Laverda a-fettleing we go
Discussion in 'Classic Motorbikes' started by Timo Geusch, Aug 12, 2007.
  1. Timo Geusch
    Ho hum, barsteward Italian bikes...
    Anyway, pulled the plugs and unsurprisingly the bike was running
    *massively* rich on the lhs cylinder. RHS is slightly better but still
    far too rich. A quick peek into the lhs carb didn't show anything amiss
    (it's not like I don't know what a Dell'Orto looks like from the
    inside...) but no markings on the main jet so to be on the safe side
    I'll order a set of standard ones as a starting point. Surprisingly
    enough the O-ring on the choke/enricher jet (every Morinisti will know
    *exactly* what I'm talking about) doesn't seem to be too mangled but
    it'll get a new O-ring anyway.
    Next stop, the contact breakers. Mangled screws on the cover
    *ggrrrrrrr* necessitated the use of an impact driver but I did get the
    cover off eventually. Contacts do look rather well used so heeding
    Champ's mate Keef's advice, I'll chuck out the lot and will stick
    electronic ignition in there. Supposedly that'll make it run a lot
    nicer at low to medium revs as well. Oh, and breaker cam was of course
    bone dry, but that does without saying, no?
    And now for the fun part, otherwise known as getting the fucking air
    filter out. First, you have to remove the side panels. That's easy,
    although matey hard screwed them down *hard*. Then, remove the battery.
    Ah, that'll be a dry cell battery then. Hrmpf. The airfilter looks
    *very* original so no wonder the thing's been running rich - undo two
    nuts on the cover plate and pull it off. Bingo.
    Unfortunately the only part that pulled off was the cover plate;
    Removal of the air filter seems to necessitate removal of the battery
    carrier, which would be reasonably easy if the bolts that hold said
    carrier to the rear mudguard hadn't rusted nicely. Guess it's time to
    dig out some stainless steel replacements then. If I ever get them off,
    that is.
    Other bits that I've noticed so far - crankcase breather tube broken
    and "fixed" with electrical tape, no steering lock and some other
    little niggles. On the positive side it does look very much like the
    bike's been restored at one point in the past as I seriously doubt that
    even Laverda painted the frames this nicely. Oh, and the original
    colour was a rather fetching shade of dark metallic red - given the
    quality of the hyperfrog paintjob, I'm tempted to pay Beav a visit...
    Oh well, I guess my wallet needed emptying anyway...
  2. Timo Geusch
    I have a Lucas Rita on the Guzzi - fitted it over ten years ago and can't
    recall ever having to adjust it. It simply works.
    These people are now the manufacturers:
    Mistral Engineering
    Unit 12 Taylors
    Gravel Lane
    Chigwell, Essex
    England IG7 6DQ
    44 20 8501 2161 voice
    44 20 8501 2270 fax
    sweller, Aug 12, 2007
  3. I have a big tin of assorted stainless, that you're welcome to rob.
    The Older Gentleman, Aug 12, 2007
  4. Timo Geusch
    I've got a shoebox like that, but thanks for the offer anyway. Only had
    to get one bolt off, it turned out that the lug held on by the other
    one had vibrated off...
    Oh, and the airfilter I couldn't get out had been manufactured out of a
    car airfilter with the aid of a hot glue gun and a sharp knife. No, I'm
    not kidding...
  5. Timo Geusch
    ....and before doing that making sure the filters are clean, valve
    clearances and timing all set correctly?
  6. Timo Geusch
    Yes, I know that - problem is that the idle is so far off the mark it
    should be at and it's running so rich (it'll start pretty much without
    choke) that I need to get the basic settings sorted out first before I
    can even think of advanced stuff like plug chops.
    .... and that's where it falls down in the first place. Haven't checked
    the valves yet but already compiled a shopping list that does include
    and air filter.
    The air filter that was on the bike is actually quite spectacular...
  7. Timo Geusch
    Dan L Guest
    JPEG man, JPEG
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Aug 12, 2007
  8. Timo Geusch
    Coming. Later today, that is.
  9. Nothing wrong with that if it was done right and paying some attention
    to the effect on mixture. Wouldn't surprise me if OE filters weren't
    available or simply cost an arm at the time.
    Grimly Curmudgeon, Aug 12, 2007
  10. Timo Geusch
    Exactly, MZs run quite happily on slightly modified Morris 1000 air
    filters.
  11. Timo Geusch
  12. After the GT380 air filter made of carpet underlay, nothing would
    surprise me.
  13. The Older Gentleman, Aug 12, 2007
  14. Timo Geusch
    Did you ever take photos of the carpet underlay "filter"? It's no good
    if we can't stick a few photos up as well...
  15. No, sadly.
  16. Timo Geusch
    Bummer.
  17. Timo Geusch
    Dan L Guest
    Dan L, Aug 12, 2007
  18. Timo Geusch
    crn Guest
    crn, Aug 12, 2007
  19. Timo Geusch
    I haven't checked it that closely but I had the impression that the
    silicone was actually hot glue out of a hot glue gun...
  20. Timo Geusch
    Sounds like a halfway decent bodge to me.
    Pip Luscher, Aug 12, 2007
