it's jinxed, I tell you
Discussion in 'UK Motorcycles' started by darsy, Feb 8, 2005.
  1. darsy wrote
    Betcha they will be back for the booze. I have never met a scrote who
    wasn't also a wino.
    steve auvache, Feb 8, 2005
  2. darsy
    you wouldn't have thought so, no. To be fair, the R65 doesn't appear to
    have been crashed either.
    darsy, Feb 8, 2005
  3. darsy
    But, crucially, wasn't the clutch alright until you got it?
    Please add "imo" to above post.
    Champ
    GSX-R 1000, GPz 750 turbo, ZX7RR Endurance Racer x 2
    GYASB#0 BotToS#2 BOTAFO(T|F)#35 WG*#1 DFV#8
    Team UKRM Racing : www.team-ukrm.com
    Champ, Feb 8, 2005
  4. darsy
    Eddie Guest
    Oh, yeah. It is partially fucked, though, which was what I meant.
    Eddie, Feb 8, 2005
  5. darsy
    true, true. But the reason the clutch is fucked, is because the carbs
    were causing over-revving, requiring a lot of clutch slip.
    The carb problem pre-dates my ownership of the bike.
    darsy, Feb 8, 2005
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    It fucking doesn't matey. That bike was running fine when you got it, in
    fact it had just had new float needles fitted to stop one of them
    overflowing.
    Wicked Uncle Nigel, Feb 8, 2005
  7. darsy
    *chomp*
    darsy, Feb 8, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    What*ever*
  9. darsy
    darsy says...
    Champ's influence
    Lozzo, Feb 8, 2005
  10. darsy
    Dan L Guest
    Utterly unspeakable cunts.
    Hanging's too good for 'em.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Feb 8, 2005
  11. darsy
    No, you can put it in gear; the neutral indicator goes out, and the
    wheel locks with the engine so you can't push it. But pulling the
    clutch lever in doesn't free up the back wheel.
    The lever feels as before. However, and this is the possibility I'm
    hoping is the case - the lever is pretty badly bent towards the grip -
    I'm thinking maybe that even pulled fully in so the lever is touching
    the grip, the amount of bend means the clutch isn't fully disengaged
    (or is it engaged, I can never remember).
    darsy, Feb 9, 2005
  12. darsy
    darsy wrote:
    [snip]
    an update. Had the SOCO out this morning. He pointed out something that
    should have been fundamentally hyper-obvious vis-a-vis the security
    arrangements on my garage doors. He was in full approval of the new
    hasp/latch I bought and fitted yesterday to replace the rubbish one
    that the scrotes managed to jemmy off. And he liked the look of the new
    circle-type padlock I got to replace the crappy u-lock.
    However, and though he said it probably wouldn't be an issue for random
    kids looking for a joy ride, he pointed out that a professional bike
    thief would be rather chuffed that the hinges on the garage doors are
    mounted and screwed on on the *outside*.
    So, I need to get 4 x bolts per door (2 top, 2 bottom) into the
    concrete floor/door frame respectively.
    It's going to be a pain in the arse getting in and out!
    darsy, Feb 9, 2005
  13. darsy
    I meant to address this point earlier.
    The area in which I live is at the edge of a "well do to" area. Where
    we are is "quite nice", and "good" in terms of crime-rate, school
    league table performance, etc.
    However, one of the problems with living in London is that no matter
    how nice an area you are in, there is always somewhere shitty within a
    couple of miles at the most.
    darsy, Feb 9, 2005
  14. darsy
    darsy wrote:
    [snip garage security]
    There always has to be some sort of a compromise. I have
    a garage with space for a car parked in front of it but there's
    no driveway as such. I occasionally get idiots parking in
    this space while they go shopping or whatever, thus blocking
    the garage. This despite there being a large "private: no parking"
    sign.[1]
    One option I have is to put in a removable or hinged post but
    that means having to move it every time I want to get the car
    in or out of the garage. I think that for the number of times
    the garage gets blocked it's probably not worth doing it and
    then needing to remove the thing every time.
    [1] It's really amazing how people react when you point
    out that a) they're on private land and b) they've blocked
    access to a garage. On one occasion I called the police
    as I needed the car, couldn't get in the garage and didn't
    know what to do. When they said they couldn't do much
    about it[2] I suggested smasing the window and pushing it
    out the way. Their reply was that I'd have to do it "while
    they weren't looking". It was around this point the owner
    turned up but trying to get an apology out of them
    was difficult until one of the coppers suggested that if
    they didn't apologise they might be subject to some
    "pretty stringent vehicle checks" once they drove onto
    the road.
    [2] They said they could called up a van to try to tow it but
    the positioning of the garage, the space and a wall in front
    doesn't make this an easy option.
    CT, Feb 9, 2005
  15. darsy
    Ginge Guest
    If there are 3 or 4 of you.... Bounce it..
    Ideally into a corner that can't be driven out of.
    Ginge, Feb 9, 2005
  16. darsy
    I've never been in that situation, but if I had no other choice, I
    wouldn't think twice about braking the car window and pushing it off my
    property.
    darsy, Feb 9, 2005
  17. darsy
    Of course, one can select a gear from neutral without the clutch.
    I think this is probably the prime candidate. A few quid on a pattern
    lever should see you right.
    Champ
    Champ, Feb 9, 2005
  18. darsy
    This is the thing with being security conscious, and contributory to
    the Blaney-stance on such things, to which I mostly subscribe - there
    comes a point when you are inconvieniencing yourself so much against
    the threat of an event that you might actually be better off
    acknowledging that the event may occassionally happen.
    My new place is in a "vary nace" square that is cheek-by-jowl with
    pikey-central. The garage has much better security than I had
    previously (internal bolts), and I'm trying to get into the habit of
    ensuring that I use them every time.
    Champ
    Champ, Feb 9, 2005
  19. darsy
    yes. I know.
    hopefully. I'll bend the current one out, and see if it fixes the
    problem this evening.
    darsy, Feb 9, 2005
  20. darsy
    I'm sure and it has been considered.
    However, you wouldn't get the car out of the way without it
    being on full lock so once inside the car you'd need to break
    the steering lock as well and I don't know if that's easy or not.
    ASCII art time - god knows how this'll come out is I'm posting
    from Google Groups.
    |1|2|
    |4 3|
    5
    =====6
    1 - neighbour's garage with wall on lhs.
    2 - my garage with wall on rhs
    3 - place where idiot's park (chain fence on rhs)
    4 - neighbour's car (never in garage) with wall on lhs
    5 - residential side road - not particularly wide
    6 - wall
    And I'm sure a criminal damage charge could be on the cards,
    regardless of the circumstances.
    Ginge's 'bumping' option would be the best next time
    it happens if I can get enough manpower.
    CT, Feb 9, 2005
