it's jinxed, I tell you
Discussion in 'UK Motorcycles' started by darsy, Feb 8, 2005.
  1. darsy
    the ZX7r that is.
    first, it attracts crazed asylum seekers, causing mild injury.
    Now, it's been nicked.
    Some scrotes managed to crowbar (or whatever) my garage door open, and
    made of with the thing (ignoring the 'blade, and the 60 or so bottles
    of wine, which is nice).
    Phoned the dibble, and after about 20-30 minutes of being put on
    hold/passed from one person or another, turned out the bike had been
    reported as abandoned about 7am this morning. Apparently it "didn't
    look damaged", though how they could tell given that it was
    pre-disastered on both sides is anyone's guess.
    Anyway, I trek over to where it's supposed to be (a 20 minute walk),
    and eventually after a further 20 minutes of searching, find it, lying
    on it's side in an alley. After picking it up, there's only two obvious
    things more wrong with it than before:
    1) the clutch lever is a bit bent, from where they've let it fall -
    don't thieves know how to work a sidestand?
    2) The key barrel / ignition area is a bit of a shambles. They'd
    chiselled the whole fucker apart, smashed the steering lock and pulled
    all the wires out.
    They'd obviously had a fair go at hotwiring it. In fact, they would
    have got away with it had it not been for the pesky immobiliser. When I
    got there, I deactivated the immobiliser, and rejigged the hot wiring.
    It started. So, I though I could ride it home. Uh-oh. The clutch lever
    doesn't appear to engage the clutch.
    Oh well, that'll be an hour of sweaty pushing-a-1/4-tonne-bike home
    then.
    It'll teach me to be blase about security - all bikes now firmly
    anchored to the ground/each other, and the 7R is now sitting in
    "alarmed and immobilised" mode rather than just "immobilised".
    Also, need to work out what's wrong with the clutch. Given the
    mostly-track nature of the bike, I'm tempted to ignore the broken
    ignition barrel, and just wire it through a switch; relying on the
    immobiliser/alarm for security.
    Two questions arising:
    1) how did the fuckers get it so far without getting it going?
    2) why did they take the 7R and not the 'blade?
    darsy, Feb 8, 2005
  2. darsy
    Eddie Guest
    Pushing it? Or stick it in the back of a van, then dump it when they
    realise it's immobilised?
    Hasn't the blade got HISS or something? Perhaps that's why they avoided it.
    Eddie, Feb 8, 2005
  3. darsy
    dwb Guest
    The Blade has HISS doesn't it? Maybe they're a bit numpty and decided they'd
    take the one most likely not to have an imoobiliser.
    What sort of garage do you have that can be crowbarred open as a matter of
    interest?
    (Someone did have a go at mine awhile back, but all they did was put a dent
    in the top of the door - subsequently the security has been somewhat
    improved so I think they'd need to pull it off now - made difficult
    considering there are two cars parked in the way.)
    dwb, Feb 8, 2005
  4. darsy
    <surprised>
    Given my knowledge of the anti-hotwire device on Kwacks, I'm surprised
    by this. Had they got all the wires out of the switch, or was part of
    the switch still in the circuit?
    ZX7Rs are much cooler than Fireblades.
    Please add "imo" to above post.
    Champ
    GSX-R 1000, GPz 750 turbo, ZX7RR Endurance Racer x 2
    GYASB#0 BotToS#2 BOTAFO(T|F)#35 WG*#1 DFV#8
    Team UKRM Racing : www.team-ukrm.com
    Champ, Feb 8, 2005
  5. darsy
    Eddie Guest
    Oh, and:
    http://groups.google.co.uk/groups?selm=&output=gplain
    Eddie, Feb 8, 2005
  6. Because they are fucking arseholes.
    Just an idea you may wish to consider:
    I have a cheap, battery powered alarm in my shed, which has a keypad and PIR
    activation. When the shed is locked, the alarm is always on. At night I
    plug a baby monitor in the leccy socket in the shed, the other half goes in
    the house. Although the alarm is only 110db, the racket transmitted via the
    baby alarm would be sufficient to wake me in the event of a break-in. Oh,
    ground anchors and FOAD chains are also worth having, if only as a visual
    deterrent.
