Lamp munching Bandit
Discussion in 'UK Motorcycles' started by rb, Nov 10, 2004.
  1. rb
    rb Guest
    My bike seems to be forever blowing the number plate lamp. I can only
    think this would be due to vibration? I was wondering if an LED type
    replacement would be more robust.
    So, what is
    a) the legal status of LED replacements?
    b) the general opinion on LED lamps?
    rb, Nov 10, 2004
  2. rb
    Almost certainly. Have you checked all the connections and joints in
    the loom for tightness and corrosion?
    It certainly would - no filament to vibrate to ****, see.
    They are legal AFAIK.
    I'd use them like a shot if they weren't so fucking expensive.
    Pip, Nov 10, 2004
  3. rb
    rb Guest
    <looks at floor, shuffles feet>
    No, the lamp stops working, I take it out and put a fresh one in.
    Although I can't see how bad connections or corrosion could cause the
    lamp itself to fail?
    I was perplexed when the new one didn't fix it today and so had a quick
    fiddle with the loom. Then I put the fluke on the new one and it was
    already blown! Good job I got two.
    My thoughts exactly.
    <googles for prices>
    Ok, where do I get them? There seem to be some rather nifty right angle
    ones which would suit number plate illumination to a tee[1] - but I
    can't find a UK site with a price.
    [1] Assuming the bend points the right way as it were.
    rb, Nov 10, 2004
  4. rb
    Otter Guest
    Try here...
    http://www.motorcycleshops.co.uk/shops/mk137pz.htm
    independant LED fitter/(retailer?) that's not too far from me.
    Otter, Nov 10, 2004
  5. rb
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Otter
    Oh you utter, utter, *utter* ****.
    <whimper>
    They're only in Milton Keynes too...
    I think the BlingMobile may be about to be taken to a whole new level...
    Nigel Eaton, Nov 10, 2004
  6. rb
    You may have answered your own query above.
    Briefly, if there is an intermittent connection on live or earth, it
    will make and break the power supply. If it does this frequently, the
    lamp will appear to flicker. A tungsten filament has a finite life in
    that it will only accept a certain number of thermal cycles - being
    turned on and off. If it is being effectively turned on and off many
    times by a bad connection, it will die comparatively rapidly.
    Poor connections also heat up, due to the 'on and off' effect. This
    will affect the longevity of the copper strands that make up the
    wires, making them more prone to breaking. That and corrosion causing
    volatge drop are major long-term problems with copper wired looms.
    I could rabbit on for ages, but that'll do for now as I'm knackered.
    [LED repalcements]
    Carry on googling, or try local car and/or bike parts shops.
    Someone who knows will be along shortly, I expect.
    Pip, Nov 10, 2004
  7. rb
    Preston Kemp Guest
    My parents/brother sell a couple of types for around £6 -
    http://www.shop.vintech.co.uk/acatalog/CATALOGUE_Lighting_set__horn__dyn
    amo____ignition_24.html
    They can probably get others if you ring & ask - the phone number's on
    the main site http://www.vintech.co.uk/
    That's the trouble with LEDs, they don't throw any light out to the
    side. If you're that worried about having an illuminated plate you'll
    probably need bent bulbs, or ones where the LEDs stick out from the
    holder rather than being flush.
    Preston Kemp, Nov 10, 2004
  8. rb
    Salad Dodger Guest
    <averts eyes>
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16931.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 11, 2004
  9. rb
    Fairy lights. Well, it is nearly Xmas...
    platypus, Nov 11, 2004
  10. rb
    Wizard Guest
    You could try
    http://www.ultraleds.co.uk
    or
    http://www.2ndbite.com
    The guy at the second one was very helpful when I got in touch.
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Nov 11, 2004
  11. rb
    rb was seen penning the following ode to ... whatever:
    I just got one for the Husky from http://www.ultraleds.co.uk/ -
    ordered Sunday, turned up Wednesday.
    It's about the same size as the bulb it replaces so there are were no
    fitting problems. I noticed that the light it emits (it's a 'white'
    LED) has a noticeable blue tinge to it, a bit light neon light - in
    fact, that was what it reminded me of.
    All in all, it seems to be somewhat brighter than a normal bulb and
    the intensity increases again noticeably when the brake light 'mode'
    is used.
    Timo Geusch, Nov 11, 2004
  12. rb
    rb Guest
    If it wasn't for you pixies and your infallible logic I would have
    gotten away with it too.
    <puts req in for another tuit>
    Thanks all.
    rb, Nov 11, 2004
  13. rb
    rb Guest
    [replacement LED lights]
    I think this particular product says it all:
    "Tarts Handbag engine and bike loom for Harley (10 lamps 8 around
    engine 2 for rear wheel) #60"
    Next!
    rb, Nov 11, 2004
  14. rb
    Wizard Guest
    @localhost.talkaboutmotorcycles.com>, Doesnotcompute
    () says...
    Are you saying you've got LEDs in there and they've failed? I thought
    that didn't happen.
    <Holds out fire extinguisher>
    <8P Wizard
    Golf GTi 16v
  15. rb
    Poor earths are also a bulb killer.
    sweller, Nov 11, 2004
