Leading link forks, advice needed
Discussion in 'Classic Motorbikes' started by deadmail, Apr 13, 2008.
  1. deadmail
    deadmail Guest
    Reposted due to fuckwit at keyboard...
    So, I've got a set of leading link forks from ebay.
    http://www.flickr.com/photos/8963323@N05/2409782962/
    They look to be about the right size to fit on the front of a K100
    (which I'm fitting a sidecar to).
    However... the fork tubes are 34mm whereas the K100s are 41mm. Speaking
    to the manufacturers they weren't really interested since every set are
    different and they'd recommend I had a new set built (at over a
    grand...)
    So I seem to have three[1] options:
    1. Make up two sleeves which runs between the yokes, OD 41mm, ID 34mm
    and with a slot in them so they squeeze the forks when squeezed by the
    yokes.
    2. Get someone to make replacement tubes to the same pattern but in 41mm
    tubing with the bottoms squished down to 34mm to fit in the 'swing arm'
    piece. Get new clamps for the 41mm forks top suspension mount.
    3. Get replacement yokes made to take 34mm forks
    Looking at my three options
    1. Seems to be the easy choice and probably not too difficult or
    expensive. But it seems like a bodge.
    2. Seems to be the most obvious way to approach it but...
    - Will the tube be weakened by squeezing it to an oval profile?
    - Any ideas where I could get this kind of fabrication done in the
    south-west?
    3. Seems to be relatively straightforward but again I've never had
    custom stuff like this made (but I suspect it just involves throwing
    money and a set of yokes at someone)
    What's the option least likely to result in me riding an outfit and th
    front end falling off?
    [1] Get some fucking sense and don't piss about with sidecars isn't the
    advice I'm looking for...
  2. deadmail
    A.Lee Guest
    My first thought was are the new ones going to be strong enough for a
    K100 and sidecar?
    There is a lot of weight there, add in rider and passenger, and you have
    probably double the forces on the front end compared to a solo bike with
    its larger diameter forks.
    Or maybe leading link forks are a better design to cop with the extra
    stresses invloved?
    Alan.
    A.Lee, Apr 13, 2008
  3. deadmail
    Either secure the sleeves with high strength retainer (Loctite 638 or
    similar) or have them made so you can shrink them on by using a bit of
    heat. I can work out the allowances for doing this but you need to get
    the sleeves machined by someone with a bit of a clue...
    I think you'd have more luck if you got someone to cut off the top
    part of the forks and weld on new 41mm items but you'd need to give
    them an old pair of yokes to use as a jig.
    It's that spending bit that's so wrong.
    3b. Ride it on standard forks.
    3b.
    Andy Bonwick, Apr 13, 2008
  4. deadmail
    deadmail Guest
    Well, 3b is the default and I have a horrible feeling that if 3b feels
    ok that neither 1, 2 or 3 will take place.
    BR
  5. deadmail
    Dave Emerson Guest
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160225448158
    "leading link front end ideal for trike what you see in the picture is what
    you get bought for project not needed know sow must go"
    There's a clue in the description.
    Who knows what world of pain these could lead to.
    Are the wheel bearings OK?
    What about the calliper?
    Is it compatible with your master cylinder?
    What pads does it take?
    What rating are the springs?
    What are the dampers set to?
    How much rake and trail would you get?
    What ride height?
    Can (will?) the manufacturer tell you what bike the setup was originally
    supplier for? Might give some clue regarding the weight.
    Nige it back on ebay and hope *someone* will give you more than the £160 you
    paid.
    Dave Emerson, Apr 13, 2008
  6. I'd assess the tubes. If the 34mm ones are significantly thicker wall than
    the 41mm ones, then they should be strong enough. However, they look like
    they're off an off-road outfit which is likely considerably lighter than a
    K-brick-plus-chair. If they seem strong enough, option 1 is the best bet;
    I'd get sleeves made with a flange, myself, so they have a flange under the
    yoke.
    If they aren't going to be suitable, then option 2 is better. Don't fancy
    option 3 at all, and besides, it offers no engineering advantage over option
    1.
    Option 1 is the easiest machining job.
    Austin Shackles, Apr 13, 2008
  7. deadmail
    deadmail Guest
    Yes... they were being sold by someone who planned to build a trike.
