Last fall my parents brought my Katana from home to Lincoln, where I go to school. Dad started it and drove it onto the truck just fine. When it got here, it got rained on a bit, not while driving down the highway. The water has never hurt it before. (I know this isn't good, but I'm sure I've learned my lesson now) We got it off of the truck and it won't start. No solenoid click or dimmed headlights or anything. I tried charging the battery and using the charger on the jumpstart mode with no change. It acts like the kill switch is on, so I tried checking the fail-safes. I took the switch housing apart and cleaned the starter and kill switch contacts as best I could with alcohol. Then I used a voltmeter across the terminals to verify there was a voltage difference in the open switch (i.e. there is power to these switches) and that the closed switch had no voltage difference (the switch works). So I eliminated the starter and kill switches. The neutral light comes on, so I'm fairly certain that sensor works, and if it didn't, it should start with the kickstand up and the clutch in, (it won't). It should also start kickstand down in neutral. So, it isn't either of these sensors, unless they are both bad, right? So I think I eliminated them as the problem by logic. So, now what can i do? I think schematics and tracing wires for good connections is next (I checked the fuses over the battery, are there more?). Where can I get schematics of the bike? Would a clymers manual or something like that be any help? I can get an Electrical engineer friend of mine to help me read them, but I don't really know where to find them. Does anyone have the schematics for this bike? (2000 suzuki Katana gsx750f) Any help or suggestions are welcome. I'm at the end of what I can think of as far as solutions. The only advice I got so far was to smack the solenoid with a mallet incase it was stuck. I'm not sure about that. Thanks in advance. -Tim