    What an arse pain, it really pisses me off when some fucker decides to help
    himself to ones hard-earned.
    oldbloke at work, Feb 8, 2005
  7. darsy
    mups Guest
    darsy says...
    <snip tale of grand theft>
    You want to move to a less pikey area, you do. Somewhere up north
    perhaps...
    The same way you got it back?
    As others have said HISS, or maybe they just liked Kwacks. I'd have gone
    for the RG myself.
    mups, Feb 8, 2005
  8. darsy
    Eddie Guest
    Can you imagine having to push that thing for any distance?
    Eddie, Feb 8, 2005
  9. darsy wrote
    Bastards.
    They obviously don't know that you have mates who have semtex. Time to
    educate the thieving scrotes perhaps?
    Thieving scrotes are thick.
    steve auvache, Feb 8, 2005
  10. darsy
    double outward-opening wooden doors with semi-opaque glass at the top.
    They smashed the window, and crowbarred the hasp off. Oh, and on the
    other less-easy-to-get-at hasp, they simply twatted the (admittedly
    small) padlock off with a hammer or something.
    darsy, Feb 8, 2005
  11. darsy
    avoided it.
    yeah, could be that. Though I don't think it was a "professional job" -
    much more likely to just be local scrotes wanting something to race up
    and down the A10 - anyone who knew what they were doing wouldn't have
    taken a bike that had obviously been crashed at least twice already.
    snot and up-and-over door, mind.
    darsy, Feb 8, 2005
  12. darsy
    dunno. Well, there were five wires sticking out - they'd joined the
    brown and red ones together, and it looked like joining the blue and
    white ones would do something, so I tried it, and the neutral light
    etc. came on. The grey wire didn't appear to do anything.
    Note, it's not "right", because this set up would only function with
    the side-lights on.
    darsy, Feb 8, 2005
  13. darsy
    an hour's worth of pushing up and down hills?
    not an ideal bike for haring around London in the dark, mind you.
    darsy, Feb 8, 2005
  14. darsy
    the RGV? that would be a complete piece of piss to push compared to the
    7R.
    darsy, Feb 8, 2005
  15. darsy
    Oh, I have those, I just wasn't using them, because I find it a pain in
    tits. I'll start now, though.
    what has annoyed me most, and how I noticed in the first place, is that
    not content with breaking into my garage, they forced the lock on the
    garage/garden door (breaking the quite old wooden jamb) and had a poke
    round my garden. The thing I noticed was that they'd opened the door to
    the shed and obviously poked round in that too.
    I can't believe they left all the wine and champagne - presumably if
    there'd been beer, that would have gone.
    darsy, Feb 8, 2005
  16. darsy
    I can only presume these are different scrotes to the ones I educated
    after someone tried to nick my Seedy.
    darsy, Feb 8, 2005
  17. darsy
    Eddie Guest
    Yeah, just noticed that. Best not to screw a piece of twobyfour across
    the top and bottom, then; might make it a bit tricky to open.
    Eddie, Feb 8, 2005
  18. darsy
    Eddie Guest
    Yes, it would. I've lost track of which bikes you've got. I thought he
    was talking about the RGS.
    Eddie, Feb 8, 2005
  19. darsy
    heh - fair enough. For the record, the current stable consists of:
    RGV250 (not road legal in any way)
    R65LS (fucked clutch)
    ZX7R (most road legal, but gruesome)
    CBR929RR-Y (nearly stock, and so far uncrashed)
    all but one of the above previously belonged to a different ukrmer.
    darsy, Feb 8, 2005
  20. darsy
    Eddie Guest
    The only one that's road legal and hasn't been crashed, yes?
    That can't be just coincidence, can it?
    Eddie, Feb 8, 2005
