Knackered thermostat?
Discussion in 'UK Motorcycles' started by Wazza, Jan 26, 2004.
  1. Wazza
    Wazza Guest
    My T595 has been running hot, not thought too much of it as they do that
    apparently. Anyway i gave it a clean and warm up over the weekend and
    noticed that after only a few minutes the temp was quite high, the fan was
    running and yet the expansion tank and the lines (that i could feel) were
    still cold. Does this suggest a knackered thermostat?
    Cheers
    Wazza
    T595
    Never underestimate the power of very stupid people in large groups.
    Wazza, Jan 26, 2004
  2. Wazza
    Robbo Guest
    Quite possibly, and then again it might be a bit of a blockage. I'd check
    the stat anyway in a pot of boiling water and see if it operates.
    If in doubt change it (And don't forget the anti-freeze)
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Jan 26, 2004
  3. Dunno. In fact I dont even know if bikes have thermostats? Do they?
    The reason I wonder this is that I always used to have to tape up half
    the (specially large) radiators on my tuned race bikes when in cold
    conditions which would indicate no thermostat. But perhaps they had
    been removed.
    Maybe your water pump is shagged?
    Steve Bullimore, Jan 26, 2004
  4. Wazza
    Yes, road bikes do.
    SOP. One less thing to go wrong, removing the 'stat also improves
    flow. It's usually an issue keeping race-tuned bikes cool enough, nas
    opposed to getting them up to temperature at 3Krpm going to work down
    a country lane at 3am.
    Pip, Jan 26, 2004
  5. Wazza
    mb Guest
    Airlock?
    mb, Jan 26, 2004
  6. Shit, where is it on an R1150GS then? :-(
    Rick
    Richard Sterry, Jan 26, 2004
  7. Wazza
    Richard Sterry was seen penning the following ode to ... whatever:
    You'll find it in the circuit to the oil cooler somewhere...
    Timo Geusch, Jan 26, 2004
  8. Wazza
    mb was seen penning the following ode to ... whatever:
    Would be my guess as well. The expansion tank on my ST never got warm
    either, but at least the hoses to/from the radiator were.
    That said, I'd expect the radiator to be hot...
  9. Wazza
    **** knows. You'll have to ask a gay mechanic about that.
    Pip, Jan 26, 2004
  10. Wazza
    Ah well you see the thermostat is built into the seat for this model
    www.corbin.com/bmw/r1150r01.shtml
    Hog, Jan 26, 2004
  11. Wazza
    Nice. That'll keep the old Farmer Gileses at bay a treat.
    Pip, Jan 26, 2004
  12. Wazza
    Wazza Guest
    Cheers guys, i think i will drain the system off and take a look at the
    thermostat at the same time....
    Wazza
    T595
    Wazza, Jan 27, 2004
