KZ 550 Advice Needed
Discussion in 'Motorbike Technical Discussion' started by Shaky Jake, Nov 5, 2006.
  1. Shaky Jake
    Shaky Jake Guest
    OK, I'm bent over and I know I'm asking for it, but I'm a motorcycle
    mechanic newbie:
    I need to remove the fuel tank and seat from my 82 Kawasaki KZ550. I
    have located an "L" pin from under the right front corner of the seat
    that had a cotter pin in it. I extracted the pin.
    Does this seat somehow fasten down and then swing up? My repair manual
    doesn't say.
    Once the seat is off then there is a metal tab that becomes exposed,
    right?
    Is there such a thing as an online owner's manual for this thing?
    Thanks in advance.
    Shaky Jake
  2. Um, from memory, what you've removed is the seat hinge. You don't need
    to remove it. There'll be a seat lock and/or catch on the opposite side
    to the hinge. Pop that, and the seat swings open.
    Oh, and there are usually two of those hinge/cotter pin things.
    As for a manual - don't be a cheapskate. Buy one.
    The Older Gentleman, Nov 6, 2006
  3. Oh yeah, so he does. Blush.
    Indeed. Well, I've given the answer above, anyway.
    chateau.murray, Nov 6, 2006
  4. Shaky Jake
    Shaky Jake Guest
    Thanks for the help, got the seat to open up, thanks to you onliners.
    Old story, simple once you see how it works.
    Now I can find the fuel leak(s) and repair the frozen petcock handle.
    Thats a "tap" for
    you limeys. : ^ )
    I was also looking at a set of 4 into 1 pipes that Dennis Kirk makes.
    They certainly appear to have less restriction than the stock pipes and
    mufflers.
    If I installed the new exhaust then what would be the procedure for
    rejetting the carbs?
    Just wondering........
    Jake
    Shaky Jake, Nov 6, 2006
  5. Shaky Jake
    Shaky Jake Guest
    Thats a "tap" for
    you limeys. : ^ )
    mufflers.
    Jake
  6. Some fuel taps are just naturally stiff. The thing with the Z is it uses
    a vacuum tap - there's a pipe goes from the carbs to the tap, and the
    carb vacuum sucks open a diaphragm which lets the fuel flow.
    Engine stops, no vacuum, diaphragm closes, fuel stops flowing, Very easy
    and neat and efficient.
    But obviously the tap spends a lot of time in the one position,
    especially if you never run it to reserve and switch it to the reserve
    setting. So it tends to seize in position.
    A fuel tap strip and clean is easy. But be careful handling the
    diaphragm - very easy to tear, and will leave you with an unwanted
    pregnancy.
    You won't notice much of a difference with performance pipes on their
    own. Far better to get a set that works with the stock carb settings.
    The Older Gentleman, Nov 7, 2006
  7. Shaky Jake
    Wudsracer Guest
    ________________________________
    You gave him the gospel, Mark, in a very succinct form.
    I hope that he heeds it.
    (and that his pipes aren't rusted through.)
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Nov 8, 2006
