kawasaki 2002 vulcan 800
Discussion in 'Motorbike Technical Discussion' started by jacques milot, Jul 15, 2003.
  1. My friend have some problems with his new Kawasaki vulcan 800 2002. The
    engine stop for no reason and will restart by it's self after the gas tank
    is switch to primer (sometimes) with a half gas tank full. The dealer can't
    find the problem. Anybody have the same problem ? My Yamaha FZ1 2001 is
    working fine...vroummm.
    Jacques
  2. Your description was a little vague as to how the engine stops, does
    it stop abruptly or slowly dies like it is starving for fuel?
    Assuming it is acting like a starvation problem for fuel rather than
    abruptly like an ignition problem, when it stops running pull off the
    fuel line at the carb or carbs and check to make sure there is an
    adequate amount of fuel, what happens if you let is just sit for a
    period and cool down without switching the tank valve? will it start
    fine then? if that is the case and runs well until the engine becomes
    hot again, my guess would be a vapor lock problem. If that is not the
    case in the regards to the engine heating up, there might be a problem
    with something restricting the fuel either at the valve or in the tank,
    you might have to remove the valve assembly and check the pickup screen
    inside the tank.
    If on the other hand the engine dies instantly with no missing or
    hesitation, I would be looking into the idea of it losing the ignition
    circuit, and that you can check by having a spare spark plug and
    grounding the threads to the engine and checking for spark by removing
    one of the plug wires and installing it on your spare plug you have
    grounded to the engine.
    I hope that helps some,
    David
    95 Nighthawk 750, Jul 16, 2003
  3. Thanks for your info. My friend told me that the last times his motorcycle
    stop he noticed that the motor was acting like he was running out of gas. We
    will try out this and let you know. Thanks again David.
    Jacques
    jacques milot, Jul 17, 2003
