just an idle question
Discussion in 'Motorbike Technical Discussion' started by paul c, Jun 16, 2008.
  1. paul c
    paul c Guest
    I presume on most bikes that have a battery and negative ground that the
    main fuse, 10 amps or bigger, is always on the positive side, I guess to
    help protect the battery from meltdown or explosion. Never having seen
    a bike with positive ground and not having paid attention to father's
    old A40 Austin, I'm guessing that even negative ground systems have a
    main fuse on the positive side. Is this so?
    (Maybe not a very important question, I admit, just something I keep
    wondering about.)
  2. No, positive ground systems put the fuse on the negative wire.
    Les
    Project Magnet #1, Jun 16, 2008
  3. paul c
    Who Me? Guest
    Thanks for answering the question he THOUGHT he was asking !! ;-)
    Who Me?, Jun 16, 2008
  4. paul c
    paul c Guest
    Thanks to Project Magnet, yes, but even if it makes me sound dumb, I was
    really thinking that the fuse would be nearest the positive terminal in
    both systems. My reason had to do with what I take to be the actual
    direction of current, as opposed to the so-called conventional
    direction. Perhaps it's simplistic but I reasoned that for protecting
    components, it might be better to fuse them 'before', as it were, they
    reach the current reaches them. (Physics is not my talent, but liking
    bikes, I can't avoid electrical theory.)
  5. A fuse on the grounded + side of the circuit won't protect against short
    circuits on the - side.
    Les
  6. I read enough to know what he was asking, just not enough to read what
    he was asking...
    Les
  7. No, current flow is essentially instantaneous, electrons/holes
    moving around the whole circuit in concert. The individual charge carriers
    don't move quickly but the current as a whole moves near to the speed of
    light.
    Dr Ivan D. Reid, Jun 16, 2008
  8. paul c
    Who Me? Guest
    Utterly ridiculous. Of course it would.
    It takes a complete circuit for current to flow; doesn't make any difference
    WHERE you open it.
  9. paul c
    Brian Guest
    That's why the fuse goes in backwards on positive grounded systems ;)
    These fuses don't protect the components, they protect the wiring.
    Current is continuous all the way around. To answer without getting
    long winded, for your example, it doesn't matter where the fuse is.
    And you don't want to fuse the grounded side, as that just
    leads to problems and lack of protection.
    Brian, Jun 17, 2008
  10. paul c
    paul c Guest
    That makes a lot of sense to me (given your point about the fuse
    protecting the wiring).
    paul c, Jun 17, 2008
  11. The Rule of Thumb in ALL electrical wiring is that -whatever- is connected
    to "Earth" Ground is NEVER fused.
    I realize on a motorcycle with rubber tires and no part of the frame
    actually connected to a real Earth ground, that the concept of the frame
    being at Earth potential is mainly theoretical. Also, the voltages involved
    are so low that they will not kill you (ie: 12v hand to hand isn't going to
    stop your heart) Thus, fuses and/or circuit breakers aren't considered
    "safety" devices as such, at least, not safety devices for people.
    However, the principles followed are the same
    Telephone systems are also positive-grounded (ie: -48 volts DC) and
    they actually do have their + side connected to a true Earth ground
    (generally
    a copper rod driven into the ground) Those also are NEVER fused on
    the ground side.
    AC power systems also follow the same rules - any Neutral line that
    is connected to Earth ground is NEVER fused, it is -illegal- to fuse it.
    Ted
    Ted Mittelstaedt, Jun 17, 2008
  12. paul c
    paul c Guest
    Ted Mittelstaedt wrote:
    Right, I should have thought of that in the first place. Thanks.
  13. paul c
    Who Me? Guest
    This is a hypothetical discussion, since it is virtually never done
    but............
    A fuse that removes the common/ground side of a circuit or circuits
    completely from the power supply certainly would stop the current
    flow.......completely. You cannot "short circuit" something that has no
    current flowing in it because the voltage potential is the same at every
    place in the "circuit".
    In the case of DC vehicle systems, a very effective and recommended way to
    prevent damage from an accidental short is to disconnect the ground lead
    from the battery.......as if there was a fuse there that has operated.
    Doesn't apply to earth ground systems like commercial AC because "you" have
    no control over the power supply and it is always connected to ground.
    AND.....back to the original premise.......a fuse doesn't "protect" against
    short circuits regardless of where it is placed. It protects the wiring and
    power supply from releasing THEIR smoke.....along with the component that
    has already failed. A properly sized fuse WILL perform that function quite
    nicely, regardless of where it is placed in the circuit.
    Who Me?, Jun 18, 2008
  14. change "virtually" to simply "never"
    Unless you have a wire chafed somewhere, in which case your ground
    is now reconnected and you have current flow. That's why we don't
    fuse common/grounds, period, in ANY power system.
    No, that is not true. The recommended way to prevent damage from
    an accidental short is to disconnect BOTH battery terminals and REMOVE
    the battery from the system.
