K&N Air Filters
Discussion in 'UK Motorcycles' started by Magpie, Jan 30, 2006.
  1. Magpie
    Magpie Guest
    Decided to strip the zx6 and treat her to some acf-50. In doing so I
    noticed the air filter is a k&n however it seems to be installed upside
    down [1]. Does this restrict the airflow at all?
    As im pretty new to bike mechanics anything else worth doing as I've got
    the thing naked? Carbs been balanced already.
    [1] I presume the this way up sign should be face up in the airbox, you
    never know.
    ______________________________________________
    Ken
    ZX636 ninja
    *Remove knickers to mail me
  2. Magpie
    Kevin Stone Guest
    Then why do they print an arrow?
    Kevin Stone, Jan 30, 2006
  3. Magpie
    Vass Guest
    the seals at each end may differ?
    Vass, Jan 30, 2006
  4. Magpie
    antonye Guest
    As far as I know, K&N use a constant size of foam throughout their
    product, so it will not make any difference which way up you fit it.
    I know that Pipercross (which I use) uses different types of foam
    in layers which filters different size particles (ie, large to start
    with
    then smaller) so it does matter which way round you fit it.
    Might be worth checking the instructions if you have them, or
    check their website for an electronic version or more info?
    antonye, Jan 30, 2006
