Kinda OT.. Sidecar tyres...
Discussion in 'Australian Motorcycles' started by Pete, Apr 22, 2005.
  1. Pete
    Pete Guest
    My father is looking for tyres for his vintage car (restoration project).
    The tyres are for a 16 inch rim at about 5 - 5.25 inch width.
    He had heard that tyres used on some sidecars might fit.
    The bike tyre dealers I ask dont deal in such tyres. Car dealers say they
    have nothing in those sizes.
    Whom does?
    I'm in Canberra, the car is in Hobart.
    Cheers,
    Pete...
    Pete, Apr 22, 2005
  2. Pete
    feral Guest
    Try here:
    feral, Apr 22, 2005
  3. Pete
    The Raven Guest
    Plenty of vintage tyre manufacturers around. OK, most are overseas but
    specialist shops will import them in bulk and sell them as needed.
    I wouldn't risk using tyres from a totally different application on a
    vintage car, particularly one you're restoring. Too many things can go
    wrong....
    The Raven, Apr 22, 2005
  4. Pete
    Vincent Guest
    A tyre for a sidecar would be almost the hardest thing to find, I used car
    tyres as the constant scrubbing of the sidecar tyre while making right hand
    turns proved too costly to use ordinary bike tyres, I looked for my tyres at
    swap meets in the veteran/vintage car sections
    Vincent, Apr 22, 2005
  5. Pete
    John Littler Guest
    Are you sure about that rim width - sounds way too wide - should be
    around 3" if it's vintage, and even post war there's only one marque who
    were still running 16's that I can think of (and if it's a roller go see
    your club, there's no shortage of tyres)
    Give us the correct crossply size are you sure it's not 16x 5.00 ?
    JL
    John Littler, Apr 22, 2005
  6. Pete
    John Littler Guest
    Actually strike that before the pedants jump in - immediately post war
    there were plenty who ran 16s but most companys were running 13,14 or at
    most 15" by the late 50's
    JL
  7. I would have thought a MC tyre would be designed with lateral force
    being of minimal importance, and since sidecar rigs do experience
    lateral forces the tyres would be very different. In fact the tyres on
    the cycle itself should really be different in the sidecar
    application?
    Toby Ponsenby, Apr 22, 2005
  8. Pete
    John_H Guest
    Forget bike tyres, they're not suitable for cars (and vice versa).
    The system used to be, and probably still is, that various tyre
    manufactures would make batches of vintage tyre sizes whenever the
    demand arose. It's usually a simple matter of finding out how who
    among the various distributors has what in stock. More obliging tyre
    outlets can usually track them down if they care to try but probably
    won't be the cheapest source (unless he's unable to fit them himself).
    Car clubs are also likely to know who has them.
    More than likely the size he's looking for will be 5.25 x 16 (5.25
    being the tyre width -- not the rim size). It'd also help if we knew
    the make and model of car as there's likely to be suitable alternative
    sizes in both radial and cross ply. Depending on the level of
    authenticity wanted and how the car will be used modern radials might
    even be a better choice
    You could try googling *5.25 x 16 tyre*. Also try 525 x 16 (which is
    another way of expressing the same thing -- with and without the
    spaces). 5.25-16 also means the same thing.
    John_H, Apr 22, 2005
  9. Pete
    Boxer Guest
    I have 3 car tyres on my bike.
    Boxer
    Boxer, Apr 23, 2005
  10. It's close. My front is a 5.00x16 Avon SM MKII. It's a rear motorcycle tyre
    made for older bikes. It's not flat but not as curved as modern tyres
    either. Perfect for a trike especially after it's half worn flat. The
    curved edges only get used in low speed tight manoeuvring and dependant of
    the rake. It handles side forces well but I reckon it's too curved for a
    car.
    Pisshead Pete, Apr 23, 2005
  11. Pete
    Vincent Guest
    All tyres would suffer with a sidecar rig.
    I found that using bike tyres would result in the both tyres scrubbing out
    long before time as I would always do a hard right hand turn, thus scrubbing
    the tyres when it slid around the corner, so having to pay $150 or so for
    tyres which lasted only a few months, was much dearer than a car tyre for
    $75 or so and would last longer than the bike tyre .
    Maybe I am too harsh but riding a sidecar rig is fun, I like to slide it
    around corners and lift the sidecar off the ground when I do a lefty and
    scare the shit out of the passenger
    Vincent, Apr 23, 2005
  12. Pete
    feral Guest
    Like this Tobe? :)
    There's a Vincent or two in there too Vincent. :)
    feral, Apr 23, 2005
  13. http://www.antiquetyres.com.au/index2.html
    have all sorts of tyres for vintage cars, they're based in Melbourne. re
    16" sidecar tyres, there are two variations I know of; the Avon like Pete
    uses on the front of his trike and you might remember maybe 15-20 years ago
    there was a "twin wheel" available for some crappydores and mercs, they used
    16" tyres(125 and 135 were available from memory), but tyres are now
    virtually unavailable, a guy in the USA bought the lot as they are good for
    some sidecar use (early Goldwing is one), if you want to contact him look up
    "Dauntless motors", somewhere, USA.
    I know some guys with MkVII-MkIX Jags are using RAV4 tyres, they are widish
    16s, also I've seen historic racers using sticky 16" bike rubber as it was
    cheaper than the real thing, but I dont think thats what your dads after.
    In short 16" sidecar tyres arent thick on the ground either.
    Al
    Alan Pennykid, Apr 25, 2005
  14. Pete
    feral Guest
    Point 1. I posted a link to antiquetyres on the 22nd.
    Have you read the whole thread?
    Point 2. Would be nice if we heard from Pete again
    even if just to thank us for nothing.
    feral, Apr 25, 2005
  15. Point 1. Of course not, you think I read the whole thread before replying?
    Aus.moto would make sense if we all did that.
    Point 2. Probably out buying tyres :)
    I've got similar tyre issues with my car, but luckily I can still get the
    original sizes even if only in ordinary brands. Suits me though, any of the
    oversized more modern tyres people are running make it difficult to get the
    rear wheel from under the guards.
    Al
    '02 Yamaha TDM900
    '66 Jaguar 3.4S
  16. Pete
    feral Guest
    Fark.
    And a mate of Rons.
    <plonk>
    feral, Apr 25, 2005
  17. Who?
  18. Pete
    John Littler Guest
    He's just making wildarse assumptions because you have a Jag and so does
    Ron (from aus.cars)
    JL
    (you'd better plonk me as well* Feral, I've actually met Ron face to
    face <gasp!> )
    *I guess that assumes I'm not already
    John Littler, Apr 25, 2005
  19. Pete
    feral Guest
    All in jest JL. :)
    I plonk noone.
    But then again, I don't often x-post either.
    See ya.
    feral, Apr 25, 2005
  20. Pete
    ck Guest
    people use 'em on cars tho
    ck
    ck, Apr 26, 2005
