Leaking '66 Triumph fork sliders
Discussion in 'Motorbike Technical Discussion' started by Wm. Chapman, Jul 19, 2005.
  1. Wm. Chapman
    Wm. Chapman Guest
    This is a '66 TR6 650. The right slider leaks really rapidly at the very
    bottom where the axle fits and the cap goes on. No visible cracks anywhere
    but haven't taken the front wheel and axle off yet. This is not a leak from
    the drain plug [stays dry] or from the seal/top of slider. Seems to be
    definitely coming from the axle and cap area. Never seen this one before.
    Any help or shared experiences greatly appreciated. Thanks and happy trails
    Billy Chapman
  2. Do old Triumphs have a damper rod with a damoper piston on the top that
    is bolted to the bottom of the slider?
    That's what holds damper rod forks together and keeps the front wheel
    from falling off with the sliders attached when a motorbike goes over a
    jump.
    If you have a loose damper rod bolt, it could leak as you described.
    A lot of non-damper rod forks back in those days were just held
    together by a snap ring above the oil seal an a good strong jerk of the
    steel stanchion tube would pull everything, including the fork bushing
    out of the slider.
    krusty kritter, Jul 19, 2005
