Learning abut guilt
Discussion in 'UK Motorcycles' started by TOG, Mar 3, 2006.
  1. TOG
    TOG Guest
    A colleague here at work has just confessed that, as a nine year-old,
    he was responsible for the untimely death of his hamster.
    We wondered if his Action Man parachute would work on the hamster, and
    so sort of strapped it in, and lobbed it out of his bedroom window.
    And.....
    Not what you're thinking. The parachute worked perfectly. The
    bewildered rodent floated down gently. Right into the waiting paws of
    the family cat that happened to be underneath.
    "I've never run down stairs so fast, but I was too late."
    He told his ma that the hamster had escaped from its cage. No idea how
    he explained the parachute.
    I'm going to be giggling about this all day.
    TOG, Mar 3, 2006
  2. TOG
    Dan White Guest
    <TOG@toil>; <>; <>
    wrote in message
    Ironically he might not have needed it. Hamsters have a very low terminal
    velocity die to the surface area/weight ratio. Could have given Hammy time
    to run away if he hadn't been strapped to a parachute...
    Dan White, Mar 3, 2006
  3. TOG
    JB Guest
    <TOG@toil>; <>; <>
    wrote in message
    Excellent.
    Reminds me of a comical tale (urban legend most likely) told to me by an old
    girlfriend. Two lads out hiking in Wales come across an a deep hole in the
    ground. A very deep hole. Just how deep, they try to ascertain. They proceed
    to lob into the hole, rocks and stones, listening for the sound of them
    hitiing the bottom. No joy. "Must be very deep" says one. "We need something
    heavier to chuck down the hole so we can hear it hit the bottom". They spy a
    large lump of wood like an old railway sleeper and between them lob it into
    the hole. As it goes into the hole they notice a piece of rope tied to it
    also disappearing down the hole........followed by a goat dragged back up
    the hill from where it was grazing happily. goat goes into hole with much
    commotion. Lads leg it guiltily.
    Like I said it is almost certainly a myth, but it had me chuckling for a
    while.
    JB
    JB, Mar 3, 2006
  4. TOG
    BGN Guest
    Why would one attach a rope to a railway sleeper?
    BGN, Mar 3, 2006
  5. TOG
    Biffa @ Work Guest
    Wasn't that on R1 confessions (with Mayo ?) back in the mists of time....
    Biffa @ Work, Mar 3, 2006
  6. TOG
    Oddly enough, I've just come across that same tale in a book I'm
    reading "The Definitive Guide to Body Language". Makes a better joke
    if it reads: "then a goat came running along, fast as his legs could
    carry him, and jumped straight down into the hole. A few minutes later
    a farmer comes along asking if they've seen his goat, "yes", they said
    "it just ran along here at a great speed and jumped into this hole."
    "Can't have been my goat then", says the farmer, "he was securely
    chained to a railway sleeper."
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Mar 3, 2006
  7. TOG
    Authentic? I don't think so. It's just a joke, not even an urban
    legend, AFAIC
    True, true.
    _______
    Ace, Mar 3, 2006
  8. TOG
    IIRC, I first heard this joke on the Dave Allen show in the mid 70s,
    and it's probably older than that.
    darsy, Mar 3, 2006
  9. TOG
    Dave Guest
    To stop the goat attached to the other end fucking off ytc.
    Dave, Mar 3, 2006
  10. TOG
    BGN Guest
    Wouldn't it just eat through the rope?
    BGN, Mar 3, 2006
  11. TOG
    Dave Guest
    Not if the rope was reinforced with wire :p
    Dave, Mar 3, 2006
  12. TOG
    BGN Guest
    Hurty gums.
    BGN, Mar 3, 2006
  13. I used to tie goats by a length of rope (polypropylene, iirc) to old
    tyres to stop the fuckers leaping fences if they espied something more
    tasty in the next field.
    Didn't stop the stupid fucking things eating the Rhodedendrons, though.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Mar 3, 2006
  14. The message <>
    from "JB" <> contains these words:
    /well-done goat/
    Definitely an urban miff. Started out as a joke.
    With mohair whiskers.
    Rusty Hinge 2, Mar 3, 2006
  15. In case someone steals it.
  16. It is.
    It was around when I was a lad. (We couldn't afford a goat though, 'appen.)
  17. Would you chew Rope?
  18. We've been waiting for you, too.
  19. I'm sure Rope of this very parish will be along shortly for the answer!
    Dave Jennings, Mar 4, 2006
  20. It may or may not be true that my mate did or did not put his hamster
    into his old remote controlled aeroplane, and take it for a spin.
    Dives, rolls, everything.
    Bad landing, plane nose dives and ploughs the ground up. We ran over,
    open the canopy and there is Hammy, like a furry Douglas Bader albeit
    with 4 legs more.
    Remarkably tough these creatures. Unless you're a cat, in which case
    they're a snack.
