Keihin CV's air cut-off valve
Discussion in 'Motorbike Technical Discussion' started by Jake, Aug 9, 2003.
  1. Jake
    Jake Guest
    Does anyone know what the function of this diaphragm/valve is? There is one
    per carb, on the side and I would need to seperate the carbs to check # 2,
    3, 4. If----I knew what they did I could determine if they were working
    properly without having to go to all the additional time and expense to
    visually inspect them. I have the carbs off to check float height, jets,
    needles, screws etc,. while seeking to correct a mid throttle lean
    condition. I have the factory Homda manual and they don't mention it. (1979
    Honda 750 LTD). I want to get the machine on the road.
    Thanks. Jake
    Jake, Aug 9, 2003
