Leather Jackets and Leather Seat care and preservation
Discussion in 'Motorbike Technical Discussion' started by Steve S., Jan 8, 2004.
  1. Steve S.
    Steve S. Guest
    Our Company Liquiguard Technologies Inc. is an innovator of new and
    unique protective coatings for use on everyday objects and specialized
    applications. Commonly available coatings have a basic polymer
    composition. Liquiguard Technologies coatings are complex formulations
    that will meet and exceed the requirements of the job at hand. Most of
    our coatings are water based, eco friendly and present no health
    hazards. They are clear, non-odorous and contain additives that
    discourage the growth of mold, mildew and other fungi. They contain
    inhibitors to prevent damage caused by invisible but harmful
    ultraviolet rays. Liquiguard Technologies development focus is to
    create application specific coatings that are the best in class.
    Coatings developed by us in our laboratories utilize the latest
    innovations in polymer
    technology. Our formulations focus on specific groups of materials and
    objects that need to be protected from hazards encountered during
    every day use. We pride ourselves on developing solutions that are
    truly effective and long lasting we have developed a very special
    product by the name of Leatherguard.
    Leatherguard is a clear coating designed to protect and enhance the
    longevity of all natural leather products including handbags, shoes,
    jackets, gloves, etc. however Leatherguard is also the perfect way to
    protect your car interior in addition to the typical areas such as
    front and rear seats, Leatherguard is great for leather wrapped
    steering wheels and gearshifts. It is totally non-staining and will
    not affect the color or appearance of the coated object. When applied
    correctly Leatherguard will extend the useful life of leather goods by
    enhancing their suppleness and resistance to scratching and scuffing
    thus keeping the coated articles looking like new. The high
    flexibility and adhesion inherent in this coating prevents it from
    cracking or peeling during normal use. Leatherguard also prevents soil
    and dirt from sticking to it, unlike existing Silicon based
    treatments.
    Formulated from a blend of complex and innovative new resins,
    Leatherguard is a water based, odorless, non-yellowing and
    non-polluting coating unlike any other available in the market today.
    More than a moisture repellant it is the first truly protective
    coating that can withstand spills of water, beverages, wine and other
    non-corrosive liquids while keeping the coated objects free from mold,
    mildew and other fungi. Leatherguard contains unique ultraviolet
    inhibitors that will protect the leather from damage caused by
    exposure to sunlight, thus extending the life of the leather articles.
    If needed, coated articles can also be wiped down with warm water and
    mild detergents.
    Leatherguard can be sprayed or brushed on to the art objects quickly
    and easily and will become tack free in 20 to 30 minutes at an ambient
    temperature of 77°F. To achieve optimal results, however, a drying
    time of approximately 72 hours is recommended. The fully dried
    Leatherguard film is highly durable and will stay in place and
    continue to provide optimal protection until physically removed or
    rubbed off.
    To ensure that your leather article is fully protected, Leatherguard
    contains a special "tracer dye" that glows when exposed to ultraviolet
    light. Missing or inadequate amount of Leatherguard can be easily
    detected by the absence of the telltale glow when the coated article
    is exposed to a UV source. If too little Leatherguard has been
    applied, simply apply another coating to correct the problem.
    Leatherguard is 100% water based and is available in aerosol cans,
    quart, gallon and five gallon containers. Aerosol cans contain solvent
    based propellants. Larger packing sizes contain concentrates which
    must be diluted with tap water. The recommended dilution is 2 or 3
    parts of water to 1 part of concentrate.
    To remove Leatherguard coating from treated surfaces, use warm water
    and mild detergents or isopropyl alcohol. Do not use corrosive
    cleaners or strong solvents.
    Leatherguard is non-toxic and environmentally safe.
    PRODUCT USAGE INFO
    1. Surface to be laminated must be free of dirt, oil, grease and other
    loose debris.
    2. Damp or wet objects should be thoroughly dried before coating.
    3. Make sure that Leatherguard and ambient temperature are at 50° F or
    higher.
    4. Shake the aerosol can well before and frequently during use.
    5. Hold the can upright and about 12 inches away from the surface to
    be sprayed.
    6. Spray from all four sides of the object to be coated to ensure
    complete coverage. This constitutes one coating cycle.
    7. Porous surfaces may require more than one coating cycle for optimal
    protection.
    8. Each coating must be partially dry prior to application of
    additional coatings.
    9. For maximum protection coat all exposed surfaces.
    CAUTION: Propellants within the aerosol contain volatile solvents that
    can ignite easily. Keep away from open flame sparks or heat. Prolonged
    exposure to sunlight may expand the pressurized solvents and the can
    could explode. Do not puncture or incinerate. Do not store at
    temperatures above 120ºF. Vapor harmful. Use with adequate
    ventilation. Avoid contact with eyes and skin and prolonged exposure
    to vapors. If swallowed do not induce vomiting. Seek immediate medical
    attention.
    LEGAL INFO
    LIQUIGUARD TECHNOLOGIES, INC. WARRANTIES THAT A PROPERLY COATED OBJECT
    WILL NOT SUFFER DAMAGE FROM HUMIDITY, MOISTURE, LIMITED EXPOSURE TO
    NON-CORROSIVE LIQUIDS AND ULTRAVIOLET RAYS. USER IS SOLELY RESPONSIBLE
    FOR DETERMINING SUITABILITY FOR IN ENDED USE AND ASSUMES ALL RISKS IN
    CONNECTION THEREWITH OTHER THAN AS WARRANTED HEREIN. WARRANTY EXTENDS
    TO ORIGINAL PURCHASER AND MAY NOT BE ASSIGNED OR TRANSFERRED. WARRANTY
    DOES NOT APPLY TO COATED OBJECT THAT HAS BEEN REWORKED, PHYSICALLY
    DAMAGED OR ABUSED AND PROVIDES NO LIABILITY FOR ANY INCIDENTAL OR
    CONSEQUENTIAL LOSS OR DAMAGE TO COATED OBJECTS. THIS LIMITED WARRANTY
    IS IN LIEU OF ALL OTHER EXPRESS OR IMPLIED WARRANTIES INCLUDING
    MERCHANTABILITY, FITNESS FOR USE OR FOR A PARTICULAR PURPOSE.
    This article is for information purposes only and is not intended to
    solicit or sell anything for more information please visit our website
    at http://www.Liquiguard.com or email:
  2. Steve S.
    Ed Guest
    No way you're gonna sell that here - if we can't agree on our HDs, Hondas,
    Aprilias, Yamahas et al, we do agree only Brylcreem is the ticket for our
    leathers. Apply liberally to hair, allow to run onto jacket and chaps or
    race skins, and then swirl in with hand until absorbed.
    Dun be advertising here, dude.
    Ed, Jan 8, 2004
