K100 service
Discussion in 'Australian Motorcycles' started by Peter Cremasco, Nov 8, 2003.
  1. Just doing a major service on the Beemer, after a very glorious 7000 km
    and three weeks through NSW and Vic and down to the Island for the GP,
    and am again bemused that a country with such a reputation for
    engineering finesse managed to put together this bike.
    Don't get me wrong. I love the bike. Ate up the km no hassles, served me
    well under a variety of conditions but what a bitch to work on.
    Doing anything of note means removing the bloody fairing.
    Change air filter? Remove fairing.
    Change coolant? Remove fairing - multiple times (well, I would if I did
    it the way the manual suggests.
    Change fuel filter? Don't remove fairing - just pull the innards out of
    the fuel tank (actually, that's not really a chore - but I felt like a
    whinge).
    And why oh why did the engineer put the engine on THAT side, so that
    when on the sidestand the head is lower than the crankshaft? Do they
    have the sidestand on the right-hand side in Europe?
    Anyway, engine oil, oil filter, fuel filter, air filter, plugs, coolant,
    diff oil, gearbox oil and fork oil renewed today.
    Brake fluid and lube shaft splines next month (first available day).
    I had to put a new rear tyre on at Dubbo, on the way through. Chose
    (cause there wasn't anything else) a Pirelli MT08. Quite liked the
    handling, and after 6000 km the wear was quite good (about 40%), but the
    longitudinal cracks were a worry.
    Got the tyre replaced today, and the old one is heading to Brisbane to
    get looked at by Pirelli. Hopefully there will be some refund due. I was
    running it at 40 psi for most of the trip (the tyre is rated to 42) due
    to the weight I was carrying and the sustained 'high' speeds.
    What does a VB rating on a tyre mean? I've heard of a V rating, but
    never seen a VB before.
    Hopefully a fine day tomorrow. Heading up to the pub at Cooyar for
    lunch. :)
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  2. Peter Cremasco
    Smee Guest
    Peter Cremasco wrote:
    It means the inspector was drinking VB at the time of the inspection.
    Hence the quality of the tyre.
    Smee, Nov 8, 2003
  3. Peter Cremasco
    Nev.. Guest
    I think VR means the tyre has speed rating of V (210kph) and is a radial tyre
    while VB has the same speed rating with bias belts.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 8, 2003
  4. Peter Cremasco
    smack Guest
    but the
    around the sidewall? My duc had cracks in the sidewall, was replaced free
    smack
    smack, Nov 8, 2003
  5. Peter Cremasco
    smack Guest
    smack, Nov 8, 2003
  6. Peter Cremasco
    SimonL Guest
    Geez pete, must be your time of the month.
    I have a 86 K100RS which I purchased in 87, sold in 98 and repurchased back
    in 01 which now has 315.000k's on the dial.
    Mate, you must be holding your tongue the wrong way or your smoking
    material is better than mine because I have never had to pull my fairing off
    to change the coolant or the airfilter.
    Try putting your tongue on the RHS of you mouth might help.
    SimonL.
    SimonL, Nov 8, 2003
  7. Rated to carry 2 slabs of green stuff that is misleadingly marketed as
    beer....
    Geoff and Jodie
    Geoff and Jodie, Nov 8, 2003
  8. Thank you, oh great one. That now makes perfect sense and explains the
    state of the tyre.
    [that HAD occurred to me]
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  9. Hmmm. Bias belts? Does that mean a nylon or what we used to called a
    'rag' tyre?
    I know the one that cracked (with the VB rating) was 130/80. The one I
    have on now (recommended) is 130/90 and has just the V rating but is
    stamped as 'nylon'.
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  10. No. Running along the treads in the centre of the tyre.
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  11. That is entirely possible. After a beautiful month off, it's been a
    shitty week back.
    I believe the RS has a smaller fairing (doesn't extend down the sides as
    far) and therefore can understand how you can change the air filter
    without removing panels.
    But how do you do the coolant? The radiator cap is under the fuel tank.
    To take the fuel tank off, I have to remove the inners off at least one
    side panel, as the covers come OVER the outer bulge of the tank.
    I do that often enough when I have tongue in cheek. :)
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  12. btw: has yours got that annoying knock at low revs when the engine is
    cold? I've got 170,000 on the clock, and when I start it on a cold
    morning it sounds like a diesel tractor.
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  13. Peter Cremasco
    They're all "rag" tyres Peter.
    Ain't no such thing as a steel-belted for motorcycles.
    [insert all of the examples where I'm wrong here;
    Bias belt is "crossply" (as opposed to radial). They're stiffer and
    generally higher profile but they run hotter than radials.
    Clem
    Knobdoodle, Nov 9, 2003
  14. Pirelli Dragon & Dragon GTS are zero degree steel belted radials.
    Pegasus
    Andrew Hatcher, Nov 9, 2003
  15. Be glad you don't have an oilhead. I was horrified at the last BMWMCQ
    service day to see how much plastic has to be removed to do an service on a
    R1100RT. At least on the K100 there is a reasonable gap between the airbox
    lid and the top frame tube. K1100 has a larger airbox lid and is a real
    bitch to remove (until you learn to lubricate the edges).
    Pegasus
  16. Peter Cremasco
    Boxer Guest
    I don't have to remove anything to service my Oilhead or Bricks, that's
    Ray's job.
    Boxer
    Boxer, Nov 9, 2003
  17. I know mine has and it has only 140,000 on the clock. I think the bike
    has done more than this, the speedo isn't the most reliable.
    __
    Cheers
    The Happy Drunk
    K100RT
    The Happy Drunk, Nov 9, 2003
  18. Peter Cremasco
    conehead Guest
    BMW means Big Man's Wheels, not Bloody Moaning Whinger. :)
    conehead, Nov 9, 2003
  19. I had to put a new rear tyre on at Dubbo, on the way through. Chose
    Pirelli Match comes in either crossply or bias belted, VB means its a V
    rated tyre with bias belt construction. They suit K100s well.
    Al
    Alan Pennykid, Nov 9, 2003
  20. Peter Cremasco
    conehead Guest
    Belly, left fairing, right fairing, tank shroud. That's hardly daunting is
    it? About 17 fasteners per side, though, IIRC
