LED blinkers
Discussion in 'Australian Motorcycles' started by John Littler, Jun 27, 2005.
  1. John Littler
    conradvr Guest
    Bah! DSE is for the tryhard nerds - you need to use a decent
    electronics supplier like Jaycar or Altronics. Haven't seen many
    resistors rated over 10W off-the-shelf, instead connect 3 x 10W 22ohm
    resistors in parallel, gives a 7.3ohm 30W resistor (cost $4.50).
    Cheers
    Conrad
    conradvr, Jun 28, 2005
  2. Bah! DSE is for the tryhard nerds -
    but!!...you can go right down there and get a wire wound resistor no?
    on saturday morning even!
    fulliautomatix, Jun 28, 2005
  3. John Littler
    moike Guest
    Just like at Jaycar!
    Moike
    moike, Jun 28, 2005
  4. John Littler
    alx Guest
    I think the timeclock is ticking over and $120 sounds a bargain LOL.
    etc etcte etc.
    alx, Jun 28, 2005
  5. John Littler
    alx Guest
    JL... make sure they're "legal"...wouldnt want to cop a fine and be defected
    off the road for 6 months now would you..... again...
    alx, Jun 28, 2005
  6. John Littler
    G-S Guest
    Or you could just get some resistive wire, work out the required length
    and allow for the heat disapated and wind it onto a heat resistent form,
    probably with a small heat sink.
    G-S
    G-S, Jun 28, 2005
  7. John Littler
    sstrik Guest
    Most people forget that electrical items run on smoke. Hence the
    massive burning of coal down in Gippsland to fill the wires with <vbg>.
    Steve
    sstrik, Jun 28, 2005
  8. John Littler
    Theo Bekkers Guest
    Or you can go down to Woolies and buy one off the shelf for $12.
    Theo
    Theo Bekkers, Jun 29, 2005
  9. Or you could just get some resistive wire, work out the required length
    [/QUOTE]
    And voila! The blinkers now flash at the right speed _and_ you've got
    heated handgrips!
    big
    Iain Chalmers, Jun 29, 2005
  10. John Littler
    conradvr Guest
    heated handgrips!
    big[/QUOTE]
    At Jaycar- might get a little chilly on long straight roads
    Nichrome Resistance Wire - 4 metre pack $1.80
    Used for wiring heating elements etc. 80% nickel, 20% chromium. -
    Resistance 13.77 ohm per metre.- Size 28 B&S
    Conrad
    conradvr, Jun 29, 2005
  11. There's a pdf floating around (I _think_ I got it from Sharkeys zoic.org
    website) about DIY heated grips using that stuff...
    big
  12. John Littler
    conradvr Guest
    I have seen that article. I'm considering doing before heading down to
    the MotoGP this year.
    Conrad
  13. John Littler
    conradvr Guest
    I have seen that article. I'm considering doing it before heading down
    to the MotoGP this year.
    Conrad
  14. John Littler
    jlittler Guest
    Yeah thanks for reminding me Al, but the EPA isn't involved so we can't
    get into a situation where there is no way of making it legal /
    clearing the "defect" again
    JL
    jlittler, Jun 29, 2005
  15. John Littler
    jlittler Guest
    heated handgrips![/QUOTE]
    <impressed>
    All hail the bodge king !! (aka "bush mechanic")
    JL
  16. John Littler
    jlittler Guest
    Hehe Burnie will be unsurprised to hear I've got plenty of time, it's
    in for warranty repairs at the moment...and the fitting of a Power
    Commander.
    JL
    (same issue,leaking base gasket, the ausmoto Cagiva owners club will be
    unsurprised to hear the gasket didn't arrive on the promised date and
    that it took 6 weeks for it to come in. Boxer, you want to poke your
    mate Feeney in the ribs and tell him his company's warranty repairs
    service sucks ?)
  17. John Littler
    jlittler Guest
    Woolworths supermarket or Big W ? I don't recall my local supermarket
    stocking blinker cans.
    JL
    (looked at them closely last night, there's actually 14 Leds on the
    board, and a couple of resistors can be seen, so I'm going to try
    plugging them straight in and see what happens)
  18. City boi!
    You mean you haven't even tried?
    Hammo
    Hamish Alker-Jones, Jun 29, 2005
  19. Mark Donoghoe, Jun 29, 2005
  20. John Littler
    John Littler Guest
    Hmmm, thanks, will have to check it out.
    JL
    John Littler, Jun 29, 2005
