LEDs are the way forward.
Discussion in 'UK Motorcycles' started by Sir.Tony, Jan 23, 2005.
  1. Sir.Tony
    Sir.Tony Guest
    LED's are more reliable, they look better & they will probably last longer
    than the bike.
    What will be a good idea are replacement high brightness LED's that can fit
    in conventional light bulb sockets.
  2. Sir.Tony
    JackH Guest
    Especially if the light in question, is one that lights up the interior of a
    car, eh...
    JackH, Jan 23, 2005
  3. Sir.Tony
    Hairy Arse Guest
    Ermmm.. they've been around for a good few years now....
    i've got a few on my motorhome.. replaced the side marker bulbs, indicator
    bulbs and tail lights with led bulbs.. just remove the tugsten bulb, replace
    with the led cluster bulb.
    They're pretty expensive for what they are tho.. so i bought 50 or so
    12000mcd (fucking bright) white led's from the states a year ago,
    now when i want to replace a tugsten bulb with led's, i smash the glass
    envelope off the bulb, de-solder the tugsten fillaments wires, make up an
    led cluster.. adding the correct resistors for the amount of led's i'm
    putting in it depending if they're in series, and/or paralell, solder the
    feed wires to the bulb's base, and a splodge of silicone sealant to hold
    them in place in the bulbd base,
    job done, one led bulb replacement for 5 minutes of my time, and about 40p
    per led i use in it.
    Hairy Arse, Jan 23, 2005
  4. Sir.Tony
    Catman Guest
    Like the ones you can already buy, you mean?
    www.cuore-sportivo.co.uk
    Catman, Jan 23, 2005
  5. Sir.Tony
    wessie, Jan 23, 2005
  6. Sir.Tony
    Dave Emerson Guest
    Does this work for indicators?
    IIRK most flasher units depend on the current draw from the tungsten bulbs
    to operate the machanism.
    Hence they don't flash if a bulb blows or go manic if a bulb shorts.
    Dave Emerson, Jan 23, 2005
  7. Sir.Tony
    Dave Emerson was seen penning the following ode to ... whatever:
    You can stick an additional resistor in to calm them down again.
    Timo Geusch, Jan 23, 2005
  8. Sir.Tony
    Or a 21W bulb in circuit but concealed inside bodywork for the
    non-electronicisti among us.
    Pip, Jan 23, 2005
  9. Sir.Tony
    Pip emerged from their own little world to say
    The ready made LED arrays have a similar power rating to conventional
    filament bulbs. E.g. http://www.lightlens.com/coloredbulbs.htm
  10. Sir.Tony
    Richard Wood Guest
    Defeating the point a bit innit?
    frag
    Richard Wood, Jan 23, 2005
  11. Sir.Tony
    rb Guest
    wessie wrote:
    I'm not sure but I suspect they mean equivilant power i.e. you would
    get the same amount of light from that wattage of tungsten filament
    lamp. An LED array of that size is not going to draw 2.25A unless they
    have already added a low value resistor in parallel to the LEDs.
    I'm surprised nobody makes after market flasher units designed to work
    with LED arrays yet.
    rb, Jan 23, 2005
  12. He's living the dream... On the road to nowhere.
    Simon Atkinson, Jan 23, 2005
  13. Sir.Tony
    Dave Emerson Guest
    We were making "solid state" replacement units 25 years ago with 555 timer
    chips. An interesting exercise but they were ten times the cost of the
    hardware originals.
  14. Sir.Tony
    rb Guest
    <sad anorak mode>
    I think the original design was an amazing piece of ingenuity. A
    bi-metallic strip warms up due to the current flowing through it. As it
    bends the circuit breaks and the lamps go out. So it cools and makes
    the circuit again, repeat. If a lamp blows then you draw less current
    so it flashes slower, if one shorts it flashes in manic mode. The dash
    indicator lamp shows that all exterior the lamps are operating
    correctly.
    Army landrovers had a slight variaton. The flasher had a second
    bi-metallic strip which only warmed up enough to actually operate when
    there was a trailer attached (more current drawn). This switched a
    second dash indicator lamp to remind the squaddy behind the wheel that
    he was towing something.
    I now work for a large semiconductor manufacturer but I can see that
    you can't beat old fashioned common sense like that.
    <gets coat>
    rb, Jan 23, 2005
  15. Sir.Tony
    rb Guest
    This post was sponsored by Chorley FM.
    rb, Jan 23, 2005
  16. Coming in your ears.
  17. Sir.Tony
    rb emerged from their own little world to say
    Many vehicles have current draw sensors to tell the driver/rider that a
    bulb is blown. Ergo, a manufacturer of LED arrays marketed as direct
    replacements for bulbs would get a lot of returns if their product did
    not mimic the characteristics of the OE.
    These products are marketed as long life rather than reduced power
    consumption aren't they?
  18. Sir.Tony
    rb Guest
    Maybe they do, I've not tried any, it just seems rather wasteful some
    how.
    What about all these people with 21W lamps under their seats then? Did
    they just buy the wrong type?
    I didn't think LED buyers needed reasons.
    rb, Jan 23, 2005
  19. Sir.Tony
    A friend of mine had a Huntmaster outfit with home made indicators. They
    comprised of a motor, a resistor and some copper contacts. Basically the
    motor slowly turned a vane which bridged two contacts causing the lamps
    to flash. It never really worked well and would cause the bike lights to
    dim.
    It was the product of somebody's shed circa 1960...
    sweller, Jan 23, 2005
  20. It was somewhere around Barstow, on the edge of the desert, when the
    The Russians put men in space using similar tech.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 23, 2005
