Kawasaki KZ / Z550 Teikei Slide Carbs
Discussion in 'Classic Motorbikes' started by dcbennett, Sep 28, 2003.
  1. dcbennett
    dcbennett Guest
    Hi,
    I've got a '82 KZ550 which was piddling petrol due to knackered float
    valves so I decided to do a carb rebuild.
    Got a set of four K&L 18-2462 repair kits and off I go - but....
    The jet needles in the repair kit are not long enough to bottom out on
    the main jet screwed into the needle jet. They are about 1cm shorter
    than the original needles on the KZ550 carbs.
    Never mind, I've got a 2nd set of carbs off an old Z550 and the
    needles are the same length as the repair kit so I decided to rebuild
    that carb instead.
    All fine until I notice that the jet needle stops well short of the
    main jet - and the original Z550 carb was like that as well. Now
    confused.
    Questions:-
    Has someone before put the wrong jet needle in the Z550 carbs?
    Are the jet needles supposed to bottom out on the main jet so the idle
    jet does the idling??
    Will I get away with it if I rebuild anyway - the bike did seem to run
    OK when I tried the old Z550 Carbs on it before rebuild (Well, three
    cylinders did anyway!)
    Thanks
    David
