KTMs - not as tough as they're cracked up to be
Discussion in 'UK Motorcycles' started by ogden, Jan 17, 2011.
  1. ogden
    <fx: paging Bonwick and his gaylord white Yamaha>
    Actually, I could almost certainly /remove/ calipers...
    darsy, Feb 1, 2011
    #61
  2. ogden
    Pete Fisher Guest
    In communiqué
    Quite. Always tempting to push the pistons out beyond the point of no
    return in an attempt to free them up. Plus if some pistons are lazy an
    elegant means of blocking the others needs to be contrived. A tiny G
    clamp is my preferred solution.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 1, 2011
    #62
  3. ogden
    SIRPip Guest
    At least that's what it seems to be to push.
    You have to get the fucker on the road first.
    And then, where are you going to find an Italian, this time of day?
    SIRPip, Feb 1, 2011
    #63
  4. ogden
    SIRPip Guest
    Yeah, that's the feller. Dunno whether it's gravity making the brake
    fluid press on the pistons and seals, or a bit of fur on the business
    side of the pad, but it always affects vehicles that have been standing
    for a bit. It only takes a couple of thou of movement to make the pads
    bind a tiny bit and that makes it awkward to push very easily.
    I'm impressed by your freedom with technical terminology.
    SIRPip, Feb 1, 2011
    #64
  5. ogden
    SIRPip Guest
    Hmm. "Mental" with a pressure washer. This is darsy and previously
    zymurgy, we're talking about here, right? Anything could have happened
    to that bike, man - anything.
    SIRPip, Feb 1, 2011
    #65
  6. ogden
    erm, yes - it does need a new battery.
    easy - "Enfield Dry Cleaners", Southbury Road or "The Barber Shop" on
    Genotin Passage - both are full of them.
    darsy, Feb 1, 2011
    #66
  7. ogden
    that takes me back to the days of Bridgeports, dodgy bandsaws, firing
    bolts across the shop with airlines, and imperial measure vernier
    calipers.
    hey, I worked in a CNC engineering shop for a while; I know what I'm
    talking about!
    darsy, Feb 1, 2011
    #67
  8. ogden
    it's worse than you think - it once had Jen on the back of it on a
    French Run.
    darsy, Feb 1, 2011
    #68
  9. ogden
    If it's not the brake pistons it could be the pads corroded onto the
    brake pins.
    Andy Bonwick, Feb 1, 2011
    #69
  10. ogden
    You'll be waiting a while because I'm away on the gay bike for the
    next 3 weekends.
    But not put them back.
    #70
  11. ogden
    SIRPip Guest
    There's no hope.
    SIRPip, Feb 1, 2011
    #71
  12. ogden
    Even I can take calipers off and put them back on again.
    Wheels too, if I'm feeling really adventurous.
    ogden, Feb 1, 2011
    #72
  13. ogden
    Salad Dodger Guest
    No it didn't, that was his Blackbird.
    It's had Linda on the back, which may not help my argument much.
    Salad Dodger, Feb 1, 2011
    #73
  14. ogden
    Snowleopard Guest
    On Tue, 01 Feb 2011 17:38:16 +0000, Andy Bonwick
    He'd surely not be daft enough to leave the bolts loose, would he?
    Snowleopard, Feb 1, 2011
    #74
  15. ogden
    err...are you sure? I am 99% certain it arrived at Duclair with Jen on
    the back.
    err..same destination, didn't you two have a bit of a wobbly?
    darsy, Feb 1, 2011
    #75
  16. ogden
    or hang on, wait, that wasn't a euphemism, was it?
    darsy, Feb 1, 2011
    #76
  17. ogden
    Salad Dodger Guest
    Jen rode it back from Dieppe, and we followed nearly all the way, it
    were deffo the Blackbird.
    We never have a bit of a wobbly. I'm too scared to answer back.
    She got a lift back from Bruges when the Wing ate its air hose to the
    rear shocks - the Lille trip where TBC tried to run his Pan on Esso
    Blue.
    #77
  18. ogden
    zymurgy Guest
    ITYF that SD is correct on both counts here :)
    Paul.
    zymurgy, Feb 1, 2011
    #78
  19. ogden
    I hate doing wheels.
    I fucked up the thread on a wheel spindle once, doing it myself. eBay
    to the rescue that time...
    CT, Feb 2, 2011
    #79
  20. ogden
    Me too, apart from the MV (single-sided single-nut rear, quick release
    dropouts on the front).
    Krusty, Feb 2, 2011
    #80
