Laser Chain alignment tool
Discussion in 'UK Motorcycles' started by flash, Mar 16, 2005.
  1. sweller wrote
    So would one of them ex burglar alarm bar magnets what live in the
    drawer in the kitchen on the off chance they will one day be useful
    gaffa taped to the illegal laser pointer thing I got when I went to
    merkainia a few years back what I have got lying in the back of the same
    drawer be any good?
    steve auvache, Mar 16, 2005
  2. flash
    I'd guess so but the magnet would have to attached square (Araldited?) to
    the pointer. Shouldn't be too difficult if the body isn't tapered.
    sweller, Mar 16, 2005
  3. sweller wrote
    Kin tape and like it. By the time I had faffed around gluing it
    together and finding/going out and buying new batteries I could have
    lined the kin thing up by eye. Snot as if it is hard, even Bear could
    do it.
  4. flash
    Sean Guest
    Overkill.
    Many moons ago, I bought a chain alignment thingummy by 'Motion Pro' which
    is a horseshoe clamp with an 18" bit of straight stainless steel rod that
    fits into the top of the clamp.
    Said clamp clamps over the sprocket and you sight down the rod to ensure the
    chain run is in line with the rear sprocket. Doddle to use and about 1/3
    the price of the laser gizmo.
    Still, I can't claim to have aligned the rear wheel with a laser, nor can I
    use mine to tease cats, so there are two tangible benefits of the laser
    tool.
    Sean, Mar 16, 2005
  5. There's loads that can't. Believe me.
    The Older Gentleman, Mar 16, 2005
  6. Does your laser pointer actually draw a beam? I mean can you actually
    see the shaft of light or just the dot at the other end?
    I almost bought a laser level to made sure my curtain rails were put on
    straight but I've still not bought any curtains or rails :)
    Whinging Courier, Mar 16, 2005
  7. Whinging Courier wrote
    Nah, it's light innit? All you can see is reflection off any dust what
    happens through the beam and the stop at the other end, of course.
  8. flash
    Catman Guest
    WT*F* is a 'lazer'?
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (Badly bent) 155 TS
    www.cuore-sportivo.co.uk
    Catman, Mar 16, 2005
  9. A good lungful of nature's finest blown along the beam should help.
    I Will, But Me Mate Won't, Mar 16, 2005
  10. flash
    Catman says...
    Crash helmet
    Lozzo, Mar 16, 2005
  11. flash
    It's an end can, I'd have thought a laser would be of more use.
    Muck, Mar 16, 2005
  12. flash
    Christofire Guest
    Christofire, Mar 16, 2005
  13. Oh yeah...
    Durr...
  14. flash
    Catman Guest
    Oh yes. Got one in wardrobe.
  15. flash
    Daz Guest
    I honestly wasn't having a "pop" at Dan but as someone who isn't the
    greatest mechanically minded person in the world I find it hard to
    believe.
    I reckon it must be some kind of "it's really technical" fear. I knew
    nothing about bike mechanics before racing and whilst I still know
    very little it's surprising how much you can get away with using
    nothing more than common sense and a HBOL.
    I've had the engine out of the gixxer and more importantly put it back
    in on my own, once I'd had some help from the brother in law lifting
    it into the frame. By the time I put the tank back on I was convinced
    I must have forgotten something as it all went far too easily but
    bugger me if it didn't fire up first time. Not exactly rocket science
    but I was chuffed to bits with myself!
    Daz, Mar 16, 2005
  16. A mate of mine refuses to touch _anything_ on his bike, other than
    oiling his chain and filling it with petrol (the bike, not the chain).
    He's convinced that if he adjusts his chain, or changes his brake pads,
    or changes a bulb, he's going to throw it down the road, with the
    girlfriend whom he worships to an almost unhealthy degree, on the
    pillion.
    genuine_froggie, Mar 16, 2005
  17. <waves> I'm mechanically useless and I don't mind admitting it.
    Paul Corfield, Mar 16, 2005
  18. I thought you had an GS1150 ?
    <fx: checks .sig>
    Christ, I'm behind the times.
  19. flash
    dwb Guest
    Bridgestone Death^W Trailwings - TBH they were fine in the dry - just not to
    sure how they'll be in the wet.
    I believe the tyres are the same sizes as those on the 1150 and 1200.
    http://www.ukgser.com/forums/showth...138e49&threadid=32096&perpage=16&pagenumber=1
    Thanks.
    dwb, Mar 16, 2005
  20. flash
    dwb Guest
    Oh I can adjust it fine - but getting the tension correct/alignment right -
    it appears not.
    I had one chain on the SV shed it's o-rings, and something similar on the
    GSX-R.
    At that point I gave up.
    dwb, Mar 16, 2005
