Last-minute Tenere hassles
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jan 24, 2009.
  1. The speedo cable broke this afternoon. Oh great. What are the chances of
    getting one before Tuesday lunchtime?
    Zilch, apparently. If a dealer doesn't have it, it takes three or four
    days to get a part (any Yamaha part) from Holland.
    Ring around London Yamaha dealers. Nobody has one. Apparently Fowlers
    has one, but a 260-mile round trip for a speedo cable is a bit silly.
    Ponder asking Platy if he could get it and bring it out with him....
    Not that I can't get to the Elefant with a dead speedo, but it'll make
    judging refuelling stops hard.
    Bloke in my local dealer has other speedo cables for Yamaha dirt bikes,
    so I measure the Tenere's speedo cable with a tape measure and he pulls
    one out that is almost exactly the right length (about three quarters of
    an inch too short) and has the same mounts at either end.
    It'll fit.
    But I can't get the old cable off because the little plastic clip that
    holds it against the fork leg is secured with a tiny nut and bolt and
    they're corroded solid. Sod it: this is what cable ties are for, so I
    riup off the silly plastic clip, run the cable up insie the fairing, and
    behold, we have a working speedo again.
    And it is a right *bastard* getting at the attchment on the speedo head
    on the Tenere.... You need about six fingers. I daresay they manage OK
    in Norfolk.
    Elefant, here we come....
  2. The Older Gentleman
    I'd have suggested going to Halfords and getting a pushbike speedo.
    You have to **** about glueing the sender somewhere where it won't be
    a problem but they work ok once they're on.
    I'd intended getting loads done today but ended up simply sorting out
    tools and piling emergency type stuff (1) into one pannier, spraying
    FS365 all over the place and then spraying every exposed electrical
    connection with a water dispersant/sealer that I've had for years.
    (1) I've probably gone crazy but I've got a pretty comprehensive
    toolkit in there, a footpump, a multimeter, gaffa tape, funnel, WD40,
    emergency cable set, puncture repair spray, Easystart, a couple of
    old rags and a litre of engine oil. If anything goes wrong that I
    can't sort with that lot I'll torch the bike.
    Andy Bonwick, Jan 24, 2009
  3. The Older Gentleman
    Gyp Guest
    YHM
    Gyp, Jan 24, 2009
  4. I've got a spare pair of levers (brake, clutch) on the basis that I'm
    sure to drop the bike and break one or both.
    The main thing is that the bike is cheap enough for me to be able to
    junk it if the worst happens. I'd rather not, mind, because I *really*
    like it.
    I suppose we could break it into large lumps and carry the pieces back
    in various sidecars?
  5. Thanks, but sorted now.
  6. The Older Gentleman
    I forgot to mention the 1.5t bottle jack that's also in the pannier.
    I'll not be bothering with spare levers because if I break a lever
    then I'll probably be going to hospital
    I'm sure we could do something, maybe just tow it behind one of the
    chairs if it was mechanical but crash damage might be more difficult.
    I've got Carole Nash European recovery cover on mine so I just
    automatically assume everyone else has the same.
  7. The Older Gentleman
    I was going to work on the R65 Friday, didn't. Today, didn't. So it gets
    what I can do Sunday and Tuesday morning before heading to Bedford and
    that's the lot.
    I have no spare cables or parts and it's 27 years old.
    It's a BMW. Everything will be fine.
    Hog, Jan 24, 2009
  8. The Older Gentleman
    SD Guest
    Cue "help" post from Doncaster. :)
    SD, Jan 24, 2009
  9. The Older Gentleman
    You could go and rescue him then take him as a passenger on the Wing.
    I'm sure you said you were coming with us this year and then you did a
    Zymurgy and bottled it. It's not too late to throw everything on the
    bike, book a ferry and tag along.
  10. The Older Gentleman
    SD Guest
    I was advised that the Wing was less than ideal. The other two are
    hardly made for the job, either.
    I genuinely thought you going last Wednesday, and dropped out
    ostensibly because of that.
    I've been mental busy at work, and a break would have been good.
    I think my brownie point account is sufficiently overdrawn as it is.
    SD, Jan 24, 2009
  11. Doh. So have I.
  12. The Older Gentleman
    Heh, I'd have loaned you the KTM just for the laugh of seeing you ride
    it.
    Poor excuse.
    Only time will tell if it's good or not but it'll be a change of
    scenery.
    She'll get over it.
  13. The Older Gentleman
    I did think about seeing if you were in today, while riding around
    Bedfordshire trying to talk myself out of a purchase.
    ogden, Jan 24, 2009
  14. The Older Gentleman
    Did you manage to talk yourself out of a purchase? You could have
    popped into mine and helped me polish the SV to within an inch of its
    life
    Lozzo
    SV650S K5, ZX-7R P4, CBR600F-W, SR250 SpazzTrakka, SR250 Project
    SpazzCaffer
    I see a bright new future, where chickens can cross the road with no
    fear of having their motives questioned
    Lozzo, Jan 24, 2009
  15. The Older Gentleman
    Alas, no. Sig-change imminent.
    ogden, Jan 24, 2009
  16. The Older Gentleman
    He'd be better off taking one of those rotary engines with infinite
    stroke that "someone" is peddling on rec.motorcycles...
    Timo Geusch, Jan 24, 2009
  17. Thanks. Did I ever mention that my family lived in Stockholm? On
    Strandvagen.
  18. The Older Gentleman
    NP. Send me the details.
    platypus, Jan 24, 2009
  19. The Older Gentleman
    SD Guest
    Ostensibly. I really didn't want to go cos it'll be all cold and
    horricle and stuff.
    Be careful what you wish for.
    I'm now into toxic levels of debt on the brownie point front,but I
    seem to be doing quite well on the sympathy hugs.
    SD, Jan 25, 2009
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    Excellent.
    Make sure she goes on top for a while. It gives your poorly hand a rest
    and makes her feel in charge.
    It's all good.
    Wicked Uncle Nigel, Jan 25, 2009
