Leaking float chambers
Discussion in 'Classic Motorbikes' started by Guest, Aug 24, 2003.
  1. Guest
    Guest Guest
    I can't believe it's the August bank holiday, and all I've managed is a
    too-rushed hack up & down M5 M6 to Falkirk & back in the rain six weeks
    ago.
    Latest joy with the Boxer has been knackered diaphragms and complete
    carb re-builds (just when the weather's been nice - deep joy). I can
    only hope it hasn't knackered the exhaust ports too - it happened some
    way from home and I had to limp back 2-up at 50.
    Now the wretched thing is dripping from one float chamber. I know it's
    clean, flat and smooth around all the mating surfaces. I know it has a
    brand new cork gasket. I know I didn't swap the bowls over by mistake
    (they're handed anyway). I know I'm losing patience (and petrol).
    I've bent the float arms slightly, which seems to help a bit, but I
    don't want to overdo it and run lean/misfire when it's wide open.
    Anyone got a favourite bodge (apart from Araldite)?
    Regards,
    Simonm.
    Guest, Aug 24, 2003
  2. Guest
    SpamTrapSeeSig was seen penning the following ode to ... whatever:
    A fake pound coin to a half-eaten doughnut that you've got dirt in the
    petrol and/or worn float needles. Dripping from the float chamber on
    ShiteOldBoxers almost *never* is a problem of the mating surface,
    because the fuel level should get that high in the first place.
    Here's what you need to do:
    Order a set of new floats/needles/axles from Motobins or
    Motorworks. While you wait for them, remove the petrol taps and clean
    out the mesh filters in the tank. If you find red powdery residue or
    flaky stuff there, you need to clean out the tank and remove the old
    coating, because it's coming loose. Do whatever you need to do to the
    tank, then put the taps back on. Fit inline fuel filters.
    Replace floats, needles & float axles with the new items that should
    have arrived by now. Do set the float height according to the
    manual. While you've got the float needles out, clean out the seats
    with really nasty carb cleaner - if the tank coating is coming off,
    chances are that it's baked itself to the needle seats and will
    prevent them from shutting properly.
    Don't, that's not the problem.
    Don't bodge them either, that'll end up costing a lot of dosh.
    Timo Geusch, Aug 24, 2003
  3. Guest
    Timo Geusch was seen penning the following ode to ... whatever:
    Grrrr. ^^^^^^ shouldn't, of course.
  4. Guest
    The problem with the float isn't visible, but the styrofoam-type
    floats on these Bings have the nasty habit of getting heavier over
    time. The ones on my GS looked perfect, just ever so slightly
    discoloured. I bought new ones because I suspected a problem with the
    floats, and the new ones were noticeably lighter. Appearantly the
    float slowly soak up petrol, and the heavier they get the later they
    close.
    Also, the rubber tips on the float needles harden - again this isn't
    visible - and this badly affects their ability to seal.
    Don't I know that...
    Put it this way - if you don't you've potentially got *two* different
    types of crap coming off the insides of the tank. Can't be a good
    thing. I'd do the job properly if I'd have to.
    Forget about the needle seats - they hardly ever wear due to the
    rubber tips on the needles. *If* the seat is worn I'd say you got more
    overall wear in the carb than is good for it. I've *never* seen a worn
    needle seat on these, and I've seen a few very manky Bing carbs.
  5. Guest
    Yes, but only if you get it right - there's a danger of making the
    bike run to lean.
    TBH I haven't used Petseal - my comment was more on the general
    side. If you recoat the inside of the tank, not cleaning it properly
    out would probably be a bad idea, especially if you have to get the
    new stuff out as well...
    Timo Geusch, Aug 25, 2003
