Leading link forks, advice needed
Discussion in 'Classic Motorbikes' started by deadmail, Apr 13, 2008.
  1. deadmail
    Dave Emerson Guest
    A 3rd wheel and still needs crashbars on the heads!
    Dave Emerson, Apr 13, 2008
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Dave Emerson
    ITYM "even more".
    cf Sweller.
    Wicked Uncle Nigel, Apr 13, 2008
  3. deadmail
    deadmail Guest
    I'm pretty sure it'll get to the fitting a sidecar to the bike I haven't
    yet collected stage. Whether the links get fitted will depend on two
    things:
    a) How bad the telescopic forks are on the K100 when used with a
    sidecar.
    b) How much time I have free to fix it.
    However, it won't need to be fixed until the elefantentreffen in January
    next year so bags of time.
  4. deadmail
    deadmail Guest
    Only just seen this.
    Thanks.
    Here's the signature you can cut and paste into a disclaimer "X"
    The rest... will measure up what kind of size I need over the next week
    or so.
    deadmail, Apr 14, 2008
  5. deadmail
    Pete Fisher Guest
    Presumably the measuring you have already done showed that the distance
    between the tubes is OK?
    | Pete Fisher at Home: |
    Pete Fisher, Apr 14, 2008
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Righty-ho.
    I won't hold my breath, I'm still waiting for Champ to send me a fuel
    return so I can make a fitting for his turbot's tank.
    Wicked Uncle Nigel, Apr 14, 2008
  7. Piece of piss to get new yokes made. The rest, which largely consists of
    riding the thing while idly wondering if they're (yokes or front end)
    ever going to crack or let go catastrophically, is up to you.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Apr 14, 2008
  8. deadmail
    I haven't priced new yokes but at a guess I'd suspect upwards of £800
    wouldn't be far out. They're easy to get made if you hose money at
    someone but to make yourself they'd be a **** of a job.
    Rough machine billets to size
    Rough out bores
    Finish billets to size
    Finish machine bores
    Finish machine any slots
    Drill and tap as required
    Rough machine steering stem
    Heat treatment on steering stem
    Finish grind steering stem
    Assemble
    Piece of piss? Not if you do the job properly.
    Andy Bonwick, Apr 14, 2008
  9. deadmail
    Measure LL forks.
    Measure original yokes.
    If different, heat LL fork legs and dogleg to suit.
    And may I point out that BMW produced airhead boxers for a quarter of a
    century with a top yoke snipped out of a beer can?
    platypus, Apr 14, 2008
  10. deadmail
    deadmail Guest
    Well, it looks 'ok'. The measuring was done with a tape measure across
    the forks and by eye (by both myself and the bloke I bought them off).
    There's a lot of measuring to be done yet I'm sure.
  11. It's a tad heavier than typical beercan. Also, the weight carrying is done
    on the bottom yoke, the top one is mostly lateral location.
    Personally, I'd make flanged sleeves for the yokes out of steel, if it were
    mine, but only if I thought the thinner fork legs were up to it.
    If I were getting yokes made, I'd want someone who knows what they're doing
    on the job.
    Austin Shackles, Apr 15, 2008
  12. deadmail
    Cherman beer can, innit?
    That's hardly the ukrm way.
    platypus, Apr 15, 2008
  13. Which is largely what I was suggesting. Note, I didn't say, "Make a set
    of yokes yourself." Anyway, custom bike builders have been making
    replacement yokes for years, and several have a decent track record at
    it. Quite what the current prices are, I've no idea.
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Apr 15, 2008
