Kawasaki Fuel Gauge Fault
Discussion in 'UK Motorcycles' started by Andy Bonwick, Sep 14, 2008.
  1. Andy Bonwick
    I think you already know the answer.
  2. Andy Bonwick
    Latest gremlin on the GT750...
    The fuel gauge has packed up - not really a problem but I can't identify
    why, so many brains and all that.
    It started randomly showing all manner of levels then it decided it was
    empty and flashed the bottom LCD block and the red warning light flashes
    (now covered with a bit of tape as it's bloody bright). It had decided
    it was half full for a bit yesterday (it's got a full tank) but is now
    back to utterly empty.
    Here's the wiring diagram:
    http://www.sweller.co.uk/docs/KawasakiGT750Diag.pdf
    The sender works within spec.
    What doesn't seem right is the voltage at the connector of the fuel
    sender (item 38 on the diagram). I assumed the BK/Y wire is the feed to
    the sender which varies the voltage and returns it via the W/Y wire to
    the gauge which displays as appropriate.
    The Bk/Y connection on the loom side is 0v and the W/Y connection is 5v.
    I've tried connecting the sender (Bk/Y) to the battery (12v) and
    connecting output from the sender to the W/Y on the loom. I expected the
    gauge to show the tank level - it didn't.
    It's an irritant that it doesn't work - ideas?
    sweller, Sep 14, 2008
  3. Andy Bonwick
    Yes, I know but I would like to fix it as the red flashing warning light
    (that I've covered with tape) also warns of other disasters - value of
    the bike aside.
  4. Andy Bonwick
    look at the battery: bk/y is earth
    so, it would seem that that the signal wire is held "high" when the tank is
    full. As the fuel float moves it adjusts a variable resistor which will
    eventually ground the signal line, as the tank empties. When that line is
    grounded the red light attached to the signal line comes on (item 19).
    There must be some circuitry in the LCD unit, 26, that works out the fuel
    gauge reading as the voltage changes.
    My diagnosis: most likely there is a short/low resistance to earth on the
    signal line W/Y (assuming the splodge is a W). Of course, if you fix the
    short, the pull up resistor might be burnt out or the LCD circuitry might
    be fucked.
    wessie, Sep 14, 2008
  5. Andy Bonwick
    FCS Guest
    Is it at all possible to graft a traditional needle
    guage (i.e., analogue) assembly from an earlier
    GT750? That would be my preferred solution in
    your position, if possible.
    Then again, later analogue guages still require
    the ignition on to read how much fuel is in there.
    I can't see why it would need a dummy load so
    one alternative is to disconnect it, take advantage
    of the of extra egg-cup-full of fuel you'll be able to
    fit in the tank, and leave the red LED warning light
    to flash up the rest of the other warnings as and
    when they may occur.
    A custom tank made of glass is another way if
    you're really not capable (I know you are) of doing
    the mathematics involved in working out how many
    miles it is since you last refuelled.
    Then again, you're talking to a guy who tunes
    guitars using anything from iolated piano notes in
    chart music to the numeric manual input tones
    on a mobile handset.
    I'm going to have to find a way to coax a major
    sawmill to my exhaust note.
    G DAEB
    COPYRIGHT (C) 2008 SIPSTON
    FCS, Sep 15, 2008
  6. As there was no such assembly ever fitted to any GT750, I'd say not.
    The Older Gentleman, Sep 15, 2008
  7. Andy Bonwick
    Eh? I think you must be somewhat confused.
    Champ, Sep 15, 2008
