kawi head skim measurement
Discussion in 'Motorbike Technical Discussion' started by Brendan, Jun 22, 2004.
  1. Brendan
    Brendan Guest
    I've noticed head skim markers under the exhaust ports on my gpz550
    cylinder heads, on std heads they are ?? 1mm below the gasket face, on
    a heavily skimmed head they are flush. Anyone?
  2. Brendan
    djtcz Guest
    Some engines have minimum head thickness specs. If that Kawasaki model
    has a recommended minimum I'd check on a few potential complications
    before exceeding it.
    On chain-driven OHC engines "Excessive" head milling/skimming changes
    the cam timing and adds slack in the cam chain for the tensioner to
    try to remove. It also weakens the head some and can tend to provoke
    head gasket sealing problems. It brings the valves closer to the
    pistons. On water cooled engines there are water jackets in there
    somewhere. Not all these problems will arise with a 1 mm cut, but
    djtcz, Jun 26, 2004
  3. Brendan
    Brendan Guest
    There is no head thickness or skim recommendations in any of the
    service manuals. Cams will be dialed in and checked for clearance and
    an uprated tensioner used.
    The manual lists around 16cc combustion chamer, this head has I think
    ..7mm skim but the chambers are still over 15cc ...ie much less
    combustion chamber reduction than simple calculations predict.
    Brendan, Jun 28, 2004
