I was looking at the indicator lightbubs on control pod, speedo and tach on my 1983 Suzuki GS650GLD and as I don't have a manual yet can someone tell me if they are wrong? Side stand down indicator #158 Speedo illuminator #151 Tach illuminator #194 Neutral indicator #158 Turn Signal indicator #158 I can not find a #151 on the web and the #194 is rated at 3.8W vs the #158 and 3.36W so if they were all changed to #158 would that be bad and overheat? My turn signals were intermittent so I took the flasher apart and sanded the contacts and it works fine now. Need to replace the ignition coils. Bike Bandit says they are 491953-001 so got a pair with same number off a 1981 bike and they don't fit as the coil body is too long. I need 90 mm hole spacing and 65 mm body length. Are mine weird. They also listed battery box as 493679-001 for both bikes but on mine the battery slides in from the side and on the other one it slides in from the top and is much fatter. Ian Singer -- ========================================================================= See my homepage at http://www.iansinger.com hosted on http://www.1and1.com/?k_id=10623894 All genealogy is stored in TMG from http://www.whollygenes.com Charts and searching using TNG from http://www.tngsitebuilding.com I am near Toronto Canada, can I tell where you are from your reply? =========================================================================
Right they are Bike Bandit Numbers. Where are you getting Suzuki numbers from and along same line how do I know if I need 2Ohm of 5OOm coild to go with teh used CDI I purchased? Says the coil is discontinued, also battery box. They are using exactly same pictures as Bike Bandit but do not show any part numbers, until you go into the shopping cart and then it does not say if their numbers or Suzuki numbers. If you don't fancy paying Doesn't stock anything older than 10 years Doesn't list my model Ian Singer -- ========================================================================= See my homepage at http://www.iansinger.com hosted on http://www.1and1.com/?k_id=10623894 All genealogy is stored in TMG from http://www.whollygenes.com Charts and searching using TNG from http://www.tngsitebuilding.com I am near Toronto Canada, can I tell where you are from your reply? =========================================================================
Because they and teh CDI unit were missing on the used bike <g> Ian Singer -- ========================================================================= See my homepage at http://www.iansinger.com hosted on http://www.1and1.com/?k_id=10623894 All genealogy is stored in TMG from http://www.whollygenes.com Charts and searching using TNG from http://www.tngsitebuilding.com I am near Toronto Canada, can I tell where you are from your reply? =========================================================================
That's for a 1981 GS750T but appears its the same part as for 1983 GS650GLD, according to Bike Bandit. Thanks or 110018368279 ? That's for a 1982 GS750E which Bike Bandit does not list. They do have an EZ and that uses different part. Thanks, Ian Singer -- ========================================================================= See my homepage at http://www.iansinger.com hosted on http://www.1and1.com/?k_id=10623894 All genealogy is stored in TMG from http://www.whollygenes.com Charts and searching using TNG from http://www.tngsitebuilding.com I am near Toronto Canada, can I tell where you are from your reply? =========================================================================
