it's jinxed, I tell you
Discussion in 'UK Motorcycles' started by darsy, Feb 8, 2005.
  1. darsy
    Preston Kemp Guest
    Shouldn't do, the design on the patent application needs four bolt
    holes in the garage floor & five holes in the door. The design may
    change a bit at the prototyping stage but I doubt the fixing method
    will be affected.
    Preston Kemp, Feb 10, 2005
  2. If you need somewhere to stay a little further out then shout.
    Adie
    Triumph 955iSS / GSF1200 bandit / CG125
    Adrienne M Bonwick, Feb 10, 2005
  3. I heard of that done & the offending car manoeuvred so that it was
    between two pillars with a minimal clearance, so that driving it out
    would be nigh on impossible.
    Boots Blakeley, Feb 10, 2005
  4. It was somewhere around Barstow, on the edge of the desert, when the
    www.cpc.co.uk
    SR04773 £94 and SR02140
    http://www.rfsolutions.co.uk/acatalog/products.html
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Feb 10, 2005
  5. darsy
    Ginge Guest
    Good job really, it'd be terrible if you were reading this and had left
    the kettle plugged in.
    Ginge, Feb 10, 2005
  6. Train from Derby to St Pancras then Picadilly line. Sorted. If you
    really /must/ drive, drop the car at Luton Airport Parkway station and
    train to St P. Fast frequent and (outside rush hour) cheap.
    Simon Atkinson, Feb 12, 2005
  7. Clamp the fucker and charge 'em 200 quid removal fee.
  8. darsy
    Lady Nina Guest
    Didn't go. Poorly, only just surfaced.
    Lady Nina, Feb 12, 2005
  9. Poorly? I had both lungs shot off in the war and I still caught the
    first train to Berlin.
  10. darsy
    Lady Nina Guest
    But you had access to the german uniforms. Until the dirt dropping out
    your trouser leg gave you away. Franz says Hi and hopes your arse is
    better.
  11. Better than waht?
  12. darsy
    Lady Nina Guest
    The east european ones he's having to use now. He misses you. The way
    his face contorted as he whispered your name was heartbreaking.
  13.
