I've been expecting something to crop up with the SOBoxer as I did a full recon on the carbs but did not get the smooth idle or the quick start-up I expected. It has been sitting outside for a few weeks making room for Shane's ZZR WIP so a clean and a quick spin seemed appropriate in today's sunshine (1). It started immediately and warmed up like a goodun but once washed and cold it was very reluctant. A quick check revealed a weak offside spark, a swap of plugs made no difference, so it was off with the tank. [URL]http://www.photobox.co.uk/public/detail.html?c_album=476902[/URL] and sure enough the primary resistance is way out. Bugger, that'll be £70 into the Motorworks coffer then....or will it. I've been thinking about twin plugging it with a view to fitting the 40mm carbs with a pro gas flow and valve/cam job. The Dyna coils to suit are £106. Question for TOG though - is that sort of visible external modification bad for value? given that it is a very clean low miles example of the model. Similar question about the frame finish vs future value. It could do with re-finishing and I would like to go down the powder coating route again, but does it really need to be a standard black cellulose finish? I will be needing some rather less restrictive silencers of course :o)
