It's big, red, shiny, and it goes up and down when I pump it ...
Discussion in 'UK Motorcycles' started by Salad Dodger, May 21, 2005.
  1. You got me :)
    eric the brave, May 22, 2005
  2. Well I emailed Dodger. It had to be done :)
  3. Salad Dodger
    mups Guest
    Salad Dodger says...
    mups, May 22, 2005
  4. Suspect the slave cylinder not releasing the clutch properly. Does it go
    away if you don't use the clutch for a while?
    It could just be plates though.
  5. Salad Dodger
    Salad Dodger Guest
    It had a new slave only 45,000 miles ago. It did improve a lot, but it
    didn't cure it completely. It's getting the fucking lot this time: new
    plates, lifter, spring, master cylinder kit, and fluid.
    If that doesn't fix it, I guess I'll have to do another 45000 miles on
    an iffy clutch.
    <fingers crossed> - though I doubt it, as it doesn't let go gradually.
    It either lets go completely, or grips properly.
    | ___ Salad Dodger
    |_\_____/_| ..75127../..18653.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, May 22, 2005
  6. Salad Dodger
    Is there an unwritten smiley at the end of that, or are you really
    that pathetic?
    ogden, May 22, 2005
  7. Bastard! I'm too trusting, innit?
    Brunel University. Room 40-1-B12, CERN
    GSX600F, RG250WD. "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, May 22, 2005
  8. It was like back in the old days.
  9. Best wind-up I've seen for a long time. Take a bow, Simon.
    The Older Gentleman, May 22, 2005
  10. Salad Dodger
    Ben Blaney Guest
    <applauds>
    Ben Blaney, May 22, 2005
  11. We try our best.
  12. This is after you engage the clutch I take it?
    If so then something in there must be preventing the clutch from going
    fully home. We can disregard things like car oil, worn plates, knackered
    springs, the plates in the wrong way round etc because it does engage and
    grip when it has a mind to.
    So the choices you are left with are :-
    1. The clutch release mechanism doesn't release the clutch properly.
    If you compare this to front brakes I wonder if the slave cylinder is not
    going back properly. This could be a fault with the master cylinder if it
    does not allow the fluid to return. Worth checking.
    2. The clutch is released properly but the plates are still held apart by
    grooving in the slots. Make sure all the slots in the clutch cage (drum)
    are nice and smooth. No burrs on the inside etc. Check the steel clutch
    plates for flatness on a sheet of glass or something dead flat. Replace
    the friction plates anyway now you have it apart. You could replace the
    springs as well.
  13. Salad Dodger
    Salad Dodger Guest
    Plates all looked fine, all had friction pads, though they were *very*
    smooth. Oddly, as it's a wet clutch, there were dry patches.
    The new vice was firmly into chocolate teapot territory wrt
    compressing the clutch pack: had to molish a Heath Robinson affair,
    using tyre levers, 10mm sockets, and G-clamps. Worked, though the new
    circlip pliers weren't a great help.
    Getting the fucking thing back into the engine was a right git,
    though. It has to be assembled as a unit before threading it onto the
    driven shaft's splines. Of course, the tabs on the friction plates
    don't then line up with the grooves in the basket.
    Cue much dismantling /reassembly.
    Anyway, it's in now, torqued up, new lifter assembly fitted, and cover
    back on. Alternator back on and connected. Every thing goes round like
    it should.
    I'm putting a new m/c kit in later.
    Spring replaced. Not *much* different in "dishing" to the old one,
    perhaps 1mm in all.
    All in all, quite a satisfying weekend - especially as the lift cost
    less than the labour charge for fitting a new clutch.
    By the way: top tip if you ever visit Machine Mart Docklands - the
    side door is only six feet high. Worth remembering if you're wearing
    trainers with thick soles, and don't want a lumpy head.
    | ___ Salad Dodger
  14. Salad Dodger
    Salad Dodger Guest
    Oh, I've done *proper* clutches. This isn't proper.
    <tenterhooks>
    | ___ Salad Dodger
  15. Salad Dodger
    zymurgy Guest
    You have machine mart on the Highway. Not open on Sunday tho'. Where's
    your forward planning :)
    See above.
    Staked, castellated or Nylock ?
    Don't use stanley knife on a aluminium gasket face, it's ok on a cast
    iron face. Use a wallpaper scraper and a solvent.
    Cheers
    Paul.
    zymurgy, May 23, 2005
  16. Salad Dodger
    'Hog Guest
    Or even a plastic scraper, safer still
    'Hog
    'Hog, May 23, 2005
  17. Salad Dodger
    zymurgy Guest
    Yes, where possible. I've used gasket paper before now to varying
    success [1], but it's fiddly on motorbike casings as the face widths
    can be very thin. I've also re-used old gaskets (without Hylomar) where
    they haven't adhered to the gasket face, and come off intact. Best to
    check the faces are true too, use a decent straight edge.
    nah, The ally is soft, but not that soft. I use several sizes of
    blunt(ish) wall paper scrapers. These have a bevelled edge, rather than
    a square edge, a square edge will leave marks or shave off thin slivers
    of aluminium if you're not careful.
    Cheers,
    Paul.
    [1] Usually on a Sunday evening when i've no other choice [2]
    [2] & When you start annealing copper sump plug washers on the stove ...
  18. Salad Dodger
    'Hog Guest
    I suppose it's the difference between working on your own kit or for
    someone else who is paying for the privilege. I recall I used to find
    very hard plastic scrapers in a DIY and cans of something really lovely
    that destroyed entire ecosystems while lifting old gasket paper.
    'Hog
    'Hog, May 23, 2005
  19. Salad Dodger
    zymurgy Guest
    Well, I tried not to distinguish too much between the two. Gasket faces
    are clean enough on a customer car/bike/van/truck or your own.
    When you're playing with someones brakes for money ferinstance, as I
    used to do, there's a certain duty of care involved in getting it right
    in both cases !
    Cheers
    Paul.
  20. Just use the blade. Unless your hamfisted. Millions of people have been
    doing it for ages.
    eric the brave, May 23, 2005
