Marty H, Jan 10, 2011
  4. F Murtz
    G-S Guest
    The only place I really 'hurry along' is at track days and the camber of
    the race tracks I ride is such that it's a constant whether I'm turning
    to the left or the right.
    That is to say the tracks are actually slightly banked to help travel
    through the corners rather than cambered.
    I don't travel fast enough on the road to notice a preference for
    direction of cornering only on the track does the issue arise.
    G-S
    G-S, Jan 10, 2011
  5. Used to be a rider in Melbourne years ago called "Hook" of all things, who
    had all controls on one side
    George W Frost, Jan 10, 2011
  6. All that given Geoff, but mainly, the topic was about road conditions, not
    track work
    I only mentioned a track because they are designed for faster travel around
    bends and the design is banked or cambered, whichever terminology you wish
    to use
  7. F Murtz
    Marty H Guest
    IMHO banking and cambered are too different things
    banking is where the road surface starts down low on the inside of the
    bend and increases upwards to the outside of the bend
    Camber is where the centre of the road is the highest point and the
    road surface decreases down to both sides of the road.
    therefore on a banked turn, it doesn't matter which way you travel,
    both the left and the right turns will be aided by the banking
    in a cambered turn, in one direction you will be aided from the
    positive camber, in the the other you will hindered by the negative
    camber
    I could be wrong, but I think its makes a big difference in this
    subject
    MH
    Marty H, Jan 11, 2011
  8. F Murtz
    atec77 Guest
    Local Harley rider has a left appendage which locks onto the handlebars
    clutch is right handed and he does perfectly fine although when he
    does a release and then clips the h00k on it gets looks
    atec77, Jan 11, 2011
  9. F Murtz
    Yeebok Guest
    Thinking about when I rode a pushie, I was unable to do a powerslide
    (put inside foot down, use it as anchor, flick back wheel out, spray
    people with dirt) or whatever you wanted to call it right handed but
    left handed is no problem.
    I suspect it's a combination of factors, such as the throttle (I think
    it may be at most minor) and oncoming traffic (bit more than minor) but
    as another issue, roundabouts are all right handers, I have no dramas
    with them - will happily lean over far enough to scrape my boots on a
    roundabout but give me the same thing on a normal corner and I am not as
    comfy as the roundabout. Most left handers I will scrape the boot happily.
    Yeebok, Jan 11, 2011
  10. F Murtz
    atec77 Guest
    On a flat track I scrap both equally , road camber does have a lot of
    effect though (no chicken strips but)
  11. I must be wierd because I prefer turning right. Might be because our local
    racetrack has 7 rights and only one left.
    Fraser
    Fraser Johnston, Jan 11, 2011
  12. I've seen two levers like that on stunt bikes. One for the rear brake. But
    never a clutch. Guess you learn something new ever day. Good on the one
    armed owner for still riding. : )
    Fraser
  13. F Murtz
    Theo Bekkers Guest
    That's a good point. I always felt more comfortable on my pushie turning
    left as well. No throttle hand there.
    What about you Zebee?
    Theo Bekkers, Jan 11, 2011
  14. F Murtz
    Theo Bekkers Guest
    How do you get back to the start? Most tracks have 4 more rights than lefts
    or vice versa.
    Theo
  15. Google earth barbagello raceway. Surely you've done a track day there Theo?
    Fraser
  16. F Murtz
    Nev.. Guest
    I think what you have described as camber is actually the crowning of
    the road surface and the camber is dependant on the lean angle of the
    bike and the slope of the road surface - negative or positive camber.
    Nev..
    Nev.., Jan 11, 2011
  17. F Murtz
    Nev.. Guest
    ...and no bad arm. Rego plate was ARM-001
    He had a prosthetic which he strapped to his right shoulder which
    clipped on to the right bar.
    Nev..
    Nev.., Jan 11, 2011
  18. F Murtz
    Nev.. Guest
    7 slight right bends and a very left hand bend will do it. Draw an "L"
    then connect the top of the L to the bottom of the L heading clockwise
    from the bottom of the L to the top.
    Phillip Island only has 2 more lefts than rights but some of the 'turns'
    (T5 and T7) are barely more than a few degrees realignment of the road
    and others (T2) are greater than 180°. Not all turns are created equal
    it seems.
    Nev..
    Nev.., Jan 11, 2011
  19. F Murtz
    G-S Guest
    If that's the case (and I'm not saying it's not) then what I said was
    referring to the 'crowning' / 'banking' difference between road and
    track and not the 'camber', but given those terminology changes I still
    think what I said applies.
    G-S
    G-S, Jan 11, 2011
  20. Nope, camber is as per that description. What most people refer to as
    camber is banking. A road surface can have both camber and banking.
    The vernacular has replaced banking with camber but is technically
    incorrect.
    Think of wing camber on an aircraft. It is what creates lift. The
    upper surface has a raised profile in the middle compared to the lower
    surface. The pressure difference as the air flows over the upper
    surface and has to go faster gives lift under the lower surface
    </physics lesson>
    Camber is used on roads to clear water. Banking is used to keep
    g-forces vertical rather than lateral.
    Kevin Gleeson, Jan 12, 2011
