I have a '77 KZ650 that I thought about cleaning the carbs on. However, I'm confused as to just what I have. I can only find one adjustment needle, that would be on the bottom, which should be the idle. I have seen diagrams showing several needles, but my carbs don't seem to have those. I have also seen that in the 80's they capped them off, but I don't think mine are capped that I can tell. I have pictures of my carbs at: [URL]http://users.dls.net/~reed/carb_left.jpg[/URL] [URL]http://users.dls.net/~reed/carb_right.jpg[/URL] Several years ago, I took them apart and soaked them. No difference. They work fine when opened up some (say over 2000 rpm) but aren't very good at idle. I usually have to play with the choke, and even after warmed up it wants to stumble. I've had it since 1978, and it's always been cold natured, but it seems a little worse now, and is a pain as I'm driving it more now :) Sometimes in the morning, I can get down to the end of the road, but there just isn't any power to take off. Once I take off, I'm on the interstate and it runs fine at higher RPM. Is it worth taking apart and cleaning? Would it be O-rings need replaced, the needles cleaned and adjusted? I also want to sync them, but don't know if that would take care of this problem. So I'm not sure just what adjustments or needles I have, as I see conflicting info between diagrams I see and my carbs. I'd just like to figure out what adjustments there are and try and get them running better. I don't mind taking them apart, although it isn't the easiest to do, but don't want to do work not necessary. Also, is there a good place to get a kit? I would assume I should change all the O-rings and gaskets while I am in there.