    Having a live battery in there will not prevent a short - all it takes is
    absently setting a bolt on top of the tank with the seat removed, and
    bumping the bike to have the bolt fall and wedge in between the battery
    negative terminal and ground while you have the wiring hanging out
    elsewhere on the bike.
    Or for more fun, drop a screwdriver in there and short the battery
    out alltogether.
    The PRIMARY purpose of a fuse is safety of human life. The bike maker
    doesen't give much of a crap if the wiring or component shorts and melts.
    Wires are pretty easy to replace. What they DO care about is if the
    component
    shorts then gets so hot it melts and starts a fire. If that were to happen
    while you
    were flying down the road you might wreck and that's not very good for
    sales,
    you see. The secondary function is to protect the wiring and/or components.
    And placing the fuse in the ground side of the circuit isn't going to
    protect
    anything since any component that has a supply lead going to it that fails,
    can
    potentially fail in a manner where the internal electric conductors short
    against the chassis.
    Ted
    Ted Mittelstaedt, Jun 18, 2008
  15. paul c
    Who Me? Guest
    Some good points and some not so. Are you REALLY so dense that you don't
    see that disconnecting the common side of the battery from the chassis
    renders the entire "loop" DEAD......falling bolts and screwdrivers not
    withstanding ?? In that case, a conductor shorted to the chassis is no more
    likely to cause a problem than if the battery is completely absent.
  16. paul c
    the fly Guest
    The short circuit is, by definition, ANOTHER path to ground,
    different from the normal path. Unless you remove the main battery
    connection to ground, current can and will flow in an energized
    circuit wherever insulation is parted and the conductor makes contact
    with another conductor which is at ground potential.
    the fly, Jun 19, 2008
  17. Interesting that you quoted the section of my response dealing with
    fusing grounds, yet replied to the issue of disconnecting the battery
    common,
    oh well.
    If you HAD quoted the section you were responding to you would have
    also read the part where I explained that if a bolt or screwdriver fell
    and jammed against the negative post, it would energize the bike
    again. Not a good thing when the mechanic is _assuming_ the bike
    circuits are dead, and undoubtedly has the wires in a state of disassembly
    with connectors laying everywhere and on everything.
    The poster had said "the recommended procedure"
    The "recommended procedure" is to remove the battery. That
    doesen't mean we always do the recommended procedures,
    naturally.
    As long as the battery is in the motorcycle, unless you have covered
    the terminals, there's a potential for something falling on it and
    shorting the battery. This is where common sense is supposed
    to kick in. Most people probably would not bother doing more than
    disconnecting the battery common if they were simply replacing a
    starter. Most people would probably remove the battery if they
    were going to pull an engine. But, just because most people would
    judge leaving a battery in the bike while replacing the starter as
    OK if the negative was disconnected, does not mean it is completely
    safe, nor does it mean that it's no more likely to cause a problem
    than if the battery is absent.
    Ted
    Ted Mittelstaedt, Jun 19, 2008
  18. The factory dealers make good money fixing this kind of problem. The
    only reason the factories aren't just using straight wire instead of fuses
    is
    they are afriad of being sued. A straight wire is cheaper.
    A lot of car electrical systems for a long time used non-fused connections
    for the vehicle turn signals. My 68 Ford was like that. It saved the
    vehicle manufacturers maybe 3 cents to not put a fused circuit in.
    It cost me about $30 to have to buy a new steering column turn
    signal switch when the old one melted because one of the turn signal
    wires chafed through in the fender.
    Trust me, the vehicle & bike manufacturers really honestly give a shit
    about your pocketbook and safety about 2 millimeters further than their
    lawyers
    and the government tells them they have to. Do you really think they would
    put in crumple zones, airbags, and the like if the government didn't
    mandate it? Come off it. Airbags were around 2 decades before they
    put them in cars, and they only did it because the government told them
    they had to. And the idea that a motorcycle manufacturer even cares
    as much as a car manufacturer is laughable. Otherwise they wouldn't
    be selling 200HP bikes to newbies, or putting $600 worth of
    useless plastic covers that shatter when the bike is leaned against
    a fire hyrant. It's all about producing products that have obsolescence
    built in.
    Ted
  19. paul c
    Who Me? Guest
    No, it isn't. A short circuit is a connection between 2 points in the
    device where there is not supposed to be a connection. It might involve
    neutral/common/ground but doesn't have to.
    Pay attention:
    Who Me?, Jun 19, 2008
  20. paul c
    Who Me? Guest
    Do try to follow along, Ted. I commented on the part that I quoted.
    What do you think happens when a fuse operates? Clue: It becomes OPEN and
    breaks the connection. If that fuse is connected between the common side of
    the battery and chassis ground, then the chassis is no longer a part of the
    circuit. At that point, it doesn't make any difference what touches the
    chassis.
    What you say about the potential for accidentally re-connecting neg. to
    ground is of course true but it would not be a problem unless the person
    doing it is so brain dead that he ALSO simultaneously grounds the positive
    terminal. Can it happen? Sure. Likely enough to mention every time the
    subject comes up....not hardly.
