The ongoing saga of the Jag bearing [1] As I posted recently I had it apart and I find a completely dry bearing - not the slightest whiff of grease! See [2] To make my description easier I've extracted the exploded diagram from the parts book: [URL]http://www.sweller.dynalias.org/docs/jag38s_rear_suspension.pdf[/URL] My problem is the hub (part 29) is slightly damaged and is now slightly shorter than before so setting the endfloat is a bit tricky. The largest available shim (part 35, which I have) is 0.151" (3.84mm) which gives an end float of 12 thou - I need a 0.160" (4.05mm) shim to get an endfloat of 4 thou (range is 2 to 6 thou). That is, shall we say, in production. However, in the interim I need to use the car with the mashed parts replaced but the original hub (see [2]) and excessive endfloat. So what are the short and long term effects of running with an endfloat of 12 thou rather than 2-6? [1] Oh dear - Squeaky. [MEDIA=youtube]vP-XxL90gEg[/MEDIA] [2] Dry [URL]http://www.flickr.com/photos/47192463@N03/4368853204/in/set-72157623462142046/[/URL]
