Leaving bikes standing unused
Discussion in 'UK Motorcycles' started by SimonM, Jul 31, 2007.
  1. SimonM
    Catman Guest
    I'd like to think that it *does* go off, but I have two cars in store
    that we go and start about once every 8 weeks or so. Neither of them
    show any problems with the fuel that's been in there over two years now.
    Yes it takes time to fill the carbs / FI system, but when they fire,
    away they go.
    On balance I would have to say that it doesn't.
    Actually thinking back, when I put the 116 back on the road it had been
    stored for about 4 years. Ran fine on that fuel as well.....
    116 Giulietta 3.0l Sprint 1.7 156 TS 166 V6 2.5 145 2.0 Cloverleaf
    www.cuore-sportivo.co.uk
    Catman, Aug 1, 2007
  2. SimonM
    ooooooOOOOOOooooh. Who rattled your cage?
    _______
    Ace, Aug 1, 2007
  3. SimonM
    Krusty, Aug 1, 2007
  4. I'll shout that at my petrol next time it goes off then.
    "YOU MYTHICAL ****!"
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Aug 1, 2007
  5. I'll shout that at my petrol next time it goes off then.
    GS850x2 XS650 SE6a
  6. SimonM
    While you're about it you can send a sample for analysis to try and
    explain exactly what's "gone off" about it. Thing is, petrol is a
    pretty homogenous mix, so this idea that there are large parts of it
    significantly more volatile than others has no grounding in chemistry.
    _______
    Ace, Aug 1, 2007
  7. In my experience (and those of plenty others) it definitely happens.
    Some engines are far more tolerant of fuel quality and would probably
    start on barbeque sauce, but some will just not start on fuel that's
    more than a few months old.
    Ergo; a change has taken place. Whether it's caused by volatiles leaving
    or another chemical change is immaterial - it's happened, and as I said,
    modern fuel seems to be just as prone to it if not more so than the
    older stuff.
    This chemical s-inlaw; she a fuel technologist?
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Aug 2, 2007
  8. SimonM
    And plenty of condensation in the exhaust, don't forget that.
    I'm actually rather suspicious of cars (and bikes) that have been
    sitting idle and started regularly - IME it doesn't do them any good.
    Cranking it from time to time, OK (to circulate some oil) but not
    starting it up.
    I used to have a Rover P6 that was very low mileage and that had been
    run regularly - a lot of the things that needed fixing were from the
    car standing around.
    None I'm aware of.
    Timo Geusch, Aug 2, 2007
  9. SimonM
    Catman Guest
    We get them up to full temperature.
    Probably not one that I could give soundly. I don't think you'll find
    too much oil actually dries up off the engine parts, but it can go a bit
    manky IME. I just like to keep my non-scientific demons at bay that the
    oils is being spread about a bit. Maybe it does nothing, but I also
    like to check they've not been nicked, burned out and I love the sound
    (Alfa engines in a large, echoey barn) ;)
    Catman, Aug 2, 2007
  10. SimonM
    Catman Guest
    Get them right up to temp. The end cans get well dried out (at lest I
    *think* they do)
    You may well have a point there. Neither of them are likely to ever
    come up for sale a they are the restoration jobs, so I'm not worried
    about anyone being suspicious.
    I bow to your greater expertise, but I still like the sound :)
    Catman, Aug 2, 2007
  11. I start the 400 Four a few times over winter, but I set the tickover to
    around 2k revs and let it run for at least 20 minutes, in order to get
    everything good and hot.
    That avoids the condensation problem. The real reason is to feed fresh
    fuel into the carbs from the tank.
    Before I shut it down, I turn off the fuel and run it till the carbs are
    utterly dry.
    The Older Gentleman, Aug 2, 2007
  12. SimonM
    dog Guest
    shout it several times to make sure.
    dog, Aug 2, 2007
  13. SimonM
    Catman Guest
    Twice should be sufficient.
    Catman, Aug 2, 2007
  14. SimonM
    I do that occasionlly too.
    A couple of years back, I was running the bike and one of my
    neigbours[1] came round to complain that the fumes were going into her
    back garden.
    I pointed directly across the road, to where a double decker bus was
    sat at the bus-stop idling away and asked if she wanted me to get all
    the buses to switch of there engines too.
    Some people have got nothing better to do than have a good moan.
    [1] Retirement age woman.
    CT, Aug 2, 2007
  15. SimonM
    SimonM Guest
    Checked this last night. No foreign objects in the airbox though the
    filter element was fairly clogged with dust. I gave it a blast with
    compressed air and bunged it back in. Came back inside for a beer and
    read the service manual, it says "Caution: Do not blow the air cleaner
    element with compressed air". Oh, OK then.
    Winter appears to have set in again here, but if it dries up later
    I'll go for a run to see what's what.
    SimonM, Aug 2, 2007
