Kawasaki LTD 440
Discussion in 'Motorbike Technical Discussion' started by a.mirarchi, Jun 13, 2004.
  1. a.mirarchi
    a.mirarchi Guest
    Hi.
    A friend of mine has a Kawasaki LTD 440 that hasn't been started in 12
    years. Does anyone know how I should proceed in starting this bike?
    Alberto
  2. a.mirarchi
    D-DUB Guest
    shot of light oil into each cylinder before you start it.
    D-DUB, Jun 13, 2004
  3. a.mirarchi
    AL Mills Guest
    Me, I just installed a used engine that sat for
    who knows how long. What I did was squirt some
    oil in through the spark plug holes and put new
    oil in the crankcase. Then for about a week,
    while I was fiddling with the vacuum hoses, I
    cranked the engine without gas or spark plugs
    just to lubricate everything.
    My 2 cents...
    AL
    AL Mills, Jun 13, 2004
  4. a.mirarchi
    Mastermech Guest
    Make sure you pull the carbs and clean them out, did I mention make sure
    they are clean. Don't forget the air screw. Do a compression check now and
    again after you have gotten it running for a while. Oh and make sure the
    carbs are clean, did I mention that.
    I had a LTD750. great compression, did the valve adjustment but could not
    get it to produce any power. turns out the rings had collected all the crap
    off the cylinder walls and stuck into their glands. Removed engine and
    pulled cylinders. cleaned and freed up rings, a quick cylinder hone and it
    ran like new. After synching the carbs of course. Good Luck
    Mastermech, Jun 13, 2004
  5. Squirt of oil down the cylinders, turn it over with the plugs out, new
    fuel, new plugs, new battery, and see what happens.
    If it then runs sweetly, leave it alone.
    If it runs roughly, if there's been any fuel left in the carbs, you've
    got gummed-up carbs and you may have a terrible job. Simply cleaning and
    blowing through the jets often is not enough - you need to strip them
    right down to the last component, and maybe have them ultrasonically
    cleaned.
    Seriously - modern lead-free fuels leave a terrible residue and it
    collects in all the galleries and nooks and crannies.
    If you have the carbs cleaned and it then runs fine, leave it alone.
    Only start tearing the engine down if it smokes, rattles or misbehaves
    elsewhere. In other words, if it ain't broke, don't fix it.
    The Older Gentleman, Jun 13, 2004
  6. Dear God. Go and *buy* one.
    The Older Gentleman, Sep 16, 2005
