Kawasaki GT550 problem (maybe)
Discussion in 'UK Motorcycles' started by Sartois, Oct 28, 2005.
  1. Sartois
    Sartois Guest
    Hi,
    I was wondering if you could give a little advice re. a problem I'm having
    with my GT550. Esentially, when running (although admittedly not
    for very long) the left exhaust pipe is showing visible fumes - a normal
    grey/white colour but the right exhaust isn't. Is this a problem?
    The bike hasn't been used much recently and has been sitting in my garage
    but I turn it over occasionally to keep the battery up and to heat
    it up.
    Any advice?
    Thanks,
    Alex.
  2. Do you per chance leave the bike on It's side stand in the garage?
    eric the brave, Oct 28, 2005
  3. Sartois:
    If the bike is left on it's side stand, ther will be more condensation
    to "burn off" in the LHS silencer.
    My 450 does this and, as a result, has corroded internally and the
    baffle has detached itself.
    FrJack @ work, Oct 28, 2005
  4. Sartois
    Zanziba Guest
    Does that mean that on the center stand niether or both would corrode?
    Zanziba, Oct 28, 2005
  5. Similarly, oil will collect in the left-hand end of the cam box, and
    frequently manifest itself as a cloud of smoke first thing. BMW Ks were
    notorious for it.
    The Older Gentleman, Oct 28, 2005
  6. Zanziba:
    I think you can work that out..... unless you are a bit dim.
  7. The Z550 could actually fill up it's LHS carb float bowl with oil.
  8. Sartois
    lushhead Guest
    And the R series bikes
    lushhead, Oct 28, 2005
  9. The Older Gentleman wrote
    I have a question arising from this.
    Since those very nice policemen returned the fucking bindit to my care
    there has been a rearrangement of the parking outside my front door. For
    reasons of convenience when arriving and leaving the GS has moved 6 feet
    closer to the road, to an area not formerly used for parking bikes and
    with a surface of gravely sandy dirt about 2 inches in depth which is
    really rather unsuitable for a side stand.
    Partly as a result of my being forced much against my desires into
    changing my pre-riding routine to accommodate the cunting fucking stupid
    annoying piece of shite called an alarm I now am in the habit of
    starting the engine and leaving it to run while I fiddle about with
    straps and zips and buckles and stuff.
    This would be fine were it not for the recent alterations to parking
    patterns and the extra lean arising from the poor surface and the worn
    valve guides. On a calm day I can fill the well sheltered on three
    sides front garden with smoke. Good it is.
    How can I get it coloured?
    steve auvache, Oct 28, 2005
  10. Sartois
    http://www.raf.mod.uk/reds/dyeteam.html
    platypus, Oct 28, 2005
  11. steve auvache, Oct 28, 2005
  12. Sartois
    Zanziba Guest
    I'm the whole 5 watts
  13. Cos the majority of what comes out of the zorst pipe is water vapour.
    GS850 x2 XS650SE / SE 6a
    Grimly Curmudgeon, Oct 28, 2005
  14. Sartois
    Sartois Guest
    yes indeed, spookily surmised
    i'll put it on the centre stand
    Thanks
    Alex.
  15. Sartois
    Zanziba Guest
    Isn't it more likely that the water condenses when the engine is started
    (Water vapour created during burning of fossil fuels condenses on COLD
    exhausts?).
    I don't see how water can condense on a hot exhaust when you turn the engine
    off.
  16. The mufflers are full of water vapour which has nothing to do but cool
    down. It's certainly not going anywhere.
  17. Sartois
    Zanziba Guest
    The amount of water you are talking about there would be tiny and comletely
    insignificant. Think about the space that there is in the mufflers, 1000cc
    maximum? (Complete guess). Now that's 1/24 of a mole of gas at room temp and
    pressure, at the temperature of exhaust gases it is much much less. PV=nRT
    (Gas law).
    Now there are a variety of gases in the exhaust of which water vapour is
    only one:
    Fuel + Oxygen ===> Carbon Dioxide + Water (+NOx)
    That all equates to tiny amount of water that would hardly make an exhaust
    "Smoke" on restart. (Think about a car driving down the road on a cold
    morning, water can actually be seen dripping from the exhaust, this is being
    made by the running motor and then condensing against the exhausts as they
    are still cold?
  18. Sartois
    DEATH Guest
    On Fri, 28 Oct 2005 13:43:49 +0100,
    It was oil seeping past the rings. ISTR hearing that the 16-valve or
    maybe the 1100 got pegged rings to alleviate the problem.
    Mine smoked dreadfully if left for a few minutes when hot on the
    sidestand.
    DEATH, Oct 28, 2005
  19. Yes, of course. Once the system's up to temperature the condensation
    isn't much, if any, and any condensed water is evaporated out. When the
    system's cooled down after shutdown that's when the condensed water
    vapour with its dissolved acids does the damage.
    On a longer timescale it's not unknown to start up a bike after a winter
    layup and find the baffles are a bit knackered after a few days running.
    All that internal corrosion taking place over a few months takes its
    toll on the system.
    For long term ownership, stainless exhausts are the way to go.
  20. Sartois
    I keep forgetting to change the settings, is all.
    Pip Luscher, Oct 29, 2005
