Learning abut guilt
Discussion in 'UK Motorcycles' started by TOG, Mar 3, 2006.
  1. In uk.rec.motorcycles, Dave Jennings belched forth and ejected the
    following:
    I told a similar lie regarding my guinea pig and a Scalextric set :)
    Whinging Courier, Mar 4, 2006
  2. Quality. Has anyone put a hamster into a radio-controlled boat? Or
    better still, one of those model rockets?
    The Older Gentleman, Mar 4, 2006
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Rope
    Ross give you lift, did he?
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Mar 4, 2006
  4. <vvvbg>
    you're a bad man.
    it's why I/we like you.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Mar 4, 2006
  5. LOL. You bad man.
  6. <fx: nostalgia>
    One of the funniest threads I remember on UKRM was about getting a
    worming tablet into a cat...
    (For those who don't remember, the 'final solution' was to feed the
    pill to the hamster first! <VBG>)
    Chris D
    Chris N Deuchar, Mar 6, 2006
  7. TOG
    Dan White Guest
    I think this one was courtesy of Windy:
    HOW TO GIVE YOUR CAT A PILL
    01. Pick the cat up and cradle in the crook of your left arm as if holding a
    baby. Position right forefinger and thumb on either side of cat's mouth and
    gently apply pressure to cheeks while holding pill in right hand. As cat
    opens mouth pop pill into it, allow cat to close mouth and swallow.
    02. Retrieve pill from floor and cat from behind the sofa and repeat
    process.
    03. Retrieve cat from bedroom and throw soggy pill away.
    04. Take new pill from foil wrapper. Cradle cat in left arm, holding rear
    paws tightly with left hand. Force jaws open and push pill to back of mouth
    with right forefinger. Hold mouth shut for a count of ten.
    05. Retrieve pill from goldfish bowl and cat from top of wardrobe. Call
    partner in from garden.
    06. Kneel on floor with cat wedged firmly between knees, hold front and rear
    paws. Ignore low growls emitted by cat. Get partner to hold head firmly with
    one hand while forcing wooden ruler into mouth. Drop pill down ruler. Rub
    cat's throat vigorously.
    07. Retrieve cat from curtain rail, get another pill from foil wrapper. Make
    note to buy new ruler and repair curtains. Carefully sweep 'Doulton' figures
    from hearth and set aside for gluing later.
    08. Wrap cat in large towel and get partner to lay on cat with cat's head
    just visible from below partner's armpit. Put pill in end of drinking straw,
    force cat's mouth open with a pencil and blow down drinking straw.
    09. Check label to make sure pill is not harmful to humans, drink glass of
    water to take taste away. Apply plaster to partner's armpit and remove blood
    from carpet with cold water and soap.
    10. Retrieve cat from neighbour's shed and get another pill. Place cat in
    cupboard and close door onto neck to leave head showing. Force mouth open
    with dessert spoon and flick pill down throat with elastic band.
    11. Fetch screwdriver from garage and put door back on hinges. Apply cold
    compress to cheek and check records for date of last tetanus jab. Throw
    t-shirt away and fetch new one from bedroom.
    12. Ring for fire brigade to retrieve cat from tree across the road and
    apologise to neighbour who crashed into fence while swerving to avoid cat.
    Take last pill from foil wrap.
    13. Tie cat's front and back paws together with garden twine and bind
    tightly to leg of dining table. Find heavy duty pruning gloves from garden
    shed and pry cat's mouth open with a small spanner. Push pill into mouth
    followed by a large piece of fillet steak. Hold head vertically and pour
    pint of water down throat to wash down pill.
    14., Get partner to drive you to A & E and sit quietly while the doctors
    stitch fingers and forearms and removes pill remnants from right eye. Call
    in furniture shop on way home to order a new table.
    15, Arrange for local animal welfare society to collect cat and ring local
    pet shop to see if they have any hamsters.
    HOW TO GIVE YOUR DOG A PILL
    1. Wrap pill in bacon.
    Dan White, Mar 6, 2006
  8. TOG
    marina Guest
    Coo ta Dan - I thought I'd saved it and I hadn't. Have now.
    Marina Mayes - Reading, UK. To email me remove XX from my address
    SR250 - on the road again. BOTAFOT12, BOD#2, BOTAFOS#2
    KotLBOD#s, KotLBOTAFOS#s,IMC#2, Tart#10-19, SR#3
    I never give in to fear or blackmail; I always give in to temptation.
    "You're a national treasure" - porl, 18.1.03
    marina, Mar 6, 2006
  9. You're probably right - but the hamster bit was in one of the
    followups... ...prolly bear or similar...
    <fx: gazes into mid distance with happy smile>
    Chris D
    Chris N Deuchar, Mar 7, 2006
