It's sulking
Discussion in 'Classic Motorbikes' started by Lady Nina, Dec 11, 2007.
  1. Lady Nina
    Adrian Guest
    Austin Shackles (Austin Shackles
    It raised my eyebrows, too. Apparently they _always_ make sure the car
    end is plugged in first.
    Adrian, Dec 12, 2007
  2. Lady Nina
    The Kenlowe Hotstart has been available for aeons:
    http://www.kenlowe.com/pre-heaters/cars/whatwill.html
    Might be overkill on a Benly, though.
    platypus, Dec 12, 2007
  3. I prefer not to rely on that sort of assumption, myself.
    Austin Shackles, Dec 12, 2007
  4. Lady Nina
    It has occurred to me that, from an eco POV, using a car cap or some sort of
    blanket on the windscreen would be better that leaving the engine running
    for twenty minutes and the blower on defrost.
  5. when it's really cold I fire up the bus 10 minutes before departure time.
    Plug-in pre-heater would be more effective, and would actually get it to
    operating temperature, which 10 minutes at idle doesn't.
  6. I tried doing that this morning,m and thought I'd be clever and lock the
    doors just in case an enterprising tea-leaf happened by. Inscos don't
    pay out if you leave a car with the keys in and running, do they?
    That's when I discovered that the remote keyless entry system on the
    Nissan Silver Tuddy doesn't work when the engine's running. Ho hum.
    The Older Gentleman, Dec 12, 2007
  7. oops. it's trying to stop you being carjacked, I expect.
    no such nonsense on mine, and anyway, it's in the yard, not on the road.
  8. Lady Nina
    ts Guest
    They've been around for three decades or more. Often combined with
    electrical heaters for the coupé, complete with a timer so you don't
    have to get out of bed to turn them on in the morning. Made quite a
    difference when the temp. dropped to -35 °C in late February, central
    Norway.
    You could also get petrol fueled heaters on as well, for those who
    regularly parked away from a mains supply.
    Some years ago (10+ ?) Saab were experimenting with thermal insulation
    of the engine block, to presvent it from cooling overnight. Can't
    remember if it never caught on because of technical difficulties, or if
    they realised that it would be a too narrow niche product. Although it
    would have helped to minimize wear and fuel consumption also in less
    chilly climates.
    ts, Dec 12, 2007
  9. Eek =:-0
  10. Lady Nina
    I thought you were going to get rid of that before the warranty ran out or
    it failed again?
  11. Changed my mind. It's worth sod all, basically, so I might as well keep
    it, run it into the ground, or until the turbo goes bang, whichever
    comes sooner.
    It's actually a decent motor. When it's going well. Which it is atm.
  12. Lady Nina
    Mark Olson Guest
    <Googles>
    The Toyota Prius has a "thermos" bottle that stores the engine
    coolant to avoid having to warm it up again, saving a small
    amount of energy and reducing emissions. It takes about 3 days
    for it to cool down to ambient temperature.
    Mark Olson, Dec 12, 2007
  13. Lady Nina
    Lady Nina Guest
    If it still will not start next time I attempt it then I'll try this.
    Lady Nina, Dec 14, 2007
  14. Lady Nina
    Lady Nina Guest
    Not yet. I've been busy. And it's cold in the garage.
    <thinks about why she's sorting the Benly>
    <buries head in hands>
    It's a lovely bike but it should have been 12v. Then I could have
    bought a heated suit.
  15. Jamie's 125 Benly is 12v. And electronic ignition, no less.
    ACtually, I don't think the alternator would be up to that.
    (That was a typo above, but it was so good, I left it)
    The Older Gentleman, Dec 14, 2007
  16. Lady Nina
    adieefc Guest
    doesnt work on the 307 either. however, manually locking the door with
    the key does.
    done it every morning this week so far.
    Adie
    adieefc, Dec 14, 2007
  17. Lady Nina
    adieefc Guest
    dont worry. there'll be half a dozen manly[1] blokes there to either
    kick it over[2] or kick it into a snowhill and let you snuggle on the
    pillion seat.
    Adie
    [1] {thinks} this word should probably be removed.
    [2] I cant believe you havent done this already!
  18. Nissan is keylless, as I said... :-(
  19. Lady Nina
    Indeed. I was going to ask who you were planning to go with.
    _______
    ..'_/_|_\_'. Ace (bdotrogers a.t compaqnet.fr)
    Ace, Dec 14, 2007
  20. Lady Nina
    <polishes ringpiece>
    platypus, Dec 14, 2007
Similar Threads
Loading...
