Lawnmower engines
Discussion in 'UK Motorcycles' started by Speedgazebo MOTP #1, May 8, 2011.
  1. Does anyone here have a mower with a 3.5 Biggs and Stratton engine
    with a carb arrangement like this?
    If so, can you take a look at the pictures I have uploaded so I can
    check that I have got these throttle springs in the right place ? It
    seems to be running very rich and hunting all over the place, one of
    the springs was disconnected and it kept stalling.
    http://www.flickr.com/photos/speedgazebo/5699943758/in/photostream
    Thanks
  2. Speedgazebo  MOTP #1
    Dan L Guest
    That looks the same as my old Briggs and Stratton engined mower. That
    developed a distinct hunting which couldn't be resolved so it now lives
    at the side of the shed. I got pissed off trying to sort it so bought a
    mountfield.
    Dan L, May 8, 2011
  3. Not what I wanted to hear, but sort of what I suspected might be the
    final outcome.
  4. <Disappears round the back of the shed for 5 minutes.>
    Nope, apparently not. I wonder when I threw that out?
    I recognise it though and in answer to your unasked question, they all do
    that sir.
    np.
    steve auvache, May 8, 2011
  5. Speedgazebo  MOTP #1
    Mike Barnard Guest
    I've just put a new spring in mine, and I photographed them before I
    took it apart to find the right place to return it. If I can find the
    pics I'll post them.
    The lighter spring is an 'idle' spring (not that I've ever had it
    idle) and the other one is the Govorner (spelling?) spring. It hooks
    up somewhere to the bottom right of your picture. I downloaded the
    parts list.
    I serviced my 2003 mower last week and it runs like new. No need to
    dump them.
    Mike Barnard, May 8, 2011
  6. Speedgazebo  MOTP #1
    Mike Barnard Guest
    http://www.flickr.com/photos/mikejanalex/5700115033/in/photostream
    Does this help? I know the top spring looks squashed up, but it runs
    perfectly like this.
  7. Mine does the same when you first start it up , after about 10
    minutes it runs fine
    Try cleaning the filter out , make sure the area around the blades
    are clean and the cowelings free of shit , any resistance will make
    them play up
    steve robinson, May 8, 2011
  8. Speedgazebo  MOTP #1
    Andy Hewitt Guest
    These apparently need the diaphragm replacing every couple of years.
    It's just the carb gaskets (but one is rubberised), and they're only a
    couple of quid on eBay. I did mine over the winter, and it runs fine.
    Also check the fuel is OK, stale fuel is also a symptom.
    Andy Hewitt, May 8, 2011
  9. Speedgazebo  MOTP #1
    Pete Fisher Guest
    In communiqué
    Different to the two I have at 'the chateau', but similarly equipped
    with springs all over the place. The lad managed to crock the Intek 60
    version in the pikey Handy-Power ride-on mower last trip, again [1]. The
    bugger won't rev up any more. TBF a totally blocked up air filter as a
    result of a displaced cut grass cowling probably didn't help. He didn't
    notice until smoke was rising from the cuttings accumulating where they
    shouldn't. That's easily sorted, but the indirect (for want of a better
    term) arrangement for opening the throttle butterfly seems to be fubar.
    All done by governors and springs like the one in your photo it seems. I
    jury-rigged it with a bit of bent fence wire, but once I fit a new
    filter I'm not sure it will be safe. It seemed to be over-revving a bit
    when testing on an open intake. Unfortunately I omitted to take a a note
    of the exact engine number and it seems there are at least three
    variants of spring according to this site:
    http://www.briggsbits.co.uk/
    [1] A couple of years ago he violently yanked the throttle wide open
    once too often and cracked air intake the cable was clamped too - still
    it is a great help that he enjoys buzzing round the place on it hacking
    down the grass.
    | Pete Fisher at Home: |
    Pete Fisher, May 8, 2011