    He'd seen them advertised as that in BSH some time back.
    Can be replaced.
    I've seen them before, not sure.
    Am sure they can be rebuilt.
    Pads I'm sure I can identify.
    Compatible with master cylinder; details, details.
    "adequate I'm sure"; adjustable Konis
    Well, a visual inspection suggests the ride height would be similar; had
    them measured before I bought them.
    No. Completely unhelpful.
    No. Have a plan and insist on the opportunity to **** up properly.
    Thanks for all your help by the way; fwiw I'd considered most of the
    above questions, with the exception of the rake and trail. I'd also
    thought "where could I get replacement disks from"?
    I'd also considered/planned measuring up a set on a K100.
  8. deadmail
    Beav Guest
    Would it be a fucker to use a pair of yokes from another bike that uses 34mm
    stanchions? The steering stem won't be much different (I imagine) and
    spacing/sleeving for bearings is a damned sight less "dodgy" than a
    stanchion sleeve.
    Just a thought.
    Or a little bit of money at a bike breaker.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 13, 2008
  9. deadmail
    There are two reasons for converting to leading links - they're stronger and
    better able to take the side loads than those slidey telescopic things, and
    they're generally built with decreased trail to lighten the steering. I
    suspect that, despite the tubes being of a smaller diameter, the overall
    structure will be at least as strong as your conventional forks. You may
    have to consider a different handlebar setup whether you change forks or
    not.
    What I think you should do is:
    First, fit the chair, and see how it feels with the original forks.
    Then, if you think there's room for improvement, fit the LLs. Sleeve them
    up to fit the standard yokes. Take the plot out and rag **** out of it. If
    they're an improvement, and they don't break, game on. Sorted.
    If you don't like them, put the originals back on.
    platypus, Apr 13, 2008
  10. deadmail
    You're my role model.
  11. deadmail
    I feel soiled.
  12. deadmail
    Don't feel too bad about it.
  13. deadmail
    Pete Fisher Guest
    They look like Unit leading links almost identical to the ones I had on
    the Mille and RS3. Can't remember what diameter the tubes were on that.
    Not massive IIRC - Sweller might know. The Mille wasn't exactly light
    but not as lardy as a brick I suppose.
    I'm with Platy. Though if you can use Andy's demon precision methods to
    get a really tight fit for the 'shims'[1] do much the better.
    The only problem I can foresee is the amount of trail provides by the
    bend in the tubes IYSWIM. Though similar ride height suggests it may not
    be miles out. That presumably was set to suit the steering head angle of
    the bike they were built for.
    I have ridden an outfit with telescopic forks and LLs (though not the
    same bike). The one with telescopics (AJS 31CSR) was light by today's
    standards, but the LLs on the Mille were a relevation after them.
    If you can get them set up near enough and the shims don't allow things
    to start twisting I don't think you will want to go back to telescopics.
    [1] I think something a bit thicker and specifically engineered than a
    piece of beer can is called for.
    | Pete Fisher at Home: |
    Pete Fisher, Apr 13, 2008
  14. deadmail
    On Sun, 13 Apr 2008 19:00:32 +0100, Pete Fisher
    snip>
    I've emailed him on the anti-clique list with a couple of suggestions
    and I'm confident we can put something together that will do the job
    properly. It might involve him begging to Eaton Engineering but I'm
    sure the man in question would be able to hit the sizes if he had
    enough tries.
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    Sho 'nuff.
    Two or three hundred goes, no worries.
    I'll be wanting a full disclaimer signing, natch.
    Wicked Uncle Nigel, Apr 13, 2008
  16. deadmail
    That's "sizes", not "sides".
    Can we watch?
  17. deadmail
    deadmail Guest
    I think you may have the makings of a rudimentary plan. Probably with a
    'temporary fix' sleeve. And if it seems ok then something better.
  18. deadmail
    Item 130213680303 would seem to have potential as "something better".
  19. deadmail
    I like that. I wonder if he'd consider a swap for an old K100 and a
    Wessex sidecar?
  20. deadmail
    R N Robinson Guest
    If your supply of round tuits doesn't run out first. Which it will.
    Ron Robinson
    R N Robinson, Apr 13, 2008
