koofruff key keeps breaking
Discussion in 'Motorbike Technical Discussion' started by sokol, Oct 1, 2006.
  1. sokol
    sokol Guest
    I'm fairly new to bike restoration so could do with a bit of help.
    The bike I'm working on is a 1936 Sokol, which is a Polish built
    knockoff
    that is basically a 995cc Vtwin a la Indian combined with Harley front
    suspension.
    The problem is that the woodruff key on the kickstart keeps breaking.
    The engine starts fairly easily with no appreciable kick back. The
    advance/retard mechanism of the distributor has been screwed down in
    the maximum retard position and will stay like that until I can
    fabricate the cable for the manual mechanism.
    I'm reluctant to keep on making new keys until I understand why they
    keep breaking.
    sokol, Oct 1, 2006
  2. sokol
    sokol Guest
    the title should, of course, say Woodruff key, excuse the type
    sokol, Oct 1, 2006
  3. sokol
    B-12 Guest
    Is the kickstarter shaft tapered? In that case, the tapered parts may
    be worn out, allowing the rotational load to be on the key instead of
    the tapered parts which are supposed to carry the load.
    At one time, Husqvarna countershafts were pressed onto a tapered
    countershaft...
    B-12, Oct 1, 2006
  4. sokol
    oldgeezer Guest
    B-12 schreef:
    If you use genuine parts, then it could be that the key is too hard.
    I once owned a russian Ural (sorry ;-) that had parts as hard as
    glass (valve stems, dynamo axle'among other). Fabrication standards
    simply were no good.
    Those parts broke under load.
    Rob.
    oldgeezer, Oct 1, 2006
  5. sokol
    oldgeezer Guest
    Rob.
  6. sokol
    oldgeezer Guest
    Rob.
  7. sokol
    oldgeezer Guest
    Rob.
  8. sokol
    oldgeezer Guest
    Rob.
  9. sokol
    oldgeezer Guest
    Rob.
  10. sokol
    oldgeezer Guest
    Rob.
  11. The woodruff key is supposed to break to protect the engine internals in
    the event of an excessive mechanical shock. If it's breaking in the event
    of
    a normal mechanical shock then check:
    1) should be zero lubrication on the keyed shaft
    2) key should not be normally taking any shear load
    3) key must fit exactly, make sure the slot where the key goes is not
    hogged out, or the key isn't too small, etc.
    Ted
    Ted Mittelstaedt, Oct 2, 2006
  12. sokol
    sokol Guest
    In response to the various comments:
    1. The shaft is not tapered
    2. No original parts available, the company disappeared during WW2.
    3. Shaft lubrication is OK
    The answer may be in my construction technique. The slot in the shaft
    is 5.5mm wide while the slot on the gear is closer to 6mm (is that a
    design issue or sloppy manufacturing?). My key was cut from a piece of
    angle iron which was the closest I had to 5.5mm so needed the least
    grinding down. Again, its iron not steel which my mentors say is OK,
    the key should break before the shaft. When grinding into shape I kept
    dunking it in cold water so that I could pick it up, was that a mistake?
    sokol, Oct 2, 2006
  13. sokol
    B-12 Guest
    I suppose that the average person cannot smell his own brain fart. I'm
    not saying that
    my brain has never flatulated, but this particular emission from Ted is
    amusing.
    The function of a locating device such as a Woodruff key is to locate
    parts accurately and prevent relative motion. If the engineer had
    actually intended the Woodruff key to break, he probably would have
    designed the device with a shear pin instead.
    A mechanical engineer *knows* what the mechanical loads on his parts
    are, before he begins designing. He selects a key made of a material
    which will withstand deflection and chooses a part from a table of
    standard keys to obtain a key which has the physical dimensions not to
    bend.
    Woodruff kets are semi-circular, a Woodruff cutter is used to mill a
    precision crescent shaped slot into the shaft, and a broach is used to
    scrape a rectangular slot into the rotating part.
    Part of the Woodruff key sticks up out of the shaft, and goes into the
    slot on the rotating part.
    If a Woodruff key breaks, the broken bits become a machine tool
    themselves, they will act as a lathe tool and ruin the adjacent part.
    B-12, Oct 2, 2006
  14. sokol
    B-12 Guest
    The slot in the shaft is called a keyseat The slot in the gear is
    called a keyway.
    Keyseats are milled with a rotating cutter. Keyways are broached with a
    device that scrapes a slot by linear motion.
    Your dimensional quandary is 5.5mm versus almost 6 mm. Half a
    millimeter. A silly half a millimeter. Less than 20 thousands of an
    inch. Is it sloppy or is it shrewd?
    It could very well be a design and manufacturing issue. I think that
    the engineers might have been cutting precision keyways and keyseats in
    the machined parts that they had quality control over, but they may
    have realized that replacement Woodruff keys might vary widely in
    dimension.
    If you're going to machine precision parts to plus or minus 1/1000th of
    an inch, the available Woodruff keys are all going to have to be
    thinner than the keyway and the keyseat or the mechanic will have to
    make them so. The tools available in the field might be crude...
    I don't happen to have a Machinist's Handbook right here, but I do have
    some books on technical drawing. So I did a little detective work and
    reasoning with what I have available, an old book and an old mind...
    The American National Standard # 808 Woodruff key is 8/32nds of an inch
    wide, and the base circle of the key is 8/8ths of an inch in diameter.
    IOW, it's a key that is nominally 1/4 of an inch thick, and if it was
    circular instead of crescent shaped, it would nominally be one inch in
    diameter. The Woodruff key would stick a nominal 1/8th of an inch out
    of the keyseat.
    The maximum depth of the keyseat would be .3130 inches. Now we're
    getting into the tenths of thousandths of an inch. The technical
    drawing book shows that the width of the milled keyseat (in the shaft)
    should be 0.249 to 0.250 wide. That's a min/max range of only 1/1000th
    of an inch. That's what the engineers controlled at the Sokol factory.
    But that *nominal* 8/32nds of an inch thickness of the key leads back
    to fractional tolerances. Fractional tolerances are often specified as
    plus or minus 1/32nd or 1/64th of an inch.
    So that nominal 1/4th inch thick Woodruff key could theoretically be
    8/32nds *minus* 1/64th of an inch wide. The standard #808 key could,
    apparently be only 0.234 inches thick. That's 16/1000ths of an inch
    thinner. It's pretty close to your half millimeter.
    That's a rather sloppy fit that might lead to broken keys. Maybe there
    are keys made of a stronger material that you could use? It's not like
    the starter shaft and gears are used continuously...
    B-12, Oct 2, 2006
  15. If you do that you will create a weakness at the transition from the 5.5mm
    to the 6mm size.
    The big question, though, is why is the key taking a shear load? What keeps
    the kickstarter from sliding off the shaft? Is there a bolt that clamps it
    on
    to the shaft?
    Ted
  16. sokol
    sokol Guest
    Lateral motion of the kickstart on the shaft is limited by a collar and
    gudgeon pin.
    sokol, Oct 3, 2006
