Kawasaki W1/W2
Discussion in 'General Motorbike Discussion' started by andysoch, Apr 28, 2023.
  1. andysoch
    andysoch
    Apr 28, 2023
    2
    0
    I need help with Cam Timing
    The Timing marks are hidden behind an inner cover.
    I have the cover off, with intermediate gear on one side, and generator sprocket on the other.
    Both cogs are keyed onto the shaft - and neither is keen to let go
    The gear on the crank has one dot on it - at 90? deg to the keyway.
    The intermediate gear has 2 dots on it - 100? degrees apart (and the number 2)
    The cam gear has A & B stamped on it - 180 degrees apart.
    The ignition Timing wheel has 1 dot on it.
    Any helpwould be usefuel - where to look for a start!!
    Tnx
