Kreemed tanks
Discussion in 'Australian Motorcycles' started by Fwoar, Sep 19, 2003.
  1. Fwoar
    Fwoar Guest
    Any leaks from the latest Kreemee's ?
    Crazycam?? Clem???
    Gonna do one myself.
    Daron
    Fwoar, Sep 19, 2003
  2. Fwoar
    I had no joy with Red, White and Blue Daron, (but that was probably that I didn't make sure it was absolutely
    dry) but my cheapo marine-epoxy effort is still holding.
    The Kreem job I did back in '87-or-so lasted until after I sold the bike a year later.
    Clem
    Knobdoodle, Sep 19, 2003
  3. Fwoar
    glitch1 Guest
    You kreeming your tank?
    I like riding my bike too, but that.... :)))
    serious:
    To get the petrol out, remove all caps/fuelcock etc. then sit tank in front
    of little fan heater (I also used the hairdryer, not recommended :), filler
    hole up, for about an hour.
    Make sure you stick to the directions on the bottles and at least double the
    drying times/ agitation times/drying times/ agitation times...
    Did a tank of a mate's ex-swiss-army R80 G/S, bloody 38 liter monster,
    needed 2 lots of Kreem at any given stage and the thing was H E A V Y.
    Took a leisurely 4 days to get it all done, then let it dry for another
    3days before the first fill.
    Done a CB400T tank about 7 years ago, still no worries.
    The stuff's good, but don't rush it.
    cheers
    pete
    glitch1, Sep 19, 2003
  4. Fwoar
    conehead Guest
    If the hole is at the lowest part, won't the fuel come out with gravity? Or
    am I missing something?
    conehead, Sep 19, 2003
  5. Fwoar
    Fwoar Guest
    The hole is in the lowest part but as you can imagine, there is a flat
    section where the hole is
    It's like ball in the hole on a flat board game.
    Never get the fuel out at the right angle. cos you can't see the swishing
    Daron
    Fwoar, Sep 19, 2003
  6. Fwoar
    Fwoar Guest
    I got one of those heat guns - that'll work if I maintain it pretty low
    Daron
    Fwoar, Sep 19, 2003
  7. Fwoar
    Nathan Smith Guest
    Hmmmm the stupidist sounding solution is definately the best one!!!!!!!!!!
    Nathan
    Nathan Smith, Sep 19, 2003
  8. Fwoar
    I seriously contemplated tapping a hole into the lowest portions of the tank (which are NOT where the tap is)
    and fitting drain-screws.
    (It might still be required!)
    Clem
  9. Fwoar
    conehead Guest
    Huh? What?!? 42.
    conehead, Sep 20, 2003
  10. Fwoar
    Doug Cox Guest
    Just don't leave it to dry (after washing out the etcher) any longer than
    specified in the instructions. First time round I decided to leave it dry
    overnight. In the morning it had more rusticles inside than the bloody
    Titanic...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Sep 22, 2003
  11. Fwoar
    Fwoar Guest
    I'm about to wash it ( bottle 2) & coat it
    Daron
    Fwoar, Sep 22, 2003
